I agree with tumbleweeds thought, increasing baud rate to 38k cuts the time available to process that streamed data to one quarter of what was available at 9600 baud . its asking for trouble .
what possible advantage are you seeking with the higher baud rate ?
there is great merit in sending data to the serial display as fast as possible but I have difficulty seeing any benefit in getting nmea data at higher speeds.
now that you have a chip with adequate memory and horsepower why not use a buffer to store and process the sentences?
Hi Richard, to be honest i dont know the way to store and process the sentences , but i will search for it and come back with some question. First i will try to understand the concept.
Now at the moment i need to speed up the serial communication because i need to use to fastest refresh rate of NMEA data from GPS at 10Hz.
As from the manufacturer and datasheet of the GPS, if you need to go at 5Hz or 10Hz then you need at least to speed up the GPS communication rate at 38400.
The SERIN command inside the main look, do not have any issue. Only at the beginning of the initialization and changing the baudrate and refresh rate.
Apart from that everything else works fine at that rate. At the end of the project which may not be able to complete, i will not use the GPS at 10Hz.
Now i do some fancy test to see how fast the Speed on the Display can be refreshed. As you better understand than me, in order to achieve that, the GPS data must be at a very high rate and the serial communication as well. Actually is a simple speedometer.
Thanks once again all of you for your time and effort to help me.
