Servo motor does not work correct
Results 1 to 38 of 38
    Default Re: Servo motor does not work correct
    My VB is severly rusted but I think you've got a format mismatch between what VB is sending and what the PIC is expecting - as I suggested in a previous post.
    I think that SerialPort1.Write(pos) will send the content of variable pos as an ASCII string while the PIC is expecting two binary bytes, not an ASCII string.
    If that's the case you need to change the VB program or the PIC program, on the PIC side you can use the DEC modifier to recieve an ASCII string consisting of decimal digits and parse that into a value.
    Again, there's a big difference between sending a byte as binary, ie 123 and sending it as an ASCII string. If you loop the TX to RX on the PC and fire up a terminal program, what does the data look like?
    Jun 2009
    Sc*nthorpe, UK
    VB serialport.write defaults to ASCII characters so change PIC side and use DEC modifier.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by cesar35
    Hello EarlyBird2
    I modified the program (dec pos)
    The servo move well.
    have problem
    I have no command (RX) not working AC motors
    Could you tell me why (RX) does not work.
    thank you
    Could you explain more "I have no command (RX) not working AC motors. Could you tell me why (RX) does not work."
    RX has the value "X" and the servo works so how is RX not working?
    Aug 2008
    Hello
    After modifying (DEC POS) The RX does not work
    I can send data to the rx ac motors not working.
    So the servant move
    I used (Servo gosub)
    The servant problem has already works better
    Thank you all.
    serin2 RX_inp,16468,500,PAR,[wait("PC"),RX,DEC POS]
    IF RX = "A" THEN FRE
    IF RX = "B" THEN TRA
    IF RX = "C" THEN ESQ
    IF RX = "D" THEN DIr
    GOSUB SERVO
    GOTO PROG
    SERVO:
    servo1 = 1
    PAUSEUS 1000 + pos
    servo1 = 0
    Pause 16
    Jun 2009
    Sc*nthorpe, UK
    You are saying that POS is received and works but "X" is not received.
    I noticed he changed HIGH/LOW to 1/0.
    Edit: (if I'm awake) a bipolar motor needs the 4 inputs to vary in a specific order (one for CW, one for CCW).
    If you keep turning on the motor but these don't change state, I think you end up with the motor holding position.
    Aug 2008
    As I said the command RX does not work.
    Here's a video made ​​in proteus.
  1. Servo motor control
    Last Post: - 16th July 2010, 23:44
  2. servo motor control??help
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 08:41
  3. servo/motor problem
    By griffin in forum mel PIC BASIC
    Last Post: - 10th February 2009, 21:07
  4. Servo motor problem
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 20th September 2008, 16:54
  5. contorlling servo motor
    By shirleyz in forum General
    Last Post: - 1st June 2008, 00:53
