Servo motor does not work correct
Results 1 to 38 of 38
    Jun 2009
    Sc*nthorpe, UK
    Default Re: Servo motor does not work correct
    Quote Originally Posted by EarlyBird2 View Post
    RX is not a command. RX is a variable which is assigned an ASCII code when serin2 is executed.
    I see you changed IF THEN to SELECT CASE. SELECT CASE is for values and not ASCII characters like "A".
    Did it stop working when you made these changes?
    Did you make these changes because it did not work with IF THEN?
    Is the servo working if not has the servo ever worked?
    Thanks for the code but you have not answered the questions.
    Jun 2009
    Sc*nthorpe, UK
    Looking at the code "CASE "1" is saying CASE = "1" not CASE = 1 there is a big difference. "1" is a string with ASCII value of 49 and 1 is a value of 1.
    CASE works with a value and not with strings but you can use the ASCII value.
    So CASE "1" should be CASE 49
    and CASE "A" should be CASE 65
    for example.
    Aug 2008
    for example.
    Hello
    About your question
    I modified the program to SELECT CASE.para get better to understand the program.
    Aug 2008
    Hello
    Now already understand what you said.
    on the servo seems to me that something is missing he is without direction
    Here is the corrected code.
    thank you
    @ DEVICE PIC16F876A
    @ DEVICE PIC16F876A,WDT_OFF
    @ DEVICE PIC16F876A,PWRT_OFF
    @ DEVICE PIC16F876A,PROTECT_OFF
    @ DEVICE PIC16F876A,XT_OSC
    define OCS 4
    ADCON1 = 7
    TRISC=%10000000:PORTC=%10000000
    TRISA=%11111111:PORTA=%11111111
    TRISB=%00000000:PORTB=%00000000
    SYMBOL SERVO1=PORTB.0 'SERVO1
    SYMBOL RX_INP=PORTC.7 'RF
    RX VAR BYTE
    POS VAR word
    POS = 1500
    PROG:
    serin2 RX_inp,84,600,MODATA,[wait("PC"),RX,DEC POS]
    SELECT CASE RX
    CASE 65 'A
    GOSUB FRE
    CASE 66 'B
    GOSUB TRA
    CASE 67 'C
    GOSUB DIR
    CASE 68 'D
    GOSUB ESQ
    CASE 69 'E
    HIGH PORTB.0
    pauseus 1500 + pos
    LOW PORTB.0
    Pause 20
    END SELECT
    GOTO PROG
    FRE:
    PORTC.0 = 0
    PORTC.1 = 1
    PORTC.2 = 1
    PORTC.3 = 0
    TRA:
    PORTC.0 = 1
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 1
    ESQ:
    PORTC.0 = 1
    PORTC.1 = 0
    PORTC.2 = 1
    PORTC.3 = 0
    DIR:
    PORTC.0 = 0
    PORTC.1 = 1
    PORTC.2 = 0
    PORTC.3 = 1
    MODATA:
    PORTC.0 = 0
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 0
    GOTO PROG
    If the PC is not sending A, B, C and D in the proper sequence, the motor will not turn, MODATA will hold the motor in place.
    Both are equally fine.
    CASE "A", CASE 65, CASE $41, CASE %01000001 all works and does the exact same thing.
    Jun 2009
    Sc*nthorpe, UK
    That is useful information.
    The mystery deepens then because the way CASE was written was not the problem. But CASE "A" did not work but CASE 65 does. Or does it? Is the question now. I need more feedback!
  1. Servo motor control
    Last Post: - 16th July 2010, 23:44
  2. servo motor control??help
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 08:41
  3. servo/motor problem
    By griffin in forum mel PIC BASIC
    Last Post: - 10th February 2009, 21:07
  4. Servo motor problem
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 20th September 2008, 16:54
  5. contorlling servo motor
    By shirleyz in forum General
    Last Post: - 1st June 2008, 00:53
