How do I discern Maidenhead Locator from GPS lat long info.
Results 1 to 40 of 126
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    Trying to work through the example in post #1.
    Quote Originally Posted by tasmod
    gives the grid square for 32.123 W, 14.321 N to be GJ34wg.
    The best I can come up with is HK33xv at that location.
    Are you sure about the example in post #1?
    And it seems that Andy is in Winnipeg Manitoba Canada.
    And you are near Gainsborough, U.K.
    If those are close, I can't be that far off with the calculations.
    Jan 2012
    Grid EN19MV
    Absolutely correct
    And you're right - HK33xv is in the ocean off of Cape Verde
    And 14.321N 32.123W converts to HK34wh - darn near exactly what you calculated
    -Stephen Hawking
    Thanks Andy, I knew I couldn't be that far off.
    But apparently, I need to work on the math some more.
    Darned Floating-Point ...
    Woohoo!
    HK34wh it is!!
    And it's not even midnight yet.
    It's some really ugly code right now, will need to add some "Pretty" to it.
    Are you guy's using PBP3?
    If not, there's only so much "Pretty" I can add.
    Dec 2011
    IO93ok
    Just realised you discerned my physical location from my locator. So your code should be OK.
    I did the calc by hand and got it to the example Locator given. ODD. Also needed to reverse calc the 'leftovers'
    One thing not mentioned is W is a negative longtitude. I need put an IF THEN in my code to deal with the 180 for a negative W rather than E.
    If you have ugly code then that's ok with me. I'm using 2.50 Darrel. Long time coding but not enough to be good with PBP
    The routine could also decode the 8th place pair too, which is as close as Maidenhead gets.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Dec 2011
    IO93ok
    Darn it.
    Scrap what I said about the example. I found my scratch pad and realised I used my own GPS co-ordinates to check the formula given to get my locator. I didn't use the example after all.
    Rob.
    Jan 2012
    Grid EN19MV
    Woohoo!
    HK34wh it is!!
    I am - I look forward to seeing your code because math and I do not get along well.....
    That's actually one of the reasons I have been delaying this project - the math was a bit above me right now.... I have just been using the AMSAT page to convert and see where a grid square takes me on the map.
    -Stephen Hawking
    An afterthought, before the fact.
    I went through this trying to make sure it didn't require PBP3 since Rob doesn't have it. But now that I've posted it, I realized it requires PBP 2.60 or later. DOH!
    At least you can download the free PBP3 trial version and compile it with that, or you can change the arrayread/arraywrite statements, so I'm not changing it.
    Ok, here goes ...
    It's not as ugly as it was, but without PBP3 there's only so much you can do.
    This code is based on the Perl script on the Wikipedia site for Maidenhead Locator System by Chris Ruvolo.
    Although I had to do things quite differently for the Microchip Floating-Point routines.
    The Microchip Floating-Point routines for PBP are available from http://melabs.com/resources/fp.htm
    Extract the .zip file to the same folder as your source code, or this code.
    To try to make things easy, the routines start out with a String in the same format as the Lat/Lon data of the $GPRMC sentence.
    For instance, an approximation of the IO93ok square is 0 degrees, 47.70 minutes West Longitude by 53 degrees, 26.20 minutes North latitude.
    $GPRMC will present the data as .... 5326.20,N and 00047.70,W.
    These can be parsed from the GPS data, or entered manually with the following two statements ... Note that they are null terminated.
    ARRAYWRITE LonStr,["00047.70,W",0]  ; -0° 47.70'
    ARRAYWRITE LatStr,["5326.20,N",0]   ; 53° 26.20
    I am entering them manually for this sample.
    I'm using the 24-bit Floating-Point routines, since it gave the same results as the 32-bit FP, but you can use either one by simply changing the include file.
    I imagine the 32-bit routines will be better around the edges of each square, but I haven't confirmed that.
    I'm using a 16F1937, so if you are using an 18F ... you'll need to use the 18F FP includes.
    Obviously, you need to initialize your hardware configs first.
    ; Filename    : Maidenhead.pbp
    ; Compiler    : PICBASIC PRO Compiler
    ; Target PIC  : 16F1937, but will work with most any chip
    ; Oscillator  : ANY
    ; Keywords    : Maidenhead, Locator, GPS, Amateur Radio
    ; Description : PICBASIC PRO program to convert between
    ;             : GPS Sexagesimal to Maidenhead coordinate systems
                           ; use only one of the FP includes
    INCLUDE "FP20.bas"     ; 24-bit Floating Point for 14-bit cores with RAM at $20
    ;INCLUDE "FP2032.bas"   ; 32-bit Floating Point for 14-bit cores with RAM at $20
    DEFINE HSER_SPBRG 25  ' 19200 Baud @ 32MHz, 0.16%
    HSEROUT [27,"[2J","Maidenhead Locator",13,10]
    HSEROUT ["16F1937, 32Mhz, PBP3 not required",13,10,13,10]
    MH     VAR BYTE[6]
    LonStr    VAR BYTE[12]
    LatStr    VAR BYTE[12]
    LonDeg    VAR BYTE
    LonMin    VAR BYTE
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatDeg    VAR BYTE
    LatMin    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    ARRAYWRITE LonStr,["00047.70,W",0]  ; -0° 47.70'  <-- Enter location here
    ARRAYWRITE LatStr,["5326.20,N",0]   ; 53° 26.20'
    HSEROUT ["LonStr  = ", STR LonStr,13,10]          ; display manual input
    HSEROUT ["LatStr  = ", STR LatStr,13,10]
    ;----[parse strings as if they came from a GPS]---------------------------------
    ARRAYREAD LonStr,[DEC3 LonDeg, DEC2 LonMin, Dec LonMinDec, LonDir]
    ARRAYREAD LatStr,[DEC2 LatDeg, DEC2 LatMin, Dec LatMinDec, LatDir]
    ;----[convert Longitude Sexagesimal to Decimal Degrees]-------------------------
    Aint = LonMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    Bint = 100 : GOSUB ItoFB          ; divided by 100
    GOSUB fpdiv
    Bint = LonMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    Bint = 60 : GOSUB ItoFB           ; divide by 60
    GOSUB fpdiv
    Bint = LonDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LonDir = "W" THEN              ; if west of Prime Meridian
        GOSUB AtoB
        Aint = 0    : GOSUB ItoFA     ; subtract from 0 to negate
        GOSUB fpsub
    Bint = 180  : GOSUB ItoFB         ; add 180
    GOSUB fpadd
    ;----[Have Longitude in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Longitude for later
    Bint = 20   : GOSUB ItoFB         ; Lon / 20
    GOSUB fpdiv
    GOSUB SaveAARG                    ; save AARG for modulus
    GOSUB FtoIA                       ; get integer
    MH(0) = "A" + Aint                ; + "A" = First character
                                      ; -- do  Lon // 20 --- (modulus)
    Bint = Aint                       ; copy integer result to BARG
    GOSUB ItoFB                       ; convert it to float
    GOSUB RestoreAARG                 ; restore Lon / 20 to AARG
    GOSUB fpsub                       ; subtract integer
    Bint = 20                         ; multiply times original divisor (20)
    GOSUB ItoFB
    GOSUB fpmul                       ; AARG now contains the modulus
    Bint = 2    : GOSUB ItoFB         ; divide modulus by 2
    GOSUB fpdiv
    MH(2) = "0" + Aint                ; + "0" = Third character
    GOSUB RestoreLon                  ; restore Longitude
    GOSUB fpdiv                       ; divide by 2
    Bint = Aint * 2  : GOSUB ItoFB    ; put int * 2 in BARG, change back to float
    GOSUB RestoreLon                  ; restore original Longitude
    GOSUB fpsub                       ; subtract A - B
    Bint = 12 : GOSUB ItoFB           ; Multiply * 12
    GOSUB fpmul
    MH(4) = "a" + Aint                ; + "a" = Fifth Character
    ;----[convert Latitude Sexagesimal to Decimal Degrees]--------------------------
    Aint = LatMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    Bint = LatMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    GOSUB fpdiv
    Bint = LatDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LatDir = "S" THEN              ; if south of equator
        GOSUB AtoB
        GOSUB fpsub
    Bint = 90  : GOSUB ItoFB          ; add 90
    GOSUB fpadd
    ;----[Have Latitude  in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Latitude for later
    Bint = 10   : GOSUB ItoFB         ; Lat / 10
    GOSUB fpdiv
    GOSUB FtoIA
    MH(1) = "A" + Aint                ; + "A" = Second character
                                      ; -- do  Lat // 10 --- (modulus)
    GOSUB RestoreAARG                 ; restore Lat / 10 to AARG
    Bint = 10                         ; multiply times original divisor (10)
    GOSUB ItoFB
    GOSUB FtoIA
    MH(3) = "0" + Aint                ; + "0" = Fourth character
    GOSUB RestoreLon                  ; restore original Latitude
    Bint = Aint : GOSUB ItoFB         ; put int in BARG, change back to float
    Bint = 24 : GOSUB ItoFB           ; Multiply * 24
    GOSUB fpmul
    MH(5) = "a" + Aint                ; + "a" = Sixth character
    ;----[Maidenhead conversion complete]-------------------------------------------
    HSEROUT ["LOC ",STR MH\6,13,10,13,10] ; show final result
    Main:                             ; blink an LED when done
        HIGH PORTA.0
        PAUSE 500
        LOW PORTA.0
        PAUSE 500
    GOTO Main
    Aexp_Copy    VAR BYTE
    AARGB0_Copy  VAR BYTE
    AARGB1_Copy  VAR BYTE
    AARGB2_Copy  VAR BYTE
    Aexp_Lon     VAR BYTE
    AARGB0_Lon   VAR BYTE
    AARGB1_Lon   VAR BYTE
    AARGB2_Lon   VAR BYTE
    SaveAARG:
        Aexp_Copy = Aexp
        AARGB0_Copy = AARGB0
        AARGB1_Copy = AARGB1
        AARGB2_Copy = AARGB2
    RestoreAARG:
        Aexp = Aexp_Copy
        AARGB0 = AARGB0_Copy
        AARGB1 = AARGB1_Copy
        AARGB2 = AARGB2_Copy
    AtoB:
        Bexp = Aexp
        BARGB0 = AARGB0
        BARGB1 = AARGB1
        BARGB2 = AARGB2
    SaveLon:
        Aexp_Lon = Aexp
        AARGB0_Lon = AARGB0
        AARGB1_Lon = AARGB1
        AARGB2_Lon = AARGB2
    RestoreLon:
        Aexp = Aexp_Lon
        AARGB0 = AARGB0_Lon
        AARGB1 = AARGB1_Lon
        AARGB2 = AARGB2_Lon
    The output from the program in a terminal looks like this ...
    Maidenhead Locator
    LonStr  = 00047.70,W
    LatStr  = 5326.20,N
    LOC IO93ok
    If you are using an Enhanced 14-bit core like the 16F1937 that I'm using ... you'll need to add the processor to the DEV_FAM.INC file from the FP.zip
    For the 16F1937 add this towards the bottom of the file (before the if statement).
        IFDEF   __16F1937          ; Generic Processor Type
    P16CXX      SET    TRUE        ; If P16CXX, use INHX8M file format.
    P16_MAP2    SET    TRUE        ;
    References:
    Jan 2012
    Grid EN19MV
    Umm, WOW! Thanks Darrel! And my brain thanks you even more, since it gets uppity when it has to do complex math!
    -Stephen Hawking
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 17:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 08:44
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 12:54
