How do I discern Maidenhead Locator from GPS lat long info.
Results 1 to 40 of 126
    Dec 2011
    IO93ok
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    Hmm, I've always had problems with configs.
    A single line config errors out. Multiple lines actually works and sets my programmer fuses OK.
    I also have severe problems with Mpasmwin 5.20 giving hundreds of errors with PBP which I now just ignore.
    I like the Months code. That's one of the things I just couldn't get right but I was thinking that way.
    How would I go about loading the character set ? I just don't get it.
    The brain is full of different ideas for the project, so many options. Even thought of two lcds.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Quote Originally Posted by tasmod
    @__config_HS_OSC
    @__config_BOD_OFF
    @__config_PWRT_ON
    @__config_WDT_ON
    @__config_PROTECT_OFF
    @__config_LVP_OFF
    Those lines are not configuration statements.
    They are actually assembly language labels. You could use an asm GOTO to jump to any one of them.
    They will not set the configuration bits in your programmer.
    If the one line __config I gave you gives an error, it's probably the "Overwriting address 2007" error that means you didn't comment the default configs in the .inc file.
    Very bad idea.
    You should track down every error and fix it.
    How would you know if there are real errors if you always just ignore them.
    If you don't know what they mean ... get help.
    These lines from your code load the custom characters
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #0
    'LCDOUT  $FE,$40,$02,$02,$02,$02,$02,$02,$02,$02  ' Cust Char #0
    LCDOUT  $FE,$48,$1F,$1F,$1B,$1B,$1B,$1B,$1B,$1B  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$1F,$18,$18,$18,$18,$1F,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$03,$03,$03,$03,$03,$03,$1F,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$1F,$1F,$1B,$1B,$1B,$1B,$1F,$1F  ' Cust Char #4
    LCDOUT  $FE,$68,$1B,$1B,$1B,$1B,$1B,$1B,$1F,$1F  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$03,$03,$03,$03,$1F,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1F,$1F,$03,$03,$03,$03,$03,$03  ' Cust Char #7
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #8
    You'll have another set of similar lines for your 4-line big digits.
    Executing those lines will overwrite the customs characters you previously loaded.
    However, you can only have 8 custom characters at a time, and you have 9 listed above.
    The one commented as Cust Char #8, is actually Cust Char #0 and will overwrite the first Cust Char #0. Good thing they're the same.
    Dec 2011
    IO93ok
    Hi Darrel,
    Many thanks for your help.
    The code I posted was the last working example on this PC connected to the net. The actual programming pc is in another room and not net connected (deliberately). There were a couple of errors, the second $40 character set was one and a missing RETURN was another.
    The Month routine was deliberately moved down from the GPS loop. Since the post I moved it into the loop and reformatted the display lines to suit the new layout. I will however look at the array solution now.
    I've always had problems with Mpasmwin and errors. For instance the code posted has 891 errors at assembly, all of which relate to standard PBP instructions. e.g. LCDOUT alone is an error, FOR is an error etc. etc.
    This is a sample around your Locator code :-
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1049 : Illegal opcode (_LatDir)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1052 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1052 : Illegal opcode (_AtoB)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1058 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1058 : Illegal opcode (_itofa)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1061 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1061 : Illegal opcode (_fpsub)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1064 : Found label after column 1. (LABEL?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1064 : Illegal opcode (L00042)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1070 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1070 : Illegal opcode (_itofb)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1073 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1073 : Illegal opcode (_fpadd)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1076 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1076 : Illegal opcode (_SaveLon)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1082 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1082 : Illegal opcode (_itofb)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1085 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1085 : Illegal opcode (_fpdiv)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1088 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1088 : Illegal opcode (_SaveAARG)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1091 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1091 : Illegal opcode (_ftoia)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1094 : Found label after column 1. (ADD?CWB)
    Error[108] C:\FPOINT\NMEA16F876ABIG.ASM 1094 : Illegal character (0)
    I will re-install 5.20 and see if it cures it. I'm sure years back I didn't have the problem.
    Rob.
    Dec 2011
    IO93ok
    SOLVED. Wrong MPASM Suite.
    I'm using PBP2.50 and at some point I must have upgraded the MPASM Suite to 8.90.
    I needed to delete and re-install 8.15 instead.
    I now get a complete compile and assemble without any errors.
    Just needed to think quietly about the problem.
    Rob.
    Dec 2011
    IO93ok
    Darrel,
    I tried incorporating your Month code but it causes odd errors in the ShowMonth, based on the FOR/NEXT loop and especially the idx. This is maybe where I placed it in the code but I will continue to try it.
    Right now I have completed the code using the long Month code and I'm able to toggle back and forth between all info onscreen and the fullscreen big digit clock.
    ; 			        PIC16F876a
    ;                          __________
    ;                          !MCLR |1        28| RB7------D7
    ;     PLL Volt--AN0---RA0 |2        27| RB6------D6
    ;         Temp--AN1---RA1 |3        26| RB5------D5
    ;                    AN2---RA2 |4        25| RB4------D4
    ;                    AN3---RA3 |5        24| RB3------LCD E
    ;           NMEA data---RA4 |6        23| RB2------LCD RS
    ;                    AN4---RA5 |7        22| RB1------
    ;                Ground---Vss |8        21| RB0------
    ;                OSC1---XTAL |9        20| VDD------ +5 V
    ;                OSC2---XTAL |10       19| Vss------Ground
    ;                         ---RC0 |11       18| RC7------
    ;                         ---RC1 |12       17| RC6------
    ;                         ---RC2 |13       16| RC5------
    ;              pbutton---RC3 |14       15| RC4------
    ' Program to display returned value of a GPS on RA4
    ' LCD in 4-BIT mode PIC16F876a controller 4Mhz clock Fuse PWRT BODEN
    'GPS sentence: $GPRMC,192144.62,A,5041.6058,N,00412.6124,E,0.45,3 57.74,081205,,*0B
    @  __config  _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    'wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    INCLUDE "FP20.bas"     ; 24-bit Floating Point for 14-bit cores with RAM at $20
    Define LCD_DREG PORTB          ' Port for LCD Data
    Define LCD_DBIT 4              ' Set LCD starting data bit
    Define LCD_RSREG PORTB         ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 2             ' Port Pin for RS bit  (pin9)
    Define LCD_EREG PORTB          ' Port for Enable (E) bit
    Define LCD_EBIT 3              ' Port Pin for E bit    (pin7)
    Define LCB_BITS 4              ' Using 4-bit bus
    Define LCD_COMMANDUS 1500      ' Command Delay (uS)
    define LCD_DATAUS 50           ' Data Delay (uS)
    OPTION_REG.7=0                 ' Enable Pull-Up's
    GPSin VAR PORTA.4
    Pbutton VAR PORTC.3
    ' Initialise ADC
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel 0 Fosc 8
    PAUSE 500
    'Declare variables
    val VAR WORD      ' final calculated adc valuesWORD' final calculated adc values
    volt VAR WORD     ' scaled value real part
    voltd1 VAR WORD   ' scaled value first decimal place
    voltd2 VAR WORD   ' scaled value second decimal place
    i var byte        ' counter
    'Allocate Variables for GPS:
    TimeOut CON 2000
    hh VAR BYTE             'hours
    mm VAR BYTE             'minutes
    ss VAR BYTE             'seconds
    knots VAR WORD          'speed in knots (units)
    knotsten VAR BYTE       'speed in knots (tens)
    course VAR WORD         'heading
    latdeg VAR BYTE         'degrees latitude
    latmin VAR BYTE         'minutes latitude
    latsecs VAR BYTE        'seconds latitude
    NS VAR BYTE             'north or south
    londeg VAR BYTE         'degrees longitude
    lonmin VAR BYTE         'minutes longitude
    lonsecs VAR BYTE        'seconds longtitude
    EW VAR BYTE             'east or west
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    butt VAR BYTE           'pushbutton variable
    marker VAR BYTE         'toggle marker
    MH     VAR BYTE[6]
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    nPos  var byte
    nDig  var byte
    fix VAR WORD 'GPS fix
    LCDOut $fe,$80,"    GPS Decoder     "
    LCDOut $FE,$c0," G8VLQ  March 2014  "
    Pause 3000
    LCDOut $FE, 1           'Clear Screen
    butt = 0
    marker = 0
    GPS: 'read GPS  #############################################################################################
    SerIn2 GPSin,188,Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss,wait(","),fix,wait(",")_
    ,DEC2 latdeg,DEC2 latmin,wait("."),DEC2 latsecs,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),DEC2 lonsecs,_
    wait(","),EW,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 d,DEC2 m,DEC2 y]
    IF marker = 1 THEN BigClock
    LonMinDec = lonmin
    LatMinDec = latmin
    LonDir = EW
    LatDir = NS
    BUTTON Pbutton,0,100,0,butt,1,BigClockClear
    If m = 01 then gosub January          ; show month
    If m = 02 then gosub February
    If m = 03 then gosub March
    If m = 04 then gosub April
    If m = 05 then gosub May
    If m = 06 then gosub June
    If m = 07 then gosub July
    If m = 08 then gosub August
    If m = 09 then gosub September
    If m = 10 then gosub October
    If m = 11 then gosub November
    If m = 12 then gosub December
    gosub PLL         ;pll control voltage
    GOSUB Locator     ;maidenhead locator
    GOSUB Clock       ;Large digit clock
    goto GPS          ; ##########################################################################################
    PLL:
    Val = 0                       ' Value returned is the average of 5 conversions
    For i = 0 TO 4
    ADCON0.2 = 1                  ' Start conversion
    NotDone:
    pause 1
    IF ADCON0.2 = 1 Then NotDone
    val = val + ((ADRESH * 256)+(ADRESL))
    nEXT I
    VAL = VAL/5
    ' Calculate Voltage to 2 decimal places
    volt = val * 5/1024
    voltd1 = ( val * 5//1024) * 10/1024
    Voltd2 = ((val *5 //1024) * 10//1024) * 10/1024
    Locator:
    ;----[convert Longitude Sexagesimal to Decimal Degrees]-------------------------
    Aint = LonMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    Bint = 100 : GOSUB ItoFB          ; divided by 100
    GOSUB fpdiv
    Bint = LonMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    Bint = 60 : GOSUB ItoFB           ; divide by 60
    GOSUB fpdiv
    Bint = LonDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LonDir = "W" THEN              ; if west of Prime Meridian
        GOSUB AtoB
        Aint = 0    : GOSUB ItoFA     ; subtract from 0 to negate
        GOSUB fpsub
    Bint = 180  : GOSUB ItoFB         ; add 180
    GOSUB fpadd
    ;----[Have Longitude in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Longitude for later
    Bint = 20   : GOSUB ItoFB         ; Lon / 20
    GOSUB fpdiv
    GOSUB SaveAARG                    ; save AARG for modulus
    GOSUB FtoIA                       ; get integer
    MH(0) = "A" + Aint                ; + "A" = First character
                                      ; -- do  Lon // 20 --- (modulus)
    Bint = Aint                       ; copy integer result to BARG
    GOSUB ItoFB                       ; convert it to float
    GOSUB RestoreAARG                 ; restore Lon / 20 to AARG
    GOSUB fpsub                       ; subtract integer
    Bint = 20                         ; multiply times original divisor (20)
    GOSUB ItoFB
    GOSUB fpmul                       ; AARG now contains the modulus
    Bint = 2    : GOSUB ItoFB         ; divide modulus by 2
    GOSUB fpdiv
    MH(2) = "0" + Aint                ; + "0" = Third character
    GOSUB RestoreLon                  ; restore Longitude
    GOSUB fpdiv                       ; divide by 2
    Bint = Aint * 2  : GOSUB ItoFB    ; put int * 2 in BARG, change back to float
    GOSUB RestoreLon                  ; restore original Longitude
    GOSUB fpsub                       ; subtract A - B
    Bint = 12 : GOSUB ItoFB           ; Multiply * 12
    GOSUB fpmul
    MH(4) = "a" + Aint                ; + "a" = Fifth Character
    ;----[convert Latitude Sexagesimal to Decimal Degrees]--------------------------
    Aint = LatMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    Bint = LatMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    GOSUB fpdiv
    Bint = LatDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LatDir = "S" THEN              ; if south of equator
        GOSUB AtoB
        GOSUB fpsub
    Bint = 90  : GOSUB ItoFB          ; add 90
    GOSUB fpadd
    ;----[Have Latitude  in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Latitude for later
    Bint = 10   : GOSUB ItoFB         ; Lat / 10
    GOSUB fpdiv
    GOSUB FtoIA
    MH(1) = "A" + Aint                ; + "A" = Second character
                                      ; -- do  Lat // 10 --- (modulus)
    GOSUB RestoreAARG                 ; restore Lat / 10 to AARG
    Bint = 10                         ; multiply times original divisor (10)
    GOSUB ItoFB
    GOSUB FtoIA
    MH(3) = "0" + Aint                ; + "0" = Fourth character
    GOSUB RestoreLon                  ; restore original Latitude
    Bint = Aint : GOSUB ItoFB         ; put int in BARG, change back to float
    Bint = 24 : GOSUB ItoFB           ; Multiply * 24
    GOSUB fpmul
    MH(5) = "a" + Aint                ; + "a" = Sixth character
    ;----[Maidenhead conversion complete]-------------------------------------------
    Aexp_Copy    VAR BYTE
    AARGB0_Copy  VAR BYTE
    AARGB1_Copy  VAR BYTE
    AARGB2_Copy  VAR BYTE
    Aexp_Lon     VAR BYTE
    AARGB0_Lon   VAR BYTE
    AARGB1_Lon   VAR BYTE
    AARGB2_Lon   VAR BYTE
    SaveAARG:
        Aexp_Copy = Aexp
        AARGB0_Copy = AARGB0
        AARGB1_Copy = AARGB1
        AARGB2_Copy = AARGB2
    RestoreAARG:
        Aexp = Aexp_Copy
        AARGB0 = AARGB0_Copy
        AARGB1 = AARGB1_Copy
        AARGB2 = AARGB2_Copy
    AtoB:
        Bexp = Aexp
        BARGB0 = AARGB0
        BARGB1 = AARGB1
        BARGB2 = AARGB2
    SaveLon:
        Aexp_Lon = Aexp
        AARGB0_Lon = AARGB0
        AARGB1_Lon = AARGB1
        AARGB2_Lon = AARGB2
    RestoreLon:
        Aexp = Aexp_Lon
        AARGB0 = AARGB0_Lon
        AARGB1 = AARGB1_Lon
        AARGB2 = AARGB2_Lon
    January:
    LCDOut $fe,$80+9,DEC2 d," Jan ","20",DEC2 y
    February:
    LCDOut $fe,$80+9,DEC2 d," Feb ","20",DEC2 y
    March:
    LCDOut $fe,$80+9,DEC2 d," Mar ","20",DEC2 y
    April:
    LCDOut $fe,$80+9,DEC2 d," Apr ","20",DEC2 y
    May:
    LCDOut $fe,$80+9,DEC2 d," May ","20",DEC2 y
    June:
    LCDOut $fe,$80+9,DEC2 d," Jun ","20",DEC2 y
    July:
    LCDOut $fe,$80+9,DEC2 d," Jul ","20",DEC2 y
    August:
    LCDOut $fe,$80+9,DEC2 d," Aug ","20",DEC2 y
    September:
    LCDOut $fe,$80+9,DEC2 d," Sep ","20",DEC2 y
    October:
    LCDOut $fe,$80+9,DEC2 d," Oct ","20",DEC2 y
    November:
    LCDOut $fe,$80+9,DEC2 d," Nov ","20",DEC2 y
    December:
    LCDOut $fe,$80+9,DEC2 d," Dec ","20",DEC2 y
    ClockClear:
    marker = 0
    GOTO GPS
    Clock:
                         ;Display time
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
        nDig=hh dig 1 : nPos=0 : gosub displaydigit
        nDig=hh dig 0 : nPos=1 : gosub displaydigit
          npos=2 : gosub colon
        ndig=mm dig 1 : npos=3 : gosub displaydigit
        ndig=mm dig 0 : npos=4 : gosub displaydigit
          npos=5 : gosub colon
        ndig=ss dig 1 : npos=6 : gosub displaydigit
        ndig=ss dig 0 : npos=7 : gosub displaydigit
    LCDOut $fe,$c0+9,"    ",#volt, ".", # voltd1,# voltd2,"v"
    LCDOUT $fe,$94,"   G8VLQ    ",STR MH\6
    LCDOut $fe,$d4,DEC2 latdeg,$DF,DEC2 latmin,"'",DEC2 latsecs,NS,"  ",DEC2 londeg,$DF,DEC2 lonmin,"'",DEC2 lonsecs,EW                           ; ,#volt, ".", # voltd1,# voltd2,"v"   ; d4 4th line
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub one
    if ndig=2 then gosub two
    if ndig=3 then gosub three
    if ndig=4 then gosub four
    if ndig=5 then gosub five
    if ndig=6 then gosub six
    if ndig=7 then gosub seven
    if ndig=8 then gosub eight
    if ndig=9 then gosub nine
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    colon:
        lcdout $fe,$80+nPos,$A5
        lcdout $FE,$C0+nPos,$A5
    BigClockClear:
    marker = 1
    BigClock:
    LCDOUT  $FE,$40,$07,$07,$07,$07,$07,$07,$07,$07  ' Cust Char #0
    LCDOUT  $FE,$48,$1C,$1C,$1C,$1C,$1C,$1C,$1C,$1C  ' Cust Char #1
    LCDOUT  $FE,$50,$03,$07,$0F,$1E,$1C,$1C,$1C,$1C  ' Cust Char #2
    LCDOUT  $FE,$58,$18,$1C,$1E,$0F,$07,$07,$07,$07  ' Cust Char #3
    LCDOUT  $FE,$60,$1C,$1C,$1C,$1C,$1E,$0F,$07,$03  ' Cust Char #4
    LCDOUT  $FE,$68,$07,$07,$07,$07,$0F,$1E,$1C,$18  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$1F,$00,$00,$00,$00,$00  ' Cust Char #6
    LCDOUT  $FE,$78,$00,$00,$00,$00,$00,$1F,$1F,$1F  ' Cust Char #7
    BUTTON Pbutton,0,100,0,butt,1,ClockClear
                         ;Display time
        nDig=hh dig 1 : nPos=0 : gosub displaydigit1
        nDig=hh dig 0 : nPos=3 : gosub displaydigit1
          npos=6 : gosub colon1
        ndig=mm dig 1 : npos=7 : gosub displaydigit1
        ndig=mm dig 0 : npos=10 : gosub displaydigit1
          npos=13 : gosub colon1
        ndig=ss dig 1 : npos=14 : gosub displaydigit1
        ndig=ss dig 0 : npos=17 : gosub displaydigit1
    GOTO GPS
    displaydigit1:
    if ndig=0 then gosub Zero1
    if ndig=1 then gosub One1
    if ndig=2 then gosub Two1
    if ndig=3 then gosub Three1
    if ndig=4 then gosub Four1
    if ndig=5 then gosub Five1
    if ndig=6 then gosub Six1
    if ndig=7 then gosub Seven1
    if ndig=8 then gosub Eight1
    if ndig=9 then gosub Nine1
    Zero1:
        LCDOUT $FE,$81+nPos,3
    	LCDOUT $FE,$C0+nPos,1
        LCDOUT $FE,$C1+nPos,0
    	LCDOUT $FE,$94+nPos,1
        LCDOUT $FE,$95+nPos,0
    	LCDOUT $FE,$D4+nPos,4
        LCDOUT $FE,$D5+nPos,5
    One1:
        LCDOUT $FE,$80+nPos," "
    	LCDOUT $FE,$81+nPos,0
    	LCDOUT $FE,$C0+nPos," "
    	LCDOUT $FE,$94+nPos," "
    	LCDOUT $FE,$D4+nPos," "
    	LCDOUT $FE,$D5+nPos,0
    Two1:
    	LCDOUT $FE,$C0+nPos,7
    	LCDOUT $FE,$C1+nPos,5
    	LCDOUT $FE,$95+nPos," "
    	LCDOUT $FE,$D5+nPos,7
    Three1:
    	LCDOUT $FE,$95+nPos,3
    	LCDOUT $FE,$D4+nPos,7
    Four1:
    	LCDOUT $FE,$81+nPos," "
    	LCDOUT $FE,$C0+nPos,4
    	LCDOUT $FE,$C1+nPos,7
    	LCDOUT $FE,$95+nPos,1
    	LCDOUT $FE,$D5+nPos,1
    Five1:
    	LCDOUT $FE,$81+nPos,6
    	LCDOUT $FE,$C1+nPos," "
    	LCDOUT $FE,$94+nPos,6
    Six1:
    	LCDOUT $FE,$94+nPos,2
    Seven1:
    Eight1:
    Nine1:
    colon1:
        LCDOUT $FE,$C0+nPos,$A5
        LCDOUT $FE,$94+nPos,$A5
    Rob.
    Dec 2011
    IO93ok
    Forgive me oh codemaster Darrel.
    The idiot has been programming again. I am but a lowly code serf with an aged addled brain.......................................I forgot to declare the variables in your Month routine.
    Rob.
    Dec 2011
    IO93ok
    Complete working prototype system
    Rockwell GPS Module on right. PLL and TCXO board on left. TCXO is small vertical board top left. Small board at top with all wires is 7805 5v reg board.
    Rear of LCD showing piggyback decoder.
    Rob.
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 17:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 08:44
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 12:54
