How do I discern Maidenhead Locator from GPS lat long info.
Results 1 to 40 of 126
    Dec 2011
    IO93ok
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    Now that was completely stupid of me, I apologise for such a silly mistake. I had never seen the message before and assumed it was a code error.
    I never gave it a thought to look at the chip spec. The reason to change over to 818 was just one adc input. The chip otherwise is pin compatible for what I've already done.
    I think I will remake a new display pcb and use the 16f876 28 pin chip that has 8k.
    The project uses the chip to accept the NMEA string from a Rockwell gps module and display it. This older gps module also produces accurate 1PPS and 10kHz signals when gps has a fix.
    I'm using these signals on a pll and divider board to lock a 10mhz tcxo.
    In its present application it would have worked fine but I wanted to monitor the gps pll control voltage on the board to check for frequency lock.
    If the voltage was 1.65v then the oscillator was in lock state.
    The display did show whether the satellites produced a fix but not whether the oscillator had locked against the 10khz frequency. Watching the pll control voltage hunt back and forth whilst the gps attempted a fix was facinating but impractical for 'normal' usage.
    Once I have the display running again I'll report back.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Dec 2011
    IO93ok
    Just looked in my box o bits and found a 18f1330 which is pin compatible with 4k space.
    Not quite pin compatible unfortunately, ports mixed
    Rob.
    Dec 2011
    IO93ok
    Here you go Darrel -
    That display is huge at 4inch by 2 inch (See pic chip in background) Used a 16f876a in the end. That's your BigDigit code put to use as well.
    Display shows 1.65v which indicates to me that the oscillator control voltage is stable and in lock.
    Code needs some polishing especially Month but that's a work in progress :-
    ; 			        PIC16F876a
    ;                          __________
    ;                   !MCLR |1        28| RB7------D7
    ;     PLL Volt--AN0---RA0 |2        27| RB6------D6
    ;         Temp--AN1---RA1 |3        26| RB5------D5
    ;               AN2---RA2 |4        25| RB4------D4
    ;               AN3---RA3 |5        24| RB3------LCD E
    ;         NMEA data---RA4 |6        23| RB2------LCD RS
    ;               AN4---RA5 |7        22| RB1------
    ;            Ground---Vss |8        21| RB0------
    ;             OSC1---XTAL |9        20| VDD------ +5 V
    ;             OSC2---XTAL |10       19| Vss------Ground
    ;                  ---RC0 |11       18| RC7------
    ;                  ---RC1 |12       17| RC6------
    ;                  ---RC2 |13       16| RC5------
    ;           pbutton---RC3 |14       15| RC4------
    ;   Serial data out               Not used    Not used
    ' Program to display returned value of a GPS on RA4
    ' LCD in 4-BIT mode PIC16F876a controller 4Mhz clock Fuse PWRT BODEN
    'GPS sentence: $GPRMC,192144.62,A,5041.6058,N,00412.6124,E,0.45,3 57.74,081205,,*0B
    @__config_HS_OSC
    @__config_BOD_OFF
    @__config_PWRT_ON
    @__config_WDT_ON
    @__config_PROTECT_OFF
    @__config_LVP_OFF
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    INCLUDE "FP20.bas"     ; 24-bit Floating Point for 14-bit cores with RAM at $20
    Define LCD_DREG PORTB          ' Port for LCD Data
    Define LCD_DBIT 4              ' Set LCD starting data bit
    Define LCD_RSREG PORTB         ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 2             ' Port Pin for RS bit  (pin9)
    Define LCD_EREG PORTB          ' Port for Enable (E) bit
    Define LCD_EBIT 3              ' Port Pin for E bit    (pin7)
    Define LCB_BITS 4              ' Using 4-bit bus
    Define LCD_COMMANDUS 1500      ' Command Delay (uS)
    define LCD_DATAUS 50           ' Data Delay (uS)
    OPTION_REG.7=0                 ' Enable Pull-Up's
    GPSin VAR PORTA.4
    Pbutton VAR PORTC.3
    ' Initialise ADC
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel 0 Fosc 8
    PAUSE 500
    'Declare variables
    val VAR WORD      ' final calculated adc valuesWORD' final calculated adc values
    volt VAR WORD     ' scaled value real part
    voltd1 VAR WORD   ' scaled value first decimal place
    voltd2 VAR WORD   ' scaled value second decimal place
    i var byte        ' counter
    'Allocate Variables for GPS:
    TimeOut CON 2000
    hh VAR BYTE             'hours
    mm VAR BYTE             'minutes
    ss VAR BYTE             'seconds
    knots VAR WORD          'speed in knots (units)
    knotsten VAR BYTE       'speed in knots (tens)
    course VAR WORD         'heading
    latdeg VAR BYTE         'degrees latitude
    latmin VAR BYTE         'minutes latitude
    latsecs VAR BYTE        'seconds latitude
    NS VAR BYTE             'north or south
    londeg VAR BYTE         'degrees longitude
    lonmin VAR BYTE         'minutes longitude
    lonsecs VAR BYTE        'seconds longtitude
    EW VAR BYTE             'east or west
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    MH     VAR BYTE[6]
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    nPos  var byte
    nDig  var byte
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #0
    'LCDOUT  $FE,$40,$02,$02,$02,$02,$02,$02,$02,$02  ' Cust Char #0
    LCDOUT  $FE,$48,$1F,$1F,$1B,$1B,$1B,$1B,$1B,$1B  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$1F,$18,$18,$18,$18,$1F,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$03,$03,$03,$03,$03,$03,$1F,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$1F,$1F,$1B,$1B,$1B,$1B,$1F,$1F  ' Cust Char #4
    LCDOUT  $FE,$68,$1B,$1B,$1B,$1B,$1B,$1B,$1F,$1F  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$03,$03,$03,$03,$1F,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1F,$1F,$03,$03,$03,$03,$03,$03  ' Cust Char #7
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #8
    fix VAR WORD 'GPS fix
    LCDOut $fe,$80,"    GPS Decoder     "
    LCDOut $FE,$c0," G8VLQ  March 2014  "
    Pause 3000
    LCDOut $FE, 1           'Clear Screen
    GPS: 'read GPS
    SerIn2 GPSin,188,Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss,wait(","),fix,wait(",")_
    ,DEC2 latdeg,DEC2 latmin,wait("."),DEC2 latsecs,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),DEC2 lonsecs,_
    wait(","),EW,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 d,DEC2 m,DEC2 y]
    LonMinDec = lonmin
    LatMinDec = latmin
    LonDir = EW
    LatDir = NS
    gosub PLL         ;pll control voltage
    GOSUB Locator     ;maidenhead locator
    GOSUB Clock      ; Large digit clock
    goto GPS
    If m = 01 then gosub January          ; show month
    If m = 02 then gosub February
    If m = 03 then gosub March
    If m = 04 then gosub April
    If m = 05 then gosub May
    If m = 06 then gosub June
    If m = 07 then gosub July
    If m = 08 then gosub August
    If m = 09 then gosub September
    If m = 10 then gosub October
    If m = 11 then gosub November
    If m = 12 then gosub December
    PLL:
    Val = 0                       ' Value returned is the average of 5 conversions
    For i = 0 TO 4
    ADCON0.2 = 1                  ' Start conversion
    NotDone:
    pause 1
    IF ADCON0.2 = 1 Then NotDone
    val = val + ((ADRESH * 256)+(ADRESL))
    nEXT I
    VAL = VAL/5
    ' Calculate Voltage to 2 decimal places
    volt = val * 5/1024
    voltd1 = ( val * 5//1024) * 10/1024
    Voltd2 = ((val *5 //1024) * 10//1024) * 10/1024
    Locator:
    ;----[convert Longitude Sexagesimal to Decimal Degrees]-------------------------
    Aint = LonMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    Bint = 100 : GOSUB ItoFB          ; divided by 100
    GOSUB fpdiv
    Bint = LonMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    Bint = 60 : GOSUB ItoFB           ; divide by 60
    GOSUB fpdiv
    Bint = LonDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LonDir = "W" THEN              ; if west of Prime Meridian
        GOSUB AtoB
        Aint = 0    : GOSUB ItoFA     ; subtract from 0 to negate
        GOSUB fpsub
    Bint = 180  : GOSUB ItoFB         ; add 180
    GOSUB fpadd
    ;----[Have Longitude in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Longitude for later
    Bint = 20   : GOSUB ItoFB         ; Lon / 20
    GOSUB fpdiv
    GOSUB SaveAARG                    ; save AARG for modulus
    GOSUB FtoIA                       ; get integer
    MH(0) = "A" + Aint                ; + "A" = First character
                                      ; -- do  Lon // 20 --- (modulus)
    Bint = Aint                       ; copy integer result to BARG
    GOSUB ItoFB                       ; convert it to float
    GOSUB RestoreAARG                 ; restore Lon / 20 to AARG
    GOSUB fpsub                       ; subtract integer
    Bint = 20                         ; multiply times original divisor (20)
    GOSUB ItoFB
    GOSUB fpmul                       ; AARG now contains the modulus
    Bint = 2    : GOSUB ItoFB         ; divide modulus by 2
    GOSUB fpdiv
    MH(2) = "0" + Aint                ; + "0" = Third character
    GOSUB RestoreLon                  ; restore Longitude
    GOSUB fpdiv                       ; divide by 2
    Bint = Aint * 2  : GOSUB ItoFB    ; put int * 2 in BARG, change back to float
    GOSUB RestoreLon                  ; restore original Longitude
    GOSUB fpsub                       ; subtract A - B
    Bint = 12 : GOSUB ItoFB           ; Multiply * 12
    GOSUB fpmul
    MH(4) = "a" + Aint                ; + "a" = Fifth Character
    ;----[convert Latitude Sexagesimal to Decimal Degrees]--------------------------
    Aint = LatMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    Bint = LatMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    GOSUB fpdiv
    Bint = LatDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LatDir = "S" THEN              ; if south of equator
        GOSUB AtoB
        GOSUB fpsub
    Bint = 90  : GOSUB ItoFB          ; add 90
    GOSUB fpadd
    ;----[Have Latitude  in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Latitude for later
    Bint = 10   : GOSUB ItoFB         ; Lat / 10
    GOSUB fpdiv
    GOSUB FtoIA
    MH(1) = "A" + Aint                ; + "A" = Second character
                                      ; -- do  Lat // 10 --- (modulus)
    GOSUB RestoreAARG                 ; restore Lat / 10 to AARG
    Bint = 10                         ; multiply times original divisor (10)
    GOSUB ItoFB
    GOSUB FtoIA
    MH(3) = "0" + Aint                ; + "0" = Fourth character
    GOSUB RestoreLon                  ; restore original Latitude
    Bint = Aint : GOSUB ItoFB         ; put int in BARG, change back to float
    Bint = 24 : GOSUB ItoFB           ; Multiply * 24
    GOSUB fpmul
    MH(5) = "a" + Aint                ; + "a" = Sixth character
    ;----[Maidenhead conversion complete]-------------------------------------------
    Aexp_Copy    VAR BYTE
    AARGB0_Copy  VAR BYTE
    AARGB1_Copy  VAR BYTE
    AARGB2_Copy  VAR BYTE
    Aexp_Lon     VAR BYTE
    AARGB0_Lon   VAR BYTE
    AARGB1_Lon   VAR BYTE
    AARGB2_Lon   VAR BYTE
    SaveAARG:
        Aexp_Copy = Aexp
        AARGB0_Copy = AARGB0
        AARGB1_Copy = AARGB1
        AARGB2_Copy = AARGB2
    RestoreAARG:
        Aexp = Aexp_Copy
        AARGB0 = AARGB0_Copy
        AARGB1 = AARGB1_Copy
        AARGB2 = AARGB2_Copy
    AtoB:
        Bexp = Aexp
        BARGB0 = AARGB0
        BARGB1 = AARGB1
        BARGB2 = AARGB2
    SaveLon:
        Aexp_Lon = Aexp
        AARGB0_Lon = AARGB0
        AARGB1_Lon = AARGB1
        AARGB2_Lon = AARGB2
    RestoreLon:
        Aexp = Aexp_Lon
        AARGB0 = AARGB0_Lon
        AARGB1 = AARGB1_Lon
        AARGB2 = AARGB2_Lon
    January:
    LCDOut $fe,$80,DEC2 d," Jan ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    February:
    LCDOut $fe,$80,DEC2 d," Feb ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    March:
    LCDOut $fe,$80,DEC2 d," Mar ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    April:
    LCDOut $fe,$80,DEC2 d," Apr ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    May:
    LCDOut $fe,$80,DEC2 d," May ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    June:
    LCDOut $fe,$80,DEC2 d," Jun ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    July:
    LCDOut $fe,$80,DEC2 d," Jul ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    August:
    LCDOut $fe,$80,DEC2 d," Aug ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    September:
    LCDOut $fe,$80,DEC2 d," Sep ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    October:
    LCDOut $fe,$80,DEC2 d," Oct ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    November:
    LCDOut $fe,$80,DEC2 d," Nov ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    December:
    LCDOut $fe,$80,DEC2 d," Dec ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    Clock:                     ;Display time
        nDig=hh dig 1 : nPos=1 : gosub displaydigit
        nDig=hh dig 0 : nPos=2 : gosub displaydigit
          npos=3 : gosub colon
        ndig=mm dig 1 : npos=4 : gosub displaydigit
        ndig=mm dig 0 : npos=5 : gosub displaydigit
          npos=6 : gosub colon
        ndig=ss dig 1 : npos=7 : gosub displaydigit
        ndig=ss dig 0 : npos=8 : gosub displaydigit
    LCDOut $fe,$80+9,"  ",DEC2 d,"-",DEC2 m,"-",DEC2 y
    LCDOut $fe,$c0+9,"    ",#volt, ".", # voltd1,# voltd2,"v"
    LCDOUT $fe,$94,"   G8VLQ    ",STR MH\6
    LCDOut $fe,$d4,DEC2 latdeg,$DF,DEC2 latmin,"'",DEC2 latsecs,NS," ",DEC2 londeg,$DF,DEC2 lonmin,"'",DEC2 lonsecs,EW                           ; ,#volt, ".", # voltd1,# voltd2,"v"   ; d4 4th line
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub one
    if ndig=2 then gosub two
    if ndig=3 then gosub three
    if ndig=4 then gosub four
    if ndig=5 then gosub five
    if ndig=6 then gosub six
    if ndig=7 then gosub seven
    if ndig=8 then gosub eight
    if ndig=9 then gosub nine
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    colon:
        lcdout $fe,$80+nPos,$A5
        lcdout $FE,$C0+nPos,$2E
    Rob.
    WooHoo!! That's Beeeeauuuutiful Rob!
    I'm so glad to see it working.
    I do have some suggestions for you about the configs, Months, volts ...
    When your ready to work on it some more.
    P.S. Nice picture of yourself too.
    Dec 2011
    IO93ok
    Glad you like it Darrel. I'm very pleased with it. Any ideas very welcome.
    I have also coded a full digit clock over the four lines. At the moment it's a standalone code due to the character loading. Is it possible to load the second set of characters, replacing the original, on a button push ? Maybe using EXT ?
    The idea was to have dual display, button push changes from that shown in pic to a full clock and back again on another push.
    Rob.
    Yes, you can have as many custom character sets as you want.
    But only one set can be loaded at a time.
    In your last code, the configs you have aren't doing anything.
    They should look like this ... make sure the defaults are commented out in the 16F876A.inc file in your PBP folder.
    @  __config  _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    And how's this look for the Months ...
    DateTime:
        LCDOut $fe,$80,DEC2 d," "
        GOSUB ShowMonth
        LCDOut " ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    ShowMonth:
        Idx = (m - 1) * 3
        FOR X = Idx TO Idx + 2
            LOOKUP X,["JANFEBMARAPRMAYJUNJULAUGSEPOCTNOVDEC"],Char
            LCDOUT Char
        NEXT X
    Dec 2011
    IO93ok
    Hmm, I've always had problems with configs.
    A single line config errors out. Multiple lines actually works and sets my programmer fuses OK.
    I also have severe problems with Mpasmwin 5.20 giving hundreds of errors with PBP which I now just ignore.
    I like the Months code. That's one of the things I just couldn't get right but I was thinking that way.
    How would I go about loading the character set ? I just don't get it.
    The brain is full of different ideas for the project, so many options. Even thought of two lcds.
    Rob.
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 17:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 08:44
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 12:54
