WooHoo!! That's Beeeeauuuutiful Rob!
I'm so glad to see it working.
I do have some suggestions for you about the configs, Months, volts ...
When your ready to work on it some more.
P.S. Nice picture of yourself too.![]()
Glad you like it Darrel. I'm very pleased with it. Any ideas very welcome.
I have also coded a full digit clock over the four lines. At the moment it's a standalone code due to the character loading. Is it possible to load the second set of characters, replacing the original, on a button push ? Maybe using EXT ?
The idea was to have dual display, button push changes from that shown in pic to a full clock and back again on another push.
Rob.
The moment after you press "Post" is the moment you actually see the typso
Yes, you can have as many custom character sets as you want.
But only one set can be loaded at a time.
In your last code, the configs you have aren't doing anything.
They should look like this ... make sure the defaults are commented out in the 16F876A.inc file in your PBP folder.
And how's this look for the Months ...Code:@ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
Code:DateTime: LCDOut $fe,$80,DEC2 d," " GOSUB ShowMonth LCDOut " ",DEC2 y," ",DEC2 hh,":",DEC2 mm,":",DEC2 ss RETURN ShowMonth: Idx = (m - 1) * 3 FOR X = Idx TO Idx + 2 LOOKUP X,["JANFEBMARAPRMAYJUNJULAUGSEPOCTNOVDEC"],Char LCDOUT Char NEXT X RETURN
Hmm, I've always had problems with configs.
A single line config errors out. Multiple lines actually works and sets my programmer fuses OK.
I also have severe problems with Mpasmwin 5.20 giving hundreds of errors with PBP which I now just ignore.
I like the Months code. That's one of the things I just couldn't get right but I was thinking that way.
How would I go about loading the character set ? I just don't get it.
The brain is full of different ideas for the project, so many options. Even thought of two lcds.![]()
Rob.
Originally Posted by tasmod
Those lines are not configuration statements.Code:@__config_HS_OSC @__config_BOD_OFF @__config_PWRT_ON @__config_WDT_ON @__config_PROTECT_OFF @__config_LVP_OFF
They are actually assembly language labels. You could use an asm GOTO to jump to any one of them.
They will not set the configuration bits in your programmer.
If the one line __config I gave you gives an error, it's probably the "Overwriting address 2007" error that means you didn't comment the default configs in the .inc file.
Very bad idea.I also have severe problems with Mpasmwin 5.20 giving hundreds of errors with PBP which I now just ignore.
You should track down every error and fix it.
How would you know if there are real errors if you always just ignore them.
If you don't know what they mean ... get help.
These lines from your code load the custom charactersHow would I go about loading the character set ? I just don't get it.You'll have another set of similar lines for your 4-line big digits.Code:LCDOUT $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03 ' Cust Char #0 'LCDOUT $FE,$40,$02,$02,$02,$02,$02,$02,$02,$02 ' Cust Char #0 LCDOUT $FE,$48,$1F,$1F,$1B,$1B,$1B,$1B,$1B,$1B ' Cust Char #1 LCDOUT $FE,$50,$1F,$1F,$18,$18,$18,$18,$1F,$1F ' Cust Char #2 LCDOUT $FE,$58,$03,$03,$03,$03,$03,$03,$1F,$1F ' Cust Char #3 LCDOUT $FE,$60,$1F,$1F,$1B,$1B,$1B,$1B,$1F,$1F ' Cust Char #4 LCDOUT $FE,$68,$1B,$1B,$1B,$1B,$1B,$1B,$1F,$1F ' Cust Char #5 LCDOUT $FE,$70,$1F,$1F,$03,$03,$03,$03,$1F,$1F ' Cust Char #6 LCDOUT $FE,$78,$1F,$1F,$03,$03,$03,$03,$03,$03 ' Cust Char #7 LCDOUT $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03 ' Cust Char #8
Executing those lines will overwrite the customs characters you previously loaded.
However, you can only have 8 custom characters at a time, and you have 9 listed above.
The one commented as Cust Char #8, is actually Cust Char #0 and will overwrite the first Cust Char #0. Good thing they're the same.
Hi Darrel,
Many thanks for your help.
The code I posted was the last working example on this PC connected to the net. The actual programming pc is in another room and not net connected (deliberately). There were a couple of errors, the second $40 character set was one and a missing RETURN was another.
The Month routine was deliberately moved down from the GPS loop. Since the post I moved it into the loop and reformatted the display lines to suit the new layout. I will however look at the array solution now.
I've always had problems with Mpasmwin and errors. For instance the code posted has 891 errors at assembly, all of which relate to standard PBP instructions. e.g. LCDOUT alone is an error, FOR is an error etc. etc.
This is a sample around your Locator code :-
I will re-install 5.20 and see if it cures it. I'm sure years back I didn't have the problem.Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1049 : Illegal opcode (_LatDir)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1052 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1052 : Illegal opcode (_AtoB)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1058 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1058 : Illegal opcode (_itofa)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1061 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1061 : Illegal opcode (_fpsub)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1064 : Found label after column 1. (LABEL?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1064 : Illegal opcode (L00042)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1070 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1070 : Illegal opcode (_itofb)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1073 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1073 : Illegal opcode (_fpadd)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1076 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1076 : Illegal opcode (_SaveLon)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1082 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1082 : Illegal opcode (_itofb)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1085 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1085 : Illegal opcode (_fpdiv)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1088 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1088 : Illegal opcode (_SaveAARG)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1091 : Found label after column 1. (GOSUB?L)
Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1091 : Illegal opcode (_ftoia)
Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1094 : Found label after column 1. (ADD?CWB)
Error[108] C:\FPOINT\NMEA16F876ABIG.ASM 1094 : Illegal character (0)
Rob.
SOLVED. Wrong MPASM Suite.
I'm using PBP2.50 and at some point I must have upgraded the MPASM Suite to 8.90.
I needed to delete and re-install 8.15 instead.
I now get a complete compile and assemble without any errors.![]()
Just needed to think quietly about the problem.
Rob.
