Control a Radio PLL with a PIC
Results 1 to 40 of 54
    Default Re: Control a Radio PLL with a PIC
    Quote Originally Posted by RayL113 View Post
    I'm trying to assign 4 pins from PORTA as the CHSEL f/register as follows;
    CHSEL = PORTA.1.2.3.4
    Get this error;
    C:\PBP\PLL-CPU.BAS ERROR Line 24: Bad variable modifier: .1.2.3.4
    I've tried different variations on this (1-4) (1234) etc. but with the same results.
    What is the correct syntax for doing this? I only want to use these 4 pins.
    You need to use BitWise masks for that
    chsel = (PORTA>>1) & $0F
    you'll need to use that line each time you want to read from PORTA.
    Jun 2011
    Thanks Steve.
    But what is this doing? I mean is it assigning pins 1 thru 4 to the CHSEL label?
    And "Bitwise Mask". I don't see that in the manual. What does it mean?
    There's got to be an easier way to do this than having to insert that line every time.
    What is the best way to assign input pins to a register in PBP?
    For that matter, how do you assign anything to a register in PBP. Can't find that in the manual either!
    CHSEL VAR PORTA
    This will assign the whole PORTA, all the time to chsel variable... it's a simple alias. Still, it's the WHOLE PORTA reading, you still need to remove the bit you don't want/need.
    If you want to assign a single pin to a variable
    A_SINGLE_PIN VAR PORTA.0
    As far as I'm aware of, there's no shortcuts. Bitwise & Logical mask/operations are indeed listed in the manual, not explained as it's a basic knowledge you should already be aware of when programming. Case not, there's Wikipedia & Google
    http://en.wikipedia.org/wiki/Bitwise_operation
    http://www.ralphb.net/IPSubnet/logical.html
    and so forth
    chsel var byte
    this read PORTA, shift the whole value one place to the right (to remove PORTA.0), then isolate the 4 lower bits.
    Jun 2011
    chsel var byte
    Ok, so let's say then, that I don't use the lsb as the toggle pin, and use 0 thru 3 as my 4 input bits, would the command be chsel = (PORTA) %00001111 ??
    Or am I missing the point?
    Really close
    chsel = PORTA & %00001111
    you're on the right direction!
    Jun 2011
    Really close
    Thanks! I'll give that a try.
