Control a Radio PLL with a PIC
Results 1 to 40 of 54
    Default Re: Control a Radio PLL with a PIC
    Yes, var= variable
    bit is one of the placeholders in the larger variable, example
    say you want a variable to hold a value as a flag for an event, you could make a bit variable, called . . . FLAGBIT this way FLAGBIT VAR BIT
    or you might need several flag bits and do it this way
    FLAGBIT VAR BYTE which gives you an 8 bit byte full of FLAGBITS as follows
    FLAGBIT.0 lowest bit in the byte
    FLAGBIT.1 second bit in the byte
    FLAGBIT.2 third " " " "
    FLAGBIT.3 . . .
    FLAGBIT.4 . . . all the way to FLAGBIT.7 , FLAGBIT.7 being the highest order bit in the byte variable
    which is to say you can address every bit of your variable individually.
    Byte = %00000000 will hold 0 to 255 in decimal
    word = %00000000 00000000 will hold 0 to 65535 in decimal
    LONG = %00000000 00000000 00000000 00000000 which is 4294967295 but I think (I am not sure of this) only allows 1/2 that much on each side of zero -2147483647 0 2147483647
    Notice the way I have written the binary expression %00000000 this is the appropriate syntax for P Basic Pro, other compilers may use different "punctuation" and you will see "BIG ENDIAN" and LITTLE ENDIAN" usage and all that means is which end of the group of zeros is the least significant bit, the Left or the Right.
    You will see different ways of displaying hex as well, in PBP we use $00 whereas in C you might see something like 0h00
    high likely 0x00
    This may not be it, but the only thing I notice is: you have OSC_HS selected, but you are using an oscillator at 4 mhz. If you are using an oscillator instead of a resonator, this should be set to XT for 4 mhz. If you are using a resonator, did you see the note with the data sheet?
    Note: When using resonators with frequencies
    above 3.5 MHz, the use of HS mode,
    rather than XT mode, is recommended.
    HS mode may be used at any VDD for
    which the controller is rated. If HS is
    selected, it is possible that the gain of the
    oscillator will overdrive the resonator.
    Therefore, a series resistor should be
    placed between the OSC2 pin and the
    resonator. As a good starting point, the
    recommended value of RS is 330Ω.
    http://www.scalerobotics.com
    Rayl113, Also make sure the "PBADEN" bit's are set for Digital on reset. Other wise the port Bb.0 thru B.3 are set as analog after reset....
    EN82fn
    Jun 2011
    Quote Originally Posted by Archangel View Post
    Yes, var= variable
    FLAGBIT.3 . . .
    Thanks that helps alot. Yes I had noticed the % in front of what looked like binary expressions but hadn't noticed the $ in front of hex expressions. Can you still use the "b and h" in PCB? In case I forget and use the asm expression?
    Nope.
    From the manual.
    4.8. Numeric Constants
    PBP allows numeric constants to be defined in the three bases: decimal, binary and hexadecimal. Binary values are defined using the prefix '%' and hexadecimal values using the prefix '$'. Decimal values are the default and require no prefix.
    100 ' Decimal value 100
    %100 ' Binary value for decimal 4
    $100 ' Hexadecimal value for decimal 256
    Jun 2011
    What if I want to use a cb channel switch instead of an encoder? The first four pins have a logical progression of 0000 to 1111. Couldn't I use this like a Gray code encoder? Count increase would equal up and count decrease would equal down. What do you think?
    Aug 2010
    Maryland, USA
    You can use that, you can use the thing you already have, its up to you. They both CAN work. With the CB switch you will only get 16 changes per full revolution. If this is enough then use it. It will prolly still have noisey output so de-bouncing will still be neccessary. Now if you can get this, I have used many, they work really well.
    Let us know how you are getting along on this project. Have you blinked a LED on port A yet?
    -Bert
    Search here . . .
    http://www.mouser.com/Electromechani...ers/_/N-39xfc/
    Seriously Cheap !
    Jun 2011
    I think I'm going to try to use the channel selector approach. Using RE1 thru RE4 as the inputs. I read in the manual that there is a command that will sample the designated pins and store the result in a register of my chosing. The problem I am having trouble sorting out in my head is what should I do when the count goes back to 0000 after 1111 and vice versa. And still have the count continue up or down. Is there some way to like have a loop restart when this limit is reached?
    Just messing with it as time allows. So not much progress. Still learnig the PBP commands and uses. And yes, got LED's blinking like crazy using machine code, but haven't tried it wih PBP yet.
    Thanks for the helps Guys!
    Aug 2010
    Maryland, USA
    well let me say I think its the more complicated way, but hey that makes it more fun. I would guess you will have to read the count on the selector, compare it to the last count, If it is higher, add 1 to the freq, if its less subtract. To cross the zero, you will have 2 choices when at 0 of at $F. from o you will go to 1 or $F, and from $F you will go to 0 or $E. So just check for that when you get to those counts.
    I would think you will have to really spin the selector VERY fast to miss any counts, so I would start with that scheme and see how it works. Don't forget you may need to de-bounce the inputs.
    -Bert
