Control a Radio PLL with a PIC
Results 1 to 40 of 54
    Jun 2011
    Default Re: Control a Radio PLL with a PIC
    Thanks Bert. Should I use the IF...THEN string? Something like this;
    Start
    PEEK CHSEL CHSELVAR
    IF CHSEL = 0000 THEN CHECK0
    IF CHSEL = 1111 THEN CHECK1
    ELSE LOOP
    LOOP
    PEEK CHSEL CHSELVAR
    If CHSEL > CHSELVAR Then UP
    Else
    PEEK CHSEL CHSELVAR
    IF CHSEL < CHSELVAR Then DOWN
    Else
    GOTO Start
    UP
    PLLDATA = PLLDATA +1
    MOVLF PLLDATA PLLDATAOUT
    GOTO Start
    DOWN
    PLLDATA = PLLDATA -1
    GOTO Start
    CHECK0
    IF CHVAR = 0001 THEN UP
    IF CHVAR = 1111 THEN DOWN
    ELSE LOOP
    CHECK1
    IF CHVAR = 0000 THEN UP
    IF CHVAR = 1110 THEN DOWN
    ELSE LOOP
    Of course I didn't include all the defines. Am I on the right track?
    Aug 2010
    Maryland, USA
    Seems like the basic idea. Not sure what language that is but the idea looks about right
    -Bert
    Jun 2011
    Uh Oh. Thought it was PBP. What did I do wrong?
    Aug 2010
    Maryland, USA
    Ray, I stand corrected. I was thinking peek came from a different language, but I see it is a valid pbp command, though according to the book not recommended.
    As for the movelf, well I think that is some ask haunting you. In pbp you would just use
    plldataout =plldata
    So yes I still think that's the basic idea.
    Oh yea, loop is a reserved word in latest release of pbp, so not a good choice for your label.
    -Bert
    Jun 2011
    Yes, I corrected that. Thanks.
    Where do I find the reserved words? Looked through the manual. Couldn't find them.
    Aug 2010
    Maryland, USA
    can't answer that one, I must say I have ony read it here MANY times, so I assume it to be true. I think it might be in the front or the back in a section talking about differences from previous versions or differences from BS2. Not sure.
    -Bert
    Jun 2011
    I'm trying to assign 4 pins from PORTA as the CHSEL f/register as follows;
    CHSEL = PORTA.1.2.3.4
    Get this error;
    C:\PBP\PLL-CPU.BAS ERROR Line 24: Bad variable modifier: .1.2.3.4
    I've tried different variations on this (1-4) (1234) etc. but with the same results.
    What is the correct syntax for doing this? I only want to use these 4 pins.
    Miami, Florida USA
    Quote Originally Posted by RayL113 View Post
    Look in appendix C in your manual.
    http://melabs.com/resources/pbpmanual/
    Anonymous
    Jun 2011
    Thanks, looked right over that.
