Control a Radio PLL with a PIC
Results 1 to 40 of 54
    Jun 2011
    Default Re: Control a Radio PLL with a PIC
    Really close
    chsel = PORTA & %00001111
    you're on the right direction!
    Thanks! I'll give that a try.
    Jun 2011
    That worked! Thanks again.
    Have another little snag.
    It doesn't like my Peek command syntax.
    Get this error; ERROR Line 27: Bad expression.27: Syntax error
    Here is line 27; PEEK CHSEL CHSELVAR 'Line 27, Look at the 4 input pins from the channel selector and put in CHSELVAR
    It appears that I'm not inputting the Peek command correctly. Anyone familiar with this command?
