pic as ps/2 keyboard
Results 1 to 26 of 26
    Default pic as ps/2 keyboard
    hello
    i want change out a ps/2 keyboard with a pic and searched for informations. has anyone links or informations to the clock speed and the data transmission?
    many thanks
    Feb 2004
    Germany
    see:
    here
    and
    here
    regards
    Ralph
    thank you ralph for the reply
    what i'm not sure :
    - i need no external hardware, or?
    - i can realise the software with shiftout?
    Feb 2004
    Germany
    mischl,
    this is probably the link you are after
    regards
    Ralph
    ralph, thanks for the help.
    i've looked for many sites and found asm as well bs examples. i read a lot about protocols and test my own code. because i have several problems and i'm a bit confused my question : has anybody else a piece of code which send at-keyboard commands to pc host?
    if it is only a piece to test, it would me helps a lot
    thanks for a support
    Nov 2004
    Default Ps/2
    I had a PS/2 KB emulator running a few weeks ago. I don't have the code right in front of me, but I wrote it all in PBP.
    You can use the SHIFTOUT command with no problems - just tell shiftout to only send 9 bits instead of 16.
    Don't forget to calculate the parity bit (odd) and tack it on at the end.
    Clock and data both idle high, so make sure you use pullup resistors.
    I'll dig around and see if I can find the code later this afternoon.
    John
  1. PS/2 keyboard emulation
    By CumQuaT in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 05:32
  2. I've made keyboard with pic, but i have a problem.
    By XErTuX in forum mel PIC BASIC Pro
    Last Post: - 8th November 2008, 01:40
  3. Pic to PC AT keyboard caracters
    By sezgin05 in forum General
    Last Post: - 27th March 2007, 11:45
  4. PS/2 mouse and keyboard
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 17:29
    Last Post: - 12th March 2005, 00:14
