Mister_e,
I found some source code in basic stamp, the author claims it works.
Apart from the fact that everything is inverted (he inverts the inputs in his
schematic using transistors) i can't find anything other tahn my code ?
' -----[ Program Description ]----------------------------------------
' This simple program shows how to connect a BASIC Stamp II to the AT
' keyboard port on a PC and to send characters when one of three buttons
' is pressed. Please read KEYBTST.TXT for more information about it's
' limitations and for a simple schematic.
' -----[ Constants ]--------------------------------------------------
datpin      con 0   'Keyboard Data
clkpin      con 1   'Keyboard Clock
btn00       con 2   'Button 0
btn01       con 3   'Button 1
btn02       con 4   'Button 2
' -----[ Variables ]--------------------------------------------------
temp        var B2  'Temp variabel
char        var W2  'Variabel containing the character
breakcode   var W3  'Variabel containing "Breakcode"
extcode     var W4  'Variabel containing "Extended charcode"
' -----[ Initialization ]---------------------------------------------
'Set pin 0 and 1 as outputs, rest as inputs
 Dirl= %00000011
'Set datpin and clkpin default to high (1)
 low datpin
 low clkpin
'Define breakcode
'           s--DATA--PS (s=start, DATA=LSB First, P=parity, S=stop)
 breakcode=%11111000000 '/F0H
'Define extcode
 extcode=%11111100010 '/E0H
' -----[ Main Code ]--------------------------------------------------
start:
temp=0
button btn00,0,255,100,temp,1,button00
button btn01,0,255,100,temp,1,button01
button btn02,0,255,100,temp,1,button02
goto start
' -----[ Test Characters ]--------------------------------------------
'      s--DATA--PS (s=startbit, DATA=LSB First, P=paritybit, S=stopbit)
'char=%10110101110 '/SPACE
'char=%11100011110 '/a
'char=%11010010100 '/CR
'char=%11011001110 '/b
'char=%11100101110 '/t
'char=%10100101100 '/r
'char=%10011101110 '/d
'char=%10101111100 '/F1
'char=%11111000110 '/INS
button00:
'Assign char a character with startbit, parity and stopbit. OBS inverted !
gosub sendchar
goto start
button01:
gosub sendchar
goto start
button02:
'Assigne char a character with startbit, parity and stopbit. OBS inverted !
gosub sendextchar
goto start
' -----[ Subroutines ]------------------------------------------------
sendchar
  'Send character
  shiftout datpin,clkpin,1,[char\11]
  'Send breakcode + character
  shiftout datpin,clkpin,1,[breakcode\11]
sendextchar
  'Send extcode + character
  shiftout datpin,clkpin,1,[extcode\11]
  'Send extcode + breakcode + character
' -----[ End ]--------------------------------------------------------
Best regards, UB
