hello john
thanks for your support.
i work with a similar code. so i have some additional questions :
- which osc speed do you use? - i have a 16f876 with 4M
- have you defined a shift_pauseus? - i try it . around 40us seems best
- how long do you wait until you send the release code (F0) after the button press comand? - i don't wait
- how looks your hardware setup? - 2 transistors at portc with pull up works at best. nod good because i get different chars... when i only take pullups instead the transisitors, after connect the keyboard it wouldn't be initialized.
- what are you doing at the booting from the pc?
best regards
