pic as ps/2 keyboard
Results 1 to 26 of 26
    Apr 2006
    GearSweaterMountain, The Netherlands
    Default Anyone, please ?
    I'm trying to simulate (emulate) a ps/2 keyboard from a pic to laptop's ps/2 port. The PIC (12F509) needs to send a few keystrokes to the laptop.
    Using a part of JEC's code i got it working, but the output (e.g. what i see on my notepad on my laptop screen does not look like the characters i should be seeing, when i look at various scan code tables.
    What am i doing wrong ?
    Here's the code :
    INCLUDE "modedefs.bas"
    DEFINE SHIFT_PAUSEUS 50
    '==== Andere test ! ============================================================
    parity      var word
    sendthis    vaR word
    kbddata     var GPIO.0
    kbdclk      var GPIO.1
    start:
    high kbddata
    high kbdclk
    sendthis = %11010110 'sending this results in a "y" on screen
    gosub calsub
    sendthis = %11110000 'This should be 0xF0 the "release code"
    gosub calsub
    sendthis = %11010110 'For release code
    gosub calsub
    goto start
    calsub
    parity = not(sendthis.0 ^^ sendthis.1 ^^ sendthis.2 ^^ sendthis.3 ^^ sendthis.4 ^^ sendthis.5 ^^ sendthis.6 ^^ sendthis.7)
    sendthis = sendthis << 1 'move over to insert start bit
    sendthis.0 = 1 'start bit 'In JEC's code this was a 0, but that did'nt work
    sendthis.9 = parity
    sendthis.10 = 0 'stop bit 'In JEC's code this was a 1, but that did'nt work
    shiftout kbddata,kbdclk,4,[sendthis\11]
    goto start
    The "y" i got when i was experimenting, other thing i saw was :
    11000111 = 3
    11000110 = DEL
    00010010 = o
    11010110 = y
    00110010 = F4
    11011110 = NUM-LOCK
    11110110 = PAGE-UP
    What is wrong ???
    Best Regards, UB
    parity var word:sendthis var word:kbddata var GPIO.0:kbdclk var GPIO.1
    start:
    high kbddata:high kbdclk:pause 500:sendthis=$d6:gosub calsub:sendthis=$f0
    gosub calsub:sendthis=$d6:gosub calsub:goto start
    calsub:    <---ADD COLON HERE
    parity=not(sendthis.0^^sendthis.1^^sendthis.2^^sendthis.3^^sendthis.4^^sendthis.5^^sendthis.6^^sendthis.7)
    sendthis=sendthis<<1:sendthis.0=1:sendthis.9=parity:sendthis.10=0:shiftout kbddata,kbdclk,4,[sendthis\11]:return
    goto start
    what happen if your change NOT by ~ ?
    Agh! Missed that one! And it was right below my comment!
    Apr 2006
    Thanks mister_e & skimask for replying ...
    I will try the ~ this morning see what happens.
    Thank you !
    Apr 2006
    Hi Mister_e & Skimask,
    I thought i figured it out:
    When googeling if found that the scancode for an "a" = 0x1C = 00011100, the key-scancode has to
    be send LSB first resulting in 00111000.
    sendthis = %00111000 'LSB first "a"
    gosub calsub
    sendthis = %00001111 'LSB first 0xF0 'for release key
    gosub calsub
    gosub calsub
    goto start
    calsub:
        parity = ~(sendthis.0 ^^ sendthis.1 ^^ sendthis.2 ^^ sendthis.3 ^^ sendthis.4 ^^ sendthis.5 ^^ sendthis.6 ^^ sendthis.7)
        sendthis.0 = 0 'start bit
        sendthis.9 = parity
        sendthis.10 = 1 'stop bit
        shiftout kbddata,kbdclk,1,[sendthis\11]
    Then i thought that the problem was the shiftout. I was sure that it had to be LSB first, clock idles high, because the clock is high to low. But a little experiment with setting this to 1 (Shift data out highest bit first. Clock idles low).
    Resulted in a perfect "a" on the laptop sceen !!
    But however, that was about the only character that i could generate, so i think this is not right also.
    Melanie has posted a scancode table, stating that the scancode for an "a" has to be 0x1E
    I can send characters, but they don't match any of the scancodes i input ? What is happening here ?
    Anyone ?
    Best Regards, UB
    Apr 2006
    Update:
    Ok messed up some of the scancode's. I can now send normal characters
    by sending the reversed scancode with shiftout
    For example : if i send 0x15 = 00010101, LSB first = 10101000 = "q" on screen, that's perfect. I tried other codes and they work also.
    There was an error with the parity calculator also, so i skipped that ....
    But now, i want to use Left-shift + q, which, when looking at the scancode
    table this would be 0x12 for left shift, 0x15 for "q", 0xF0 for release, 0x15 for release "q" and 0xF0 and 0x12 for release left shift.
    Doing this results in an F10 being received ??
    Here's the code :
    sendthis = %01001000 'left shift
    test = 1 'parity bit
    gosub calsub
    sendthis = %10101000 'q
    test = 0
    gosub calsub
    sendthis = %00001111 'Release
    test = 1
    gosub calsub
    test = 0
    gosub calsub
    test = 1
    gosub calsub
    test = 1
    gosub calsub
    goto start
    calsub:
        sendthis.9 = test 'parity
    Best regards, UB
  1. PS/2 keyboard emulation
    By CumQuaT in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 05:32
  2. I've made keyboard with pic, but i have a problem.
    By XErTuX in forum mel PIC BASIC Pro
    Last Post: - 8th November 2008, 01:40
  3. Pic to PC AT keyboard caracters
    By sezgin05 in forum General
    Last Post: - 27th March 2007, 11:45
  4. PS/2 mouse and keyboard
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 17:29
