pic as ps/2 keyboard
Results 1 to 26 of 26
    Feb 2004
    Germany
    see:
    here
    and
    here
    regards
    Ralph
    thank you ralph for the reply
    what i'm not sure :
    - i need no external hardware, or?
    - i can realise the software with shiftout?
    Feb 2004
    Germany
    mischl,
    this is probably the link you are after
    regards
    Ralph
    ralph, thanks for the help.
    i've looked for many sites and found asm as well bs examples. i read a lot about protocols and test my own code. because i have several problems and i'm a bit confused my question : has anybody else a piece of code which send at-keyboard commands to pc host?
    if it is only a piece to test, it would me helps a lot
    thanks for a support
    Nov 2004
    Default Ps/2
    I had a PS/2 KB emulator running a few weeks ago. I don't have the code right in front of me, but I wrote it all in PBP.
    You can use the SHIFTOUT command with no problems - just tell shiftout to only send 9 bits instead of 16.
    Don't forget to calculate the parity bit (odd) and tack it on at the end.
    Clock and data both idle high, so make sure you use pullup resistors.
    I'll dig around and see if I can find the code later this afternoon.
    John
    Nov 2004
    Default Found it!
    Here's a code snippet to transmit PS/2 data:
    In this case, dataout is an array of bytes I may want to send to the computer.
    Odd parity is NOT the value of all bits XOR'ed together.
    Good luck!
    John
    for x = 0 to 7
    if dataout[x] <> 0 then
    sendthis = dataout[x]
    parity = not(sendthis.0 ^^ sendthis.1 ^^ sendthis.2 ^^ sendthis.3 ^^ sendthis.4 ^^ sendthis.5 ^^ sendthis.6 ^^ sendthis.7)
    sendthis = sendthis << 1 'move over to insert start bit
    sendthis.0 = 0 'start bit
    sendthis.9 = parity
    sendthis.10 = 1 'stop bit
    shiftout kbddata,kbdclk,4,[sendthis\11]
    dataout[x] = 0
    next x
    hello john
    thanks for your support.
    i work with a similar code. so i have some additional questions :
    - which osc speed do you use? - i have a 16f876 with 4M
    - have you defined a shift_pauseus? - i try it . around 40us seems best
    - how long do you wait until you send the release code (F0) after the button press comand? - i don't wait
    - how looks your hardware setup? - 2 transistors at portc with pull up works at best. nod good because i get different chars... when i only take pullups instead the transisitors, after connect the keyboard it wouldn't be initialized.
    - what are you doing at the booting from the pc?
    best regards
  1. PS/2 keyboard emulation
    By CumQuaT in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 05:32
  2. I've made keyboard with pic, but i have a problem.
    By XErTuX in forum mel PIC BASIC Pro
    Last Post: - 8th November 2008, 01:40
  3. Pic to PC AT keyboard caracters
    By sezgin05 in forum General
    Last Post: - 27th March 2007, 11:45
  4. PS/2 mouse and keyboard
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 17:29
