pic as ps/2 keyboard
Results 1 to 26 of 26
    Apr 2006
    GearSweaterMountain, The Netherlands
    Hi Mister_e & Skimask,
    I thought i figured it out:
    When googeling if found that the scancode for an "a" = 0x1C = 00011100, the key-scancode has to
    be send LSB first resulting in 00111000.
    sendthis = %00111000 'LSB first "a"
    gosub calsub
    sendthis = %00001111 'LSB first 0xF0 'for release key
    gosub calsub
    gosub calsub
    goto start
    calsub:
        parity = ~(sendthis.0 ^^ sendthis.1 ^^ sendthis.2 ^^ sendthis.3 ^^ sendthis.4 ^^ sendthis.5 ^^ sendthis.6 ^^ sendthis.7)
        sendthis = sendthis << 1 'move over to insert start bit
        sendthis.0 = 0 'start bit
        sendthis.9 = parity
        sendthis.10 = 1 'stop bit
        shiftout kbddata,kbdclk,1,[sendthis\11]
    Then i thought that the problem was the shiftout. I was sure that it had to be LSB first, clock idles high, because the clock is high to low. But a little experiment with setting this to 1 (Shift data out highest bit first. Clock idles low).
    Resulted in a perfect "a" on the laptop sceen !!
    But however, that was about the only character that i could generate, so i think this is not right also.
    Melanie has posted a scancode table, stating that the scancode for an "a" has to be 0x1E
    I can send characters, but they don't match any of the scancodes i input ? What is happening here ?
    Anyone ?
    Best Regards, UB
    Apr 2006
    Update:
    Ok messed up some of the scancode's. I can now send normal characters
    by sending the reversed scancode with shiftout
    For example : if i send 0x15 = 00010101, LSB first = 10101000 = "q" on screen, that's perfect. I tried other codes and they work also.
    There was an error with the parity calculator also, so i skipped that ....
    But now, i want to use Left-shift + q, which, when looking at the scancode
    table this would be 0x12 for left shift, 0x15 for "q", 0xF0 for release, 0x15 for release "q" and 0xF0 and 0x12 for release left shift.
    Doing this results in an F10 being received ??
    Here's the code :
    sendthis = %01001000 'left shift
    test = 1 'parity bit
    gosub calsub
    sendthis = %10101000 'q
    test = 0
    gosub calsub
    sendthis = %00001111 'Release
    test = 1
    gosub calsub
    test = 0
    gosub calsub
    test = 1
    gosub calsub
    test = 1
    gosub calsub
    goto start
    calsub:
        sendthis.9 = test 'parity
    Best regards, UB
    not sure but i think you have to send some other code(s) + sendthis as well.
    Apr 2006
    Mister_e,
    I found some source code in basic stamp, the author claims it works.
    Apart from the fact that everything is inverted (he inverts the inputs in his
    schematic using transistors) i can't find anything other tahn my code ?
    ' -----[ Program Description ]----------------------------------------
    ' This simple program shows how to connect a BASIC Stamp II to the AT
    ' keyboard port on a PC and to send characters when one of three buttons
    ' is pressed. Please read KEYBTST.TXT for more information about it's
    ' limitations and for a simple schematic.
    ' -----[ Constants ]--------------------------------------------------
    datpin      con 0   'Keyboard Data
    clkpin      con 1   'Keyboard Clock
    btn00       con 2   'Button 0
    btn01       con 3   'Button 1
    btn02       con 4   'Button 2
    ' -----[ Variables ]--------------------------------------------------
    temp        var B2  'Temp variabel
    char        var W2  'Variabel containing the character
    breakcode   var W3  'Variabel containing "Breakcode"
    extcode     var W4  'Variabel containing "Extended charcode"
    ' -----[ Initialization ]---------------------------------------------
    'Set pin 0 and 1 as outputs, rest as inputs
     Dirl= %00000011
    'Set datpin and clkpin default to high (1)
     low datpin
     low clkpin
    'Define breakcode
    '           s--DATA--PS (s=start, DATA=LSB First, P=parity, S=stop)
     breakcode=%11111000000 '/F0H
    'Define extcode
     extcode=%11111100010 '/E0H
    ' -----[ Main Code ]--------------------------------------------------
    start:
    temp=0
    button btn00,0,255,100,temp,1,button00
    button btn01,0,255,100,temp,1,button01
    button btn02,0,255,100,temp,1,button02
    goto start
    ' -----[ Test Characters ]--------------------------------------------
    '      s--DATA--PS (s=startbit, DATA=LSB First, P=paritybit, S=stopbit)
    'char=%10110101110 '/SPACE
    'char=%11100011110 '/a
    'char=%11010010100 '/CR
    'char=%11011001110 '/b
    'char=%11100101110 '/t
    'char=%10100101100 '/r
    'char=%10011101110 '/d
    'char=%10101111100 '/F1
    'char=%11111000110 '/INS
    button00:
    'Assign char a character with startbit, parity and stopbit. OBS inverted !
    gosub sendchar
    goto start
    button01:
    gosub sendchar
    goto start
    button02:
    'Assigne char a character with startbit, parity and stopbit. OBS inverted !
    gosub sendextchar
    goto start
    ' -----[ Subroutines ]------------------------------------------------
    sendchar
      'Send character
      shiftout datpin,clkpin,1,[char\11]
      'Send breakcode + character
      shiftout datpin,clkpin,1,[breakcode\11]
    sendextchar
      'Send extcode + character
      shiftout datpin,clkpin,1,[extcode\11]
      'Send extcode + breakcode + character
    ' -----[ End ]--------------------------------------------------------
    Best regards, UB
    YEAH as i thought... it's all there... sequence of char, breakcode and extcode. I knew something was missing.
    Apr 2006
    Smile
    Thanks guys, for thinking this over with me ....
    Above code does seem to work !
    Best Regards,
    UB
  1. PS/2 keyboard emulation
    By CumQuaT in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 05:32
  2. I've made keyboard with pic, but i have a problem.
    By XErTuX in forum mel PIC BASIC Pro
    Last Post: - 8th November 2008, 01:40
  3. Pic to PC AT keyboard caracters
    By sezgin05 in forum General
    Last Post: - 27th March 2007, 11:45
  4. PS/2 mouse and keyboard
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 17:29
