Having trouble with SERIN command and MAX6675
Results 1 to 40 of 40
    If you have an O-scope check the data out pin. That will at least let you know if it's responding.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2010
    the O-scope test checked out alright
    Dec 2010
    I just disabled the comparators in the chip but it still won't. I even replaced the thermocouple and the MAX76675 but i get the same response. I have no idea what could be wrong with this. Any ideas?
    Have you tried sending the raw value received 'without modifying it' to your LCD while heating or cooling the part?
    Something like: lcdout $fe, $c0, BIN16 MXtemp
    Does it change when heated?
    Edit: Since you're using the internal osc on this one, place Define OSCCAL_1K 1 in the top section. Not sure it that will fix it, but it will for sure affect timing.
    -Bruce
    tech at rentron.com
    Dec 2010
    I just tried it and there is no change
    What's the 16-bit value shown?
    -Bruce
    tech at rentron.com
    Dec 2010
    0000 0000 0000 0000
    zeros across the board with no change to heat
    Is the thermocouple a K type?
    The code given in the link I gave works.
    Check the hardware. Bad connections or backwards connection on the thermocouple or wrong type will cause problems.
    Did you look at the data output pin on the MAX chip with your O-scope to see if it's changing the value sent?
    If you send 16 clocks, and the data line stays at ground, I would think there's a problem with the MAX IC. If you see transitions on the data line, there's something going on with the PIC side.
    -Bruce
    tech at rentron.com
