Simulator
Results 1 to 32 of 32
Thread: Simulator
    Proteus assumes that anything with a .BAS extension is a PROTON program.
    So use .PBP instead for PicBasic Pro programs.
    Then you need to tell proteus how to compile a PicBasic Pro program... (Note: this assumes you have PBP 2.60A)
    In ISIS, go to the Source > Define Code Generation Tools... menu and click the New button.
    Point it to the c:\pbp\PBPMPLAB.BAT file. It will create a PBPMPLAB "tool".
    Enter the following fields.
    Source Extn: PBP
    Obj. Extn: COF
    Command Line: %1 -ampasmwin -oq -k#
    List File Extn: LST
    Then click OK
    After drawing your circuit with a PIC chip in it ... Save it to a new folder first.
    Then go to Source > Add/Remove Source files...
    Under "Code Generation Tool", drop-down the box and select PBPMPLAB
    Click the New button and either select the .PBP file, or give it a new name and it will create a new file.
    AFTER giving it a Source Code Filename ... enter the PIC's part number in the Flags field -p12F683.
    Then press OK.
    To edit the source code, go to Source menu and select the file you specified previously at the bottom.
    When you try to start the simulation, it will automatically compile the program if you have changed it.
    Or you can select "Source > Build All" and it will compile it even if you haven't changed it.
    If the compile succeeds, it will begin running the simulation.
    If you selected "Build All" it will show the results of the compile process.
    On Sunday I will try to make a video of the process.
    Going Kart racing tomorrow at Unser's in Denver.
    Need some sleep first. And some Advil after ... OK, several Advil.
    France
    Default Proteus simulation
    5h30 AM it is not serious ! hi ..
    Many thanks for your nice explanation, is it great !
    I was obliged to modify the PBPMPLAB.BAT to point on the MPASMWIN (no problem at all)
    I use MPASM version 5.2 (thanks for the explanation about Path installation)
    http://melabs.com/support/mpasm.htm
    Now the last error message I got is in the screen copy (Isis msg)
    (looking for a BLINK.O file ???)
    have a nice week end first
    all the best
    Francois
    Using PBP 2.60A and MPASM v5.36 "O" files are generated. Maybe an MPASM upgrade will help?
    France
    Thumbs down wher to find MPASM V5.36 ?
    You can tell me that I am "outside my shoes"
    I spent half an hour , but I am not able to locate where I can download
    MPASM V5.36 !
    thanks ...
    francois
    MPASM is part of MPLAB.
    The latest version can be found here
    http://www.microchip.com/stellent/id...&part=SW007002
    France
    Default PBP simulation in Proteus ISIS
    Hello
    one week after, same player ...
    With your kind help, I am able to "play" under Isis simulation
    not completly : I can't see my variable "compteur" , I see that it is possible
    to see most of the Internal variables from the Pic itself, but not the declared
    variable coming from the .PBP file
    but it is great (I use an LCD to see the value !)
    I made some update in the wonderfull explanation, may be this will help other
    see the attached file
    I will try no to use the I2C debugger and the Logic analyser under Isis (not a piece of cake !)
    all the best,
    francois
    France
    hello
    May be in this page here is the explanation (PBP and Proteus)
    http://www.labcenter.com/products/crownhill.cfm
    they don't refer to Pic Basic Pro they speak about PROTON products
    nb: just a new for your marketing dpt ; the links to Crownhill are dead !
    but at least it is working.
    Francois
    Mar 2009
    Colorado
    Default Re: Simulator
    Source Extn: PBP
    Obj. Extn: COF
    List File Extn: LST
    Then click OK
    Attachment 4957
    Then press OK.
    Attachment 4958
    Darrel, I am trying to start using Proteus ISIS with simulator. Followed these instructions of yours and when I do a Build ALL I get the following error:
    Processing ..\..\..\PBP26\Ellis_Codes\Temperature\0DisplayLM3 4temp.pbp...
    PBPMPLAB ..\..\..\PBP26\Ellis_Codes\Temperature\0DisplayLM3 4temp.pbp -ampasmwin -oq -k# %1 -ampasmwin -oq -k#
    \Microchip\MPASM was unexpected at this time.
    ERROR: PBPMPLAB.BAT reported error code (255L).
    Build FAILED with 1 error(s).
    Looked at PBPMPLAB.BAT statements and can't figure out what error 255L is telling me. Can you advise??
    Normally, you get those kind of paths when you haven't saved the .DSN yet.
    Each .dsn should be saved in it's own folder, and the source code should be in the same foler.
    Mar 2009
    Colorado
    Double checked that and .dsn file and source code are in the same folder. Still get same errors.
    Maybe I should clarify, I am attempting to use Proteus Lite 6.7 to evaluate whether I want to buy VSM Startup Kit or not. I was under impression that I could simulate running my PBP v2.6A code on an 18F2620 model of CPU with Proteus Lite 6.7....not true?? I do notice that BUILD ALL is only option not grayed out...the Debug options are all grayed out, so maybe that means I can't simulate with Proteus Lite 6.7.
    It's been a few years since I had the Demo version.
    So I installed it on another machine.
    I do not see any example design files that use an 18F2620.
    Which means you would have drawn a new schematic with an 18F2620.
    The demo version does not allow you to save new designs, so I think your "Double checked that" may not have included the "save the file first" part.
    But it won't let you simulate a new design either.
    You can use any of the existing demo designs (without changing the design), and change the .hex file that it executes.
    But most of them are 18F452's, and the designs are limited.
    Mar 2009
    Colorado
    Thanks for that reply, Darrel. I see from your comments now why it wasn't working.
    Since I was running Proteus Lite 6.7 and Labcenter doesn't support it anymore, they sold me the Proteus VSM Starter Design Kit (SDK) for their special price of $125. This will at least let me thoroughly evaluate ISIS for all my schematic work and will also at least let me do some simulations for the three MCUs that the SDK supports. I already have it running and have been running and looking at some of the samples to see how the VSM works. Looks like it may be a big help if I later decide to spend the $ and upgrade to the full 18F version of VSM. Since they credit the $125 towards the 18F version it makes is almost affordable.
    Which Proteus versions do you use? I tend to use 18F version MCUs so I hope that if I do upgrade that the 18F version is all I would need....your opinion as to whether it would be worth it?
    John
  1. PIC10F200 simulator
    By ronsimpson in forum General
    Last Post: - 17th February 2010, 01:41
  2. A java based LCD simulator ..
    By Dennis in forum Schematics
    Last Post: - 18th January 2010, 17:10
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  4. PIC's ports individual bits manipulation - how to?
    Last Post: - 27th February 2007, 23:34
  5. Replies: 3
    Last Post: - 26th November 2006, 22:47
