Simulator
Results 1 to 32 of 32
Thread: Simulator
    France
    Default Proteus simulation
    hello
    As I am not super fluent in english, could you check my affirmations ?
    1/ Isis ask for HEX file, we can't feed the simulator with PBP files ?
    2/ we can see datas from PIC registers (trisa , etc ..) but it is not possible to see the datas from our VARIABLES
    lest say TOTO var BYTE and the big application like TOTO = TOTO + 1 !
    for hardware simulation, it is super nice (voltmeter, oscillo, LED, relays, etc ..) but in my case (sending in serial mode
    21 bits with clock and enable line ... using Three outputs pins from a PIC) is it not so easy to see if everything is OK
    and in front of that, I have some Bitwise operation on the datas line , that why I try to see my TOTO variable !
    that's all folks
    Francois
    for the moment I will continue with my breadboard ...using debug, or LCDOUT or serout ... but normally the PIC
    is a 8 pins ... so I must devellop on a big one first ... that why I try to get a Software simulator.
    best regards,
    If you have PBP 2.60A, then you can use .pbp files directly in Proteus.
    Or you can use Proteus inside of MPLAB with more debugging options.
    With previous version of PBP, you can only simulate the .HEX files.
    France
    Default PIC emulator (after Pic Basic pro compilation)
    OK darrel
    you know everything !
    and we got answer as soon as the enter key is done !
    about this sentence
    "Or you can use Proteus inside of MPLAB with more debugging options."
    Mplab is too complicated for me ... may be I'm too old now "$3E" years old ! hi ...
    best regards,
    francois
    just one question (off topic) what about Mélanie ?
    She is still in the support group ?
    I always appreciated her support way of life.
    France
    Default simulation PBP under ISIS
    hello 23h35
    I spent hours with the big BLINK application (bas and pbp under Pic Basic PRO 2.60A)
    with ISIS version 7.7 SP2 without succes !
    he didn't accept pbp extension
    simulation is working (LED blinking), but I can't see any Basic line to put breakpoint and display my variable (compteur)
    nb: I got this INFO message at start time ! (speaking about PROTON ???)
    here is my big application :
    ' Example program from manual to blink an LED connected to PORTB.3 about once a second
    compteur var byte
    cont: High PORTB.3 ' Turn on LED connected to PORTB.3
    Pause 500 ' Delay for .5 seconds
    Low PORTB.3 ' Turn off LED connected to PORTB.3
    compteur = compteur + 1
    Goto cont ' Go back to loop and blink LED forever
    Proteus assumes that anything with a .BAS extension is a PROTON program.
    So use .PBP instead for PicBasic Pro programs.
    Then you need to tell proteus how to compile a PicBasic Pro program... (Note: this assumes you have PBP 2.60A)
    In ISIS, go to the Source > Define Code Generation Tools... menu and click the New button.
    Point it to the c:\pbp\PBPMPLAB.BAT file. It will create a PBPMPLAB "tool".
    Enter the following fields.
    Source Extn: PBP
    Obj. Extn: COF
    Command Line: %1 -ampasmwin -oq -k#
    List File Extn: LST
    Then click OK
    After drawing your circuit with a PIC chip in it ... Save it to a new folder first.
    Then go to Source > Add/Remove Source files...
    Under "Code Generation Tool", drop-down the box and select PBPMPLAB
    Click the New button and either select the .PBP file, or give it a new name and it will create a new file.
    AFTER giving it a Source Code Filename ... enter the PIC's part number in the Flags field -p12F683.
    Then press OK.
    To edit the source code, go to Source menu and select the file you specified previously at the bottom.
    When you try to start the simulation, it will automatically compile the program if you have changed it.
    Or you can select "Source > Build All" and it will compile it even if you haven't changed it.
    If the compile succeeds, it will begin running the simulation.
    If you selected "Build All" it will show the results of the compile process.
    On Sunday I will try to make a video of the process.
    Going Kart racing tomorrow at Unser's in Denver.
    Need some sleep first. And some Advil after ... OK, several Advil.
    France
    5h30 AM it is not serious ! hi ..
    Many thanks for your nice explanation, is it great !
    I was obliged to modify the PBPMPLAB.BAT to point on the MPASMWIN (no problem at all)
    I use MPASM version 5.2 (thanks for the explanation about Path installation)
    http://melabs.com/support/mpasm.htm
    Now the last error message I got is in the screen copy (Isis msg)
    (looking for a BLINK.O file ???)
    have a nice week end first
    all the best
    Francois
    Using PBP 2.60A and MPASM v5.36 "O" files are generated. Maybe an MPASM upgrade will help?
    France
    Thumbs down wher to find MPASM V5.36 ?
    You can tell me that I am "outside my shoes"
    I spent half an hour , but I am not able to locate where I can download
    MPASM V5.36 !
    thanks ...
    francois
    Mar 2009
    Colorado
    Default Re: Simulator
    Source Extn: PBP
    Obj. Extn: COF
    List File Extn: LST
    Then click OK
    Attachment 4957
    Then press OK.
    Attachment 4958
    Darrel, I am trying to start using Proteus ISIS with simulator. Followed these instructions of yours and when I do a Build ALL I get the following error:
    Processing ..\..\..\PBP26\Ellis_Codes\Temperature\0DisplayLM3 4temp.pbp...
    PBPMPLAB ..\..\..\PBP26\Ellis_Codes\Temperature\0DisplayLM3 4temp.pbp -ampasmwin -oq -k# %1 -ampasmwin -oq -k#
    \Microchip\MPASM was unexpected at this time.
    ERROR: PBPMPLAB.BAT reported error code (255L).
    Build FAILED with 1 error(s).
    Looked at PBPMPLAB.BAT statements and can't figure out what error 255L is telling me. Can you advise??
    Normally, you get those kind of paths when you haven't saved the .DSN yet.
    Each .dsn should be saved in it's own folder, and the source code should be in the same foler.
    Mar 2009
    Colorado
    Double checked that and .dsn file and source code are in the same folder. Still get same errors.
    Maybe I should clarify, I am attempting to use Proteus Lite 6.7 to evaluate whether I want to buy VSM Startup Kit or not. I was under impression that I could simulate running my PBP v2.6A code on an 18F2620 model of CPU with Proteus Lite 6.7....not true?? I do notice that BUILD ALL is only option not grayed out...the Debug options are all grayed out, so maybe that means I can't simulate with Proteus Lite 6.7.
    Mar 2009
    Colorado
    Darrel, I have Proteus VSM SDK working now. However, when I run a simulation in the debug step mode I don't see variables listed in the Variables Window. In checking the VSM help files it says that most COF files from compilers will support the Variables Window. Does the PBP 2.6C compiler create a COF file that will let Proteus VSM show the variables in the program in the Variables Window??
    John
    Yes, unfortunately the variables don't show when simulating directly in ISIS.
    But if you run Proteus as a debugger in MPLAB 8 the watch window will show the variables.
    MPLAB uses the same .cof file, so it's not currently known why they work in MPLAB and not ISIS.
    Since you can have as many serial lcd's or virtual terminals as you want, it easier to just put a few statements in your program to spit out the variables at key points.
    I don't really miss the variable window too much.
    Sep 2010
    Las Vegas, NV
    Boss says we might have some extra money and I'd like to order simulation software and an upgrade to PBP3.0.
    Do you still recommend Proteus/ISIS when using PBP 3.0?
    Thanks for your time.
    It's not very often that you won't see Proteus running on my computer.
    It works great with PBP3.
    I highly recommend getting the ARES (PCB layout) package with it.
    I used to hate laying out PCB's, but it's almost enjoyable now.
    Draw it, simulate it, lay it out, export gerbers, and order your proto's all in the same day.
  1. PIC10F200 simulator
    By ronsimpson in forum General
    Last Post: - 17th February 2010, 01:41
  2. A java based LCD simulator ..
    By Dennis in forum Schematics
    Last Post: - 18th January 2010, 17:10
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  4. PIC's ports individual bits manipulation - how to?
    Last Post: - 27th February 2007, 23:34
  5. Replies: 3
    Last Post: - 26th November 2006, 22:47
