Could you try those lines ???
@ Errorlevel -306
' PIC Defines
'Config bits
@ __CONFIG _CONFIG1H, _IESO_OFF_1H & _FSCM_OFF_1H & _INTIO2_OSC_1H
@ __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_27_2L
@ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_32K_2H
@ __CONFIG _CONFIG3H, _MCLRE_OFF_3H
@ __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVR_OFF_4L
@ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
@ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
@ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
@ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
@ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
@ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
' Include "modedefs.bas" ' Include serial modes
' DEFINE OSC 8 '8Mhz clock used. Note - Set PIC config fuses on programmer to use Internal RC OSC
' Define some constants if needed
' Initialise Processor - check for each PIC type
ADCON1 = %11111111 'Turn off all AD's
OSCCON = %01100111 'set INTRC to 4 MHZ <<< I Think the error was here : define directly bits without ANY ORing ...
' OSCCON = %01110111 'set INTRC to 8 MHZ
' OSCTUNE = 0 'OSC trim set to Null
and comment your configs ... ( I cut and pasted from an old 1320 program of mine ... as you see I never believe in defaults !!! )
your OSCCON settings ... mmmhhhh, how to say, ... I do not like them !!!!
