'DEFINE OSC 8' seems to be ignored by PBP ?
Results 1 to 19 of 19
    Must be those new fangled configs
    Sounds like you may have an @ someplace where it should not be.
    Oh, and see post 2
    Nov 2008
    OK, here is my code warts and all, please excuse any spelling errors etc as this is a work in progress.
    In this form the code compiles and runs fine, but if I un-remark the DEFINE OSC 8 line I get that compile error. At the moment I'm running at 4Mhz on the PIC.
    'MR.SNEEZY - test code for FrSky using Bosch BMP085 baro sensor.
    'This version is for PIC 18F1220
    'ADD/Do
    'NOTES -
    'LAST ACTION - scratch my head...
    'PIC 18F1220 port/pin alocations
    'PortA.0/Pin 1 = Serial TX
    'PortA.1/Pin 2 = LED
    'PortB.0/Pin 8 = I2C SCL clock
    'PortB.1/Pin 9 = I2C SDA data
    ' PIC Defines
     'Config bits
    'Config1H register
    @ CONFIG OSC=INTIO2
        ' Oscillator switch OFF
    'Config2L register
    @ CONFIG BOR=ON, PWRT=ON, BORV=27
        ' Brown out reset ON @ 2.7Volts
        ' Power-up timer ON
    'Config2H register
    @ CONFIG WDT=ON
        ' Watch dog timer ON
    'Config3H register
    @ CONFIG MCLRE=OFF
        'Reset pin disabled
    'Config4L register
    @ CONFIG STVR=ON, LVP=OFF, DEBUG=OFF
        ' Stack over/underflow ON
        ' Low Voltage programming OFF
        ' Background debugger OFF
    '    Include "modedefs.bas"          ' Include serial modes
    '   DEFINE OSC 8 '8Mhz clock used. Note - Set PIC config fuses on programmer to use Internal RC OSC
    ' Define some constants if needed
    ' Software Defines (variables and pins)
        Cal_table   var word[11]         '11 word array to store calibration data
        lUpres      var long
        lTemp_Var   var Long
        Temp_Var    var byte             'temp variable
        Temp_Var2   var Word	         'temp variable
        Temp_Var3   var word             'temp variable
        UTemp       var word             'uncompensated temp reading
        UPres       var word             'uncompensated pressure reading
        i2c_Reg     var Byte             'variable for target i2c register address
        CPIN        var     PortB.0       ' I2C clock pin
        DPIN        var     PortB.1       ' I2C data pin
        SO          Var     PortA.0        'Serial out pin
        LED         var     PortA.1        'Indicator LED, via 500ohm to +3.3V
    'Alias's for calibration data in the sensor to match the Bosch parameter list names
        AC1     var     Cal_table[0]      '
        AC2     var     Cal_table[1]     'BMP085 has 11 16bit values stored in EEPROM
        AC3     var     Cal_table[2]     'First byte is at $AA last at $BF, two bytes per cal value
        AC4     var     Cal_table[3]     'Lowbyte is MSB (e.g $AA), Highbyte is LSB (e.g. $AB)
        AC5     var     Cal_table[4]     'some values are signed (not AC4, AC5, AC6)
        AC6     var     Cal_table[5]
        B1      var     Cal_table[6]
        B2      var     Cal_table[7]
        MB      var     Cal_table[8]
        MC      var     Cal_table[9]
        MD      var     Cal_table[10]
    ' Initialise Processor - check for each PIC type
        ADCON1 = %11111111              'Turn off all AD's
        OSCCON = OSCCON | %01100000     'set INTRC to 4 MHZ
    '    OSCCON = OSCCON | %01110000     'set INTRC to 8 MHZ
    '    OSCTUNE = 0                      'OSC trim set to Null
    ' Set initial state of port pins as Input or Output
        TRISA = %11111100    'Input(0 = output, 1 = Input)
        TRISB = %11111100    '
    ' PIC initialization code
            Low So      'Must start low, or you get rubbish on the LCD at PIC boot up.
            Low LED     'LED on
            pause 5000  'led on for x seconds
            High LED    'LED off
            Serout2 SO,16780,[$FE,$01]               ' Clear LCD & home LCD cursor.
            pause 10                                ' wait for LCD to catch up
            Serout2 SO,16780,["   FrSky Vario    "]  ' Serial print
            Serout2 SO,16780,[$FE,$C0]               ' Shift cursor to line2
            Serout2 SO,16780,[" Development Jig  "]  ' Serial print
            Pause 3000                               'wait three seconds
            i2c_Reg =$AA                            'Start address of the BMP085 calibration data
            I2CREAD DPIN,CPIN,$EF,I2C_REG,[STR Cal_table\11],cal_error  'Read 11 reversed words out of sensor
            AC1 = (AC1.lowbyte<<8) + AC1.highbyte   'swap MSB and LSB of each to use in PBP (un-reverse then)
            AC2 = (AC2.lowbyte<<8) + AC2.highbyte   'device stores the MSB in the Low byte, LSB in the High byte
            AC3 = (AC3.lowbyte<<8) + AC3.highbyte
            AC4 = (AC4.lowbyte<<8) + AC4.highbyte
            AC5 = (AC5.lowbyte<<8) + AC5.highbyte
            AC6 = (AC6.lowbyte<<8) + AC6.highbyte
            B1 = (B1.lowbyte<<8) + B1.highbyte
            B2 = (B2.lowbyte<<8) + B2.highbyte
            MB = (MB.lowbyte<<8) + MB.highbyte
            MC = (MC.lowbyte<<8) + MC.highbyte
            MD = (MD.lowbyte<<8) + MD.highbyte
            Pause 10                              ' wait for LCD to catch up
    'Main loop -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
            Serout2 SO,16780,[$FE,$02]             'home LCD cursor.
            Gosub Read_temp
            lTemp_var = 0
            For Temp_var = 0 to 9
            Gosub Read_pres
            lTemp_var = ltemp_var + lUpres
            Next Temp_var
            lUpres = lTemp_Var / 10
            Serout2 SO,16780,["UT=",DEC utemp," "]       'Send Word size number to LCD
            Serout2 SO,16780,["UP=",DEC lupres," "]      'Send Word size number to LCD
    'lets see whats in the cal data array for a checking math in Excel - Rem out Utemp and lUpres above
    '        Serout2 SO,16780,[$FE,$2]               ' Shift cursor to line_1 (128+addr) Note-Rem out Utemp and lUpres above
    '        Serout2 SO,16780,[SDEC AC1," ",SDEC AC2," ",SDEC AC3]   'display three signed cal values
            Serout2 SO,16780,[$FE,$C0]               ' Shift cursor to line_2
            Serout2 SO,16780,[DEC AC4," ",DEC AC5," ",DEC AC6]   'display three unsigned cal values
            Serout2 SO,16780,[$FE,$94]               ' Shift cursor to line_3
            Serout2 SO,16780,[SDEC B1," ",SDEC B2]   'display two signed cal values
            Serout2 SO,16780,[$FE,$D4]               ' Shift cursor to line_4
            Serout2 SO,16780,[SDEC MB," ",SDEC MC," ",SDEC MD]  'display three signed cal values
     '        pause 100
            Toggle LED
            Goto main
    'SUBROUTINES -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
    Read_pres:
            i2c_Reg = $F4                         '$F4 is the control register address
            I2CWRITE DPIN,CPIN,$EE,I2C_REG,[$F4]  ' Write $34+(oss << 6) to set pressure conversion
            Pause 30                              ' Delay 10ms after each write (30mS for HiRes results (oss=3))
            i2c_Reg = $F6                         '$F6 is the result register MSB
            I2CREAD DPIN,CPIN,$EF,I2C_REG,[lUpres],I2C_error  'Read pressure MSB, LSB, XLSB, $F9(not needed).
            lUpres = lUpres >> 13                 'remove result from $F9 (>>8) + left shift result back to 19bits (>>5)
                                                  'it's because PBP reads four bytes if [Var] is a long...
            return                                'we only want top 19bits of the result.
    Read_temp:
            I2CWRITE DPIN,CPIN,$EE,I2C_REG,[$2E]  ' Write $2E to set temperature conversion
            Pause 10                              ' Delay 10ms after each write
            I2CREAD DPIN,CPIN,$EF,I2C_REG,[Utemp],I2C_error  'Read temperature MSB, LSB.
    I2C_error:
            Serout2 SO,16780,["i2c bus read error"]       '
            pause 2000
            Toggle LED
            Goto main
    Cal_error:
            Pause 10
            Serout2 SO,16780,["i2c cal read error "]       '
    I'll probably cross post this code on the BMP085 thread tomorrow when I go down the hill (literally) and prove if my pressure reading agrees with my GPS altitude.
    I do not see where the problem is. So I must be missing something too.
    I am concerned about the note stating something about setting the OSC config in the programmer. Seems like that gives a lot of folks trouble. Can you shut that part down? It is not needed.
    Could you try those lines ???
    @ Errorlevel -306
    ' PIC Defines
     'Config bits
    @    __CONFIG  _CONFIG1H, _IESO_OFF_1H & _FSCM_OFF_1H & _INTIO2_OSC_1H
    @    __CONFIG  _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_27_2L
    @    __CONFIG  _CONFIG2H, _WDT_ON_2H & _WDTPS_32K_2H
    @    __CONFIG  _CONFIG3H, _MCLRE_OFF_3H
    @    __CONFIG  _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVR_OFF_4L
    @    __CONFIG  _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    @    __CONFIG  _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @    __CONFIG  _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    @    __CONFIG  _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @    __CONFIG  _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    @    __CONFIG  _CONFIG7H, _EBTRB_OFF_7H
        OSCCON =  %01100111     'set INTRC to 4 MHZ    <<<  I Think the error was here : define directly bits without ANY ORing ...
    '    OSCCON = %01110111     'set INTRC to 8 MHZ
    and comment your configs ... ( I cut and pasted from an old 1320 program of mine ... as you see I never believe in defaults !!! )
    your OSCCON settings ... mmmhhhh, how to say, ... I do not like them !!!!
    Nov 2008
    @ Errorlevel -306
    ' PIC Defines
     'Config bits
    OK, we have success.
    Your @ _Config text compiles with no errors. I also confirmed that my code slowed down as expected if there was a mismatch of DEFINE and OSC settings... All good.
    Your OSCCON works too, but so does mine. Interesting, I read in another forum that the OR'd method was good because it allowed the other bits to not be altered. Maybe I misinterpreted when or why this was good.
    So, anybody understand why the preferred Microchip config method gave me an error ?
    Quote Originally Posted by mr.sneezy View Post
    Like I was telling a friend of mine called ..." Skimask " ... ( coughing sounds around ??? Why ??? )
    "As a pilot, you know it works well and will not try to see if other ways could have been working ...
    may be it is just a very little thing ... but I want to have an in-deep look before telling anything ...
    BTW: do you have any link to this " new config way " ???
    Nov 2008
    Alain, I just read the detailed comments right out of the bottom of the 18F1220.INC out of my late installation of MPASM. It list's the config 'directives' for both methods, but says we should be using the new type syntax...
    Martin
    Nope, I do not understand it but there are lots of things I do not understand. I just know that the new way does not work well for me when I tried it a time or two so I figure why fight it. Use the way that has worked for years.
    Maybe it is something for a later version of MPASM?
    Hi, Dave
    Just found µChip writes :
    @ CONFIG BOR = ON, PWRT = ON, BORV = 27
    With spaces around " = " sign ...
    too weak to give a decent conclusion...
    BTW ... I found a nice tool in the MPLAB Help ... Config values tables for the 18x series !!!
    but none for 10,12 and 16 Series
    Nov 2008
    Sorry, that was a wort, an unused hangover from the last program I wrote. Not needed or done with this PIC. (12F629's were giving trouble...)
