'DEFINE OSC 8' seems to be ignored by PBP ?
Results 1 to 19 of 19
    Nov 2008
    Default 'DEFINE OSC 8' seems to be ignored by PBP ?
    I must have kicked a big black cat recently, my project is going from bug to bug like I've never had before.
    My current minor quirk is that on a PIC 18F1220 I'm finding my Pause statements run at double speed with a 8Mhz internal clock even though I set Define OSC 8 in the top of my code.
    If I set the Internal clock to run at 4Mhz and Define OSC my timing is OK. Leaving the clock source at 4Mhz and setting PBP Define to 8Mhz has no effect on program speed. I'd have expected a pause to go double the time length like that...
    I did an extra test and set Define OSC 16... Nope the pause statement (a LED flash) took the same time as with Define OSC 8 (or 4).
    Is there a condition where things like pause and serial PBP statements don't use the Define OSC X statement ?
    Could you provide your full piece of code ??? ( configs included )
    Sep 2005
    Campbell, CA
    The DEFINES are case-sensitive, and are not checked for syntax by the compiler. If you don't have it typed perfectly, it will be ignored.
    Charles Linquist
    Nov 2008
    Quote Originally Posted by Charles Linquis View Post
    Thanks.
    I changed the case to all upper and I did get a change in the compiler so my lower case must have been a problem.
    I now get an assembler Config directive warning
    Config Directive Error: (setting '8' not found for the processor 18F1220)
    Must be those new fangled configs
    Sounds like you may have an @ someplace where it should not be.
    Oh, and see post 2
    Nov 2008
    OK, here is my code warts and all, please excuse any spelling errors etc as this is a work in progress.
    In this form the code compiles and runs fine, but if I un-remark the DEFINE OSC 8 line I get that compile error. At the moment I'm running at 4Mhz on the PIC.
    'MR.SNEEZY - test code for FrSky using Bosch BMP085 baro sensor.
    'This version is for PIC 18F1220
    'ADD/Do
    'NOTES -
    'LAST ACTION - scratch my head...
    'PIC 18F1220 port/pin alocations
    'PortA.0/Pin 1 = Serial TX
    'PortA.1/Pin 2 = LED
    'PortB.0/Pin 8 = I2C SCL clock
    'PortB.1/Pin 9 = I2C SDA data
    ' PIC Defines
     'Config bits
    'Config1H register
    @ CONFIG OSC=INTIO2
        ' Oscillator switch OFF
    'Config2L register
    @ CONFIG BOR=ON, PWRT=ON, BORV=27
        ' Brown out reset ON @ 2.7Volts
        ' Power-up timer ON
    'Config2H register
    @ CONFIG WDT=ON
        ' Watch dog timer ON
    'Config3H register
    @ CONFIG MCLRE=OFF
        'Reset pin disabled
    'Config4L register
    @ CONFIG STVR=ON, LVP=OFF, DEBUG=OFF
        ' Stack over/underflow ON
        ' Low Voltage programming OFF
        ' Background debugger OFF
    '    Include "modedefs.bas"          ' Include serial modes
    '   DEFINE OSC 8 '8Mhz clock used. Note - Set PIC config fuses on programmer to use Internal RC OSC
    ' Define some constants if needed
    ' Software Defines (variables and pins)
        Cal_table   var word[11]         '11 word array to store calibration data
        lUpres      var long
        lTemp_Var   var Long
        Temp_Var    var byte             'temp variable
        Temp_Var2   var Word	         'temp variable
        Temp_Var3   var word             'temp variable
        UTemp       var word             'uncompensated temp reading
        UPres       var word             'uncompensated pressure reading
        i2c_Reg     var Byte             'variable for target i2c register address
        CPIN        var     PortB.0       ' I2C clock pin
        DPIN        var     PortB.1       ' I2C data pin
        SO          Var     PortA.0        'Serial out pin
        LED         var     PortA.1        'Indicator LED, via 500ohm to +3.3V
    'Alias's for calibration data in the sensor to match the Bosch parameter list names
        AC1     var     Cal_table[0]      '
        AC2     var     Cal_table[1]     'BMP085 has 11 16bit values stored in EEPROM
        AC3     var     Cal_table[2]     'First byte is at $AA last at $BF, two bytes per cal value
        AC4     var     Cal_table[3]     'Lowbyte is MSB (e.g $AA), Highbyte is LSB (e.g. $AB)
        AC5     var     Cal_table[4]     'some values are signed (not AC4, AC5, AC6)
        AC6     var     Cal_table[5]
        B1      var     Cal_table[6]
        B2      var     Cal_table[7]
        MB      var     Cal_table[8]
        MC      var     Cal_table[9]
        MD      var     Cal_table[10]
    ' Initialise Processor - check for each PIC type
        ADCON1 = %11111111              'Turn off all AD's
        OSCCON = OSCCON | %01100000     'set INTRC to 4 MHZ
    '    OSCCON = OSCCON | %01110000     'set INTRC to 8 MHZ
    '    OSCTUNE = 0                      'OSC trim set to Null
    ' Set initial state of port pins as Input or Output
        TRISA = %11111100    'Input(0 = output, 1 = Input)
        TRISB = %11111100    '
    ' PIC initialization code
            Low So      'Must start low, or you get rubbish on the LCD at PIC boot up.
            Low LED     'LED on
            pause 5000  'led on for x seconds
            High LED    'LED off
            Serout2 SO,16780,[$FE,$01]               ' Clear LCD & home LCD cursor.
            pause 10                                ' wait for LCD to catch up
            Serout2 SO,16780,["   FrSky Vario    "]  ' Serial print
            Serout2 SO,16780,[$FE,$C0]               ' Shift cursor to line2
            Serout2 SO,16780,[" Development Jig  "]  ' Serial print
            Pause 3000                               'wait three seconds
            i2c_Reg =$AA                            'Start address of the BMP085 calibration data
            I2CREAD DPIN,CPIN,$EF,I2C_REG,[STR Cal_table\11],cal_error  'Read 11 reversed words out of sensor
            AC1 = (AC1.lowbyte<<8) + AC1.highbyte   'swap MSB and LSB of each to use in PBP (un-reverse then)
            AC2 = (AC2.lowbyte<<8) + AC2.highbyte   'device stores the MSB in the Low byte, LSB in the High byte
            AC3 = (AC3.lowbyte<<8) + AC3.highbyte
            AC4 = (AC4.lowbyte<<8) + AC4.highbyte
            AC5 = (AC5.lowbyte<<8) + AC5.highbyte
            AC6 = (AC6.lowbyte<<8) + AC6.highbyte
            B1 = (B1.lowbyte<<8) + B1.highbyte
            B2 = (B2.lowbyte<<8) + B2.highbyte
            MB = (MB.lowbyte<<8) + MB.highbyte
            MC = (MC.lowbyte<<8) + MC.highbyte
            MD = (MD.lowbyte<<8) + MD.highbyte
            Pause 10                              ' wait for LCD to catch up
    'Main loop -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
            Serout2 SO,16780,[$FE,$02]             'home LCD cursor.
            Gosub Read_temp
            lTemp_var = 0
            For Temp_var = 0 to 9
            Gosub Read_pres
            lTemp_var = ltemp_var + lUpres
            Next Temp_var
            lUpres = lTemp_Var / 10
            Serout2 SO,16780,["UT=",DEC utemp," "]       'Send Word size number to LCD
            Serout2 SO,16780,["UP=",DEC lupres," "]      'Send Word size number to LCD
    'lets see whats in the cal data array for a checking math in Excel - Rem out Utemp and lUpres above
    '        Serout2 SO,16780,[$FE,$2]               ' Shift cursor to line_1 (128+addr) Note-Rem out Utemp and lUpres above
    '        Serout2 SO,16780,[SDEC AC1," ",SDEC AC2," ",SDEC AC3]   'display three signed cal values
            Serout2 SO,16780,[$FE,$C0]               ' Shift cursor to line_2
            Serout2 SO,16780,[DEC AC4," ",DEC AC5," ",DEC AC6]   'display three unsigned cal values
            Serout2 SO,16780,[$FE,$94]               ' Shift cursor to line_3
            Serout2 SO,16780,[SDEC B1," ",SDEC B2]   'display two signed cal values
            Serout2 SO,16780,[$FE,$D4]               ' Shift cursor to line_4
            Serout2 SO,16780,[SDEC MB," ",SDEC MC," ",SDEC MD]  'display three signed cal values
     '        pause 100
            Toggle LED
            Goto main
    'SUBROUTINES -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
    Read_pres:
            i2c_Reg = $F4                         '$F4 is the control register address
            I2CWRITE DPIN,CPIN,$EE,I2C_REG,[$F4]  ' Write $34+(oss << 6) to set pressure conversion
            Pause 30                              ' Delay 10ms after each write (30mS for HiRes results (oss=3))
            i2c_Reg = $F6                         '$F6 is the result register MSB
            I2CREAD DPIN,CPIN,$EF,I2C_REG,[lUpres],I2C_error  'Read pressure MSB, LSB, XLSB, $F9(not needed).
            lUpres = lUpres >> 13                 'remove result from $F9 (>>8) + left shift result back to 19bits (>>5)
                                                  'it's because PBP reads four bytes if [Var] is a long...
            return                                'we only want top 19bits of the result.
    Read_temp:
            I2CWRITE DPIN,CPIN,$EE,I2C_REG,[$2E]  ' Write $2E to set temperature conversion
            Pause 10                              ' Delay 10ms after each write
            I2CREAD DPIN,CPIN,$EF,I2C_REG,[Utemp],I2C_error  'Read temperature MSB, LSB.
    I2C_error:
            Serout2 SO,16780,["i2c bus read error"]       '
            pause 2000
            Toggle LED
            Goto main
    Cal_error:
            Pause 10
            Serout2 SO,16780,["i2c cal read error "]       '
    I'll probably cross post this code on the BMP085 thread tomorrow when I go down the hill (literally) and prove if my pressure reading agrees with my GPS altitude.
