Learning to walk again. (18F46J50 configuration)
Results 1 to 27 of 27
    California, USA
    WOW! Thanks Steve.
    Now you have me thinking about trying the beast also
    It's a big chunk of data sheet to read for sure. (554 pgs) It's a lot to absorb for someone of my... limited... skill level & experience.
    You won't have any trouble I'm sure Dave.
    I suppose the next step for me is to figure out how to make the USB work...
    steve
    USB is something I have not played with yet. It will be interesting to see how it goes.
    Keep us posted...
    Miami, Florida USA
    This chip seems to be a nice upgrade to the more common USB-capable 18F4550. The 18F46J50 has 64 Kbytes of programming memory compared to 32 Kbytes of the 18F4550.
    Also, the 18F46J50 has a very interesting feature which is "On-Chip USB Transceiver with Crystal-less operation". Which means "High-Precision Internal Oscillator (±0.15% typ.) for USB", so no need for an external crystal oscillator . I will keep this chip in mind for my own projects.
    mackrackit,
    Even a rookie like me got the USB working on a 18F4550, so you shouldn't have any problems. But, I do recommend starting with a 18F4550 chip, which is a lot easier to work with and it is well documented in this forum. The 18F46J50 chip seems to be a lot harder to make it work.
    California, USA
    Only low speed USB (1.5 Mbps) is supported in "crystal-less mode".
    For full speed operation (12 Mbps) you'll need to use an external xtal.
    Still... not bad.
    And it's even got a RTCC calibration register that lets you "fine tune" the oscillator for the RTC.
    steve
    Nice Steve. Where did you get the COG LCD display?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    California, USA
    Digikey.
    Steve likes Digikey.
    http://search.digikey.com/scripts/Dk...0220az&stock=1
    steve
    Thanks.
    I bet Digikey likes Steve too ehh...;o)
    -Bruce
    tech at rentron.com
    Miami, Florida USA
    Quote Originally Posted by Byte_Butcher View Post
    steve
    Steve,
    Were you ever able to make the USB interface work in this 18F46J50 chip? Do you mind sharing your findings with us? I have been thinking about upgrading my 18F4550 to a 18F46J50.
