Learning to walk again. (18F46J50 configuration)
Results 1 to 27 of 27
    California, USA
    Byte_Butcher,
    Ok, I am just curious here. What type of programmer are you using?
    Robert, I''m using the PICkit 2.
    But the melabs programmer is starting to look pretty handy...
    Anyone else have any comments about using the melabs vs PICkit programmers?
    I've got what I think seem like intelligent configuration settings put into my 18F46J50 include file, but I STILL can't get an LED to blink. I don't think the chip is running at all.
    I'll post my code and configs later, after I've fed cats and taken care of some sunday morning chores.
    steve
    Quote Originally Posted by Byte_Butcher View Post
    I have not used the melabs programmers, but over the years here it seems like one of the problems has been with the configs being set via the software. Problem solved by turning that feature of and learning how to set the configs in the *inc or in code space.
    You have a PicKit2, just stick with it.
    California, USA
    Default Too many registers, not enough brain cells...
    OK, all I'm trying to do is flash 2 LEDs on ports B.4 and D.0 of the 18F46J50.
    It's not working. Not only do the LEDs not light, but the chip doesn't even seem to be running. All of the output pins seem to kind of "float" like they were high impedance inputs, and there's NO clock out on RA.6.
    I kind of get the feeling it's not running at all. I DO have 3.26 volts on both Vdd pins, and 2.44 volts on the Vcap pin (internal regulator), so the power is on.
    I'm guessing that there's SOMETHING that I haven't set correctly, but I haven't found it yet.
    Here's my CONFIG goodies. I'm trying to use the internal OSC with an output on RA6 so I can see if the clock is running.
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
    ;;;        LIST p = 18F46J50, r = dec, w = -311, f = inhx32
            INCLUDE "P18F46J50.INC"	; MPASM  Header
    	CONFIG XINST = ON
    	CONFIG STVREN = OFF
    	CONFIG PLLDIV = 2
    	CONFIG WDTEN = OFF
    	CONFIG CP0 = OFF
    	CONFIG CPUDIV = OSC1
    	CONFIG IESO = OFF
    	CONFIG FCMEN = OFF
    	CONFIG LPT1OSC = OFF
    	CONFIG T1DIG = OFF
    	CONFIG OSC = INTOSCO  ;Internal OSC, with output on RA6
    	CONFIG DSBOREN = OFF
    	CONFIG DSWDTEN = OFF
            NOLIST
            LIST
    BLOCK_SIZE	EQU	64
    And here's my program.
    I was hoping that this would set the set the internal OSC to 8MHz, disable all the peripheral stuff, and flash some LEDS on ports B.4 and D.0
    No luck so far.
    'Test program to flash LEDS on PORTB.4 and PORTD.0 of the 18F46J50
    Define OSC 8
    OSCCON = %01111111      'idle enable off, 8MHz clock, primary clock source
    '---PERIPHERAL CONFIGURATION REGISTERS---------------------------
    PPSCON = 0              'PERIPHERAL PIN SELECT INPUT REGISTER 0  --  0 = unlocked, 1 = locked
    '-------INPUT PIN SELECT-----------------------------------------
    RPINR1 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 1   ' SET ALL PERIPHERALS TO A NON-EXISTENT PIN (no peripherals selected on any pin)
    RPINR2 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 2
    RPINR3 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 3
    RPINR4 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 4
    RPINR6 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 6
    RPINR7 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 7
    RPINR8 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 8
    RPINR12 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 12
    RPINR13 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 13
    RPINR16 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 16
    RPINR17 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 17
    RPINR21 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 21
    RPINR22 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 22
    RPINR23 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 23
    RPINR24 = 27             'PERIPHERAL PIN SELECT INPUT REGISTER 24
    '-------OUTPUT PIN SELECT-----------------------------------------
    RPOR0 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 0  'SET ALL OUTPUTS TO THE "NULL" SETTING (no peripherals selected on any pin)
    RPOR1 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 1
    RPOR2 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 2
    RPOR3 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 3
    RPOR4 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 4
    RPOR5 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 5
    RPOR6 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 6
    RPOR7 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 7
    RPOR8 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 8
    RPOR9 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 9
    RPOR10 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 10
    RPOR11 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 11
    RPOR12 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 12
    RPOR13 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 13
    RPOR17 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 17
    RPOR18 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 18
    RPOR19 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 19
    RPOR20 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 20
    RPOR21 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 21
    RPOR22 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 22
    RPOR23 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 23
    RPOR24 = 0               'PERIPHERAL PIN SELECT OUTPUT REGISTER 24
    TRISA = %00000000   'Set PORTA to outputs
    TRISB = %00000000   'Set PORTB to outputs
    TRISC = %00000000   'Set PORTC to outputs
    TRISD = %00000000   'Set PORTD to outputs
    TRISE = %00000000   'Set PORTE to outputs
    '---MAIN ROUTINE-------------------------------
    PORTB.4 = 1
    PORTD.0 = 0
    PORTB.4 = 0
    PORTD.0 = 1
    Does anyone have any clues they could toss my way? In the meantime, I'll go RTFM some MORE in hopes I can make sense of all of those registers eventually...
    steve
    Edit: Err, I had a suggestion, but now I can't seem to get mine to work either. Let me regroup, and I will try to post something helpfull
    May 2007
    Take a look here on how to setup a similar device (ignore the RTCC stuff) http://www.picbasic.co.uk/forum/showthread.php?t=12553
    California, USA
    Default From the "well duh" dept... GOT IT!
    Thanks everyone! I got it.
    Walter sort of put the clue in front of me. I took a look through that USB demo board data sheet, and when I got to the schematic of the thing I suddenly sat up and gave myself a good slap on the forehead! (DOH!)
    I took my soldering iron and stuck a 470 ohm resistor from Vdd to MCLR and now it works!
    I was so freaked out and worried about the huge pile of registers on this chip, that I forgot one of the most basic hardware items.
    LED's are blinking away now. Next job... get my LCD display to say "Hello World".
    Thanks to everyone for your help!
    steve
    California, USA
    Default Still stumbling along, but I've almost got my feet under me... :)
    Wow, there's LOTS of "features" on a 18F46J50, and LOTS of registers and configuration thingies to set!
    And lots of RTFM'ing to be done to get this baby under control!
    Anyway, I've got far enough along to get the RTCC working and display the time to an LCD. Yay!
    Since there seems to be a shortage of info about the 18F46J50 here on the forum so far, I'll post my bit of working code. It's crude I'm sure, but it is functional and maybe it will be a helpful start for someone else.
    This code is enough to set up and turn on the RTCC module, using an external 32.768Khz xtal on the Timer1 Osc, and it displays the time on a 2 x 20 parallel LCD display.
    Here's my code, busted into 2 parts so it'll fit on the forum...
    Part 1: "Setup"
    '18F46J50 test program to turn on the RTCC and display time on a 2x20LCD
    Include "MODEDEFS.BAS"   'Include Shiftin/out modes
    DEFINE LCD_DREG PORTD    'Set LCD Data port
    DEFINE LCD_DBIT 4        'Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTE   'Set LCD Register Select port
    DEFINE LCD_RSBIT 0       'Set LCD Register Select bit
    DEFINE LCD_EREG PORTE    'Set LCD Enable port
    DEFINE LCD_EBIT 2        'Set LCD Enable bit
    DEFINE LCD_BITS 4        'Set LCD bus size (4 or 8 bits)
    Define OSC 8             '8MHz Oscillator
    '---SET UP A BUNCH OF REGISTERS----------
    ADCON0 = 0              'Turn OFF the ADC
    ANCON0 = %11111111      'Analog Port Configuration bits (AN7-AN0) 1 = Digital, 0 = analog
    ANCON1 = %00011111      'Analog Port Configuration bits (AN12-AN8) 1 = Digital, 0 = analog
    PMCONH.7 = 0            'Parallel Master Port Enable = OFF
    PMCONH.2 = 0            'Byte Enable Port Enable = OFF
    PMCONH.1 = 0            'Write Enable Strobe Port Enable = OFF
    PMCONH.0 = 0            'Read/Write Strobe Port Enable = OFF
    PMEH = 0                'PARALLEL PORT ENABLE REGISTER HIGH BYTE = OFF
    PMEL = 0                'PARALLEL PORT ENABLE REGISTER LOW BYTE = OFF
    RTCCFG = %10100100      'RTCC CONFIGURATION REGISTER ... sets up some of the RTCC stuff
    'RTCCAL = %00000000     'RTCC CALIBRATION REGISTER ... 0 = no adjustment
    PADCFG1 = 0             'PAD CONFIGURATION REGISTER
    T1CON = %10001111       '
    RPINR1 = 27              'PERIPHERAL PIN SELECT INPUT REGISTER 1   ' SET ALL PERIPHERALS TO A NON-EXISTANT PIN [27] (no peripherals selected on any pin)
    RPOR17 = 14              'PERIPHERAL PIN SELECT OUTPUT REGISTER 17  'CCP1 routed to RP17 (for the LCD contrast)
     '---ALIAS PINS-------------------------
    RW              var     PORTE.1             'LCD READ/WRITE
    LED1            VAR     PORTB.4             'Blinky thing 1
    LED2            var     PORTD.0             'Blinky thing 2
    LCDcontrast     var     PORTC.6             'HPWM for LCD contrast
    '---ALLOCATE VARIABLES-----------------
    contrast        var     word   'LCD contrast
    timevall        var     word                    'temporary storage for rtcvall
    timevalh        var     word                    'temporary storage for rtcvalh
    weekdaynum      var     word                    'Weekdaynum = 0-6  (0= sunday, 1= monday, etc)
    weekday         var     byte[9]                 'monday, tuesday, wednesday, etc
    year            var     word                    'year = 0 - 99
    month           var     word
    monthname       var     byte[3]                 'jan, feb, mar, etc
    day             var     word
    hours           var     word
    minutes         var     word
    seconds         var     word
    pmflag          var     word
    '---SET SOME VARIABLES-----------------
    RW = 0             'LCD R/W = Write
    led1 = 0           'Turn the LED off
    led2 = 0           'Turn the LED off
    contrast = 200     'Set LCD contrast (0-255) [0 = max contrast, 255 = min]
    end of part1....
