How do I give a radio control car autonomous control
Results 1 to 40 of 191
    Nov 2009
    Fitchburg, Mass
    Default Hello, I am back.
    Mucho frustration.
    I could not get my DPDT mini-relay switches to work. I unwittingly purchased the "latching" kind with two coils. Neither I nor wikipedia know how these work. Today I ordered the same kind that http://letsmakeroborts.com/node/928 used. 5 to 10 days delivery by land.
    I have succeeded in separating the 6volt battery (powers the PICkit, the radio receiver, the steering servo and the proto board) and the 7.2 volt battery (powers the wheels and the electronic speed control). Under radio control the car still runs.
    Next step CCP1 and CCP2 pin outputs to the speed control and the servo.
    Ken
    California, USA
    Mucho frustration.
    Wikipedia? Hmmm. I imagine the manufacturer has a data sheet available for them. Do they have a part #?
    I thought it was 1 if by land, 2 if by sea.
    Must be thinking of something else....
    steve
    Nov 2009
    Fitchburg, Mass
    Default No details from manufacturer
    AXICOM, part of TYCO, has a 15 page .pdf file giving the specs to their P2 V23079 Relay product line. No where does it say how, exactly, a latching relay works. It must be common knowledge except hereabouts.
    I have never coded in BASIC. I know C and C++ and a few (if I could remember them) older languages. Today I wanted to see what is being INCLUDEd when at the beginning a program I see:
    "include 'M16F88x.INC' ; PM header" see below.
    Today my question is about PBP INCLUDE files. (see below example) Where are NOLIST and LIST and ifdef and XALL defined? Not, as far as I can find, in the smallish MicroEngineering Labs PICBASIC PRO Compiler booklet. Is there a more complete spec on the WEB? I assume there exists a well constructed public PBP library. Where do I find "intrc_osc_noclkout" (see below code)? When I was working each company I worked for maintained its own C libraries. Is that the way this world works?
    ;* 16F887.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2009 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 07/02/09 *
    ;* Version : 2.60 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    device pic16F887, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F887, r = dec, w = -302
    INCLUDE "P16F887.INC" ; MPASM Header
    __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    California, USA
    No, the data sheet isn't very specific about how it works. But it appears from this data sheet, that you energize one coil to "latch" the relay on, and enrgize the other coil to release it. Or you can reverse the polarity on a coil to reverse its effect (e.g., one polarity to latch, and reverse polarity to release.
    I think the
    http://relays.tycoelectronics.com/datasheets/p2.pdf
    At the bottom of pg 4, right hand most of the 3 diagrams, (where it says
    "Contacts in reset position. Both coils can be used either as set or reset coils.". I think that bit applies to your relays. You can either energize one coil to "set" the relay and the other coil to "release"..., or you can use one coil and hit it with one polarity to "set", and reverse polarity to release".
    steve
    ;* 16F887.INC *
    ;* Version : 2.60 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    XALL
    NOLIST
    LIST
    NOLIST
    LIST
    Hi Ken,
    Those are assembly language instructions, find them in PIC data sheets.
    Section 15.
    Ken,
    You will also want to look in the C:\Program Files (x86)\Microchip\MPASM Suite for the *.inc file for your chip. That is where you will find all of the config options, near the end of the file.
    To learn a little more about PBP and includes try this.
    Start a new project, leave it blank and compile ( you may have to put the configs in you code space if that is the way you are doing it, but nothing more).
    Looks at the ASM generated. PBP will do all of the setup from the default includes.
    Now add
    INCLUDE "modedefs.bas"
    to your code. Compile again and look at the ASM file.
    Nov 2009
    Fitchburg, Mass
    Default Looks like I've got to do some studying....
    You all posted in the "PBP projects for R/C models" thread code specifically for the 12F675. My PIC is a 16F887.
    I am at a loss to translate from one PIC to the other. My PBP compiler (set up for 16F887) has no idea what to do with GPIO.x references. When I set it for 12F675 it is happy, but the resulting code is useless to my PICkit2.
    Is it my job to read about the 12F675 and try to figure out which register in my 16F887 is equivalent? That would be an excellent homework assignment.
    Ken
    Yup, pretty much your job to pull the data sheet and compare pin/port assingments.
    Even if you found code for the PIC you are using the pin assingments would probably be different from your setup.
    The ADC and other built in hardware things can be confusing from PIC to PIC. So when those kind of things come up we can help you there.
  1. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 19:41
  2. Remote Car Starter Safety
    By CocaColaKid in forum General
    Last Post: - 22nd November 2005, 09:10
