DT_INTS-18 - problem with INT0
Results 1 to 17 of 17
    Q: Isn't it so that INT_Handler execution cannot be interrupted (e.g interrupt in interrupt sequence)?
    If yes, then debounce filtering is not needed, because first falling edge trigger INT_Handler. Ringing is ignored during interrupt execution time.
    Yes, (as long as we're not talking low priority interrupts) but if the switch bounces longer than the time it takes to execute the ISR then it will get triggered again as soon as it leaves the interrupt routine.
    The while-wend loop won't solve the problem either. If the switch bounces, the while-loop may check it at a moment when it's high and then exit the ISR, the switch continues to bounce and trips the interrupt again. The switch probably bounces on release as well so even if the while-loop manages to the job "sometimes" it's likely that once the button is released causing the program to leave the ISR, it will bounce and trip the interrupt again.
    How about trying a bit of hardware, a single capacitor should do it.
    Just post it to be sure that after this modification it will work OK. If it does, then sure the de-bounce is an issue here.
    If not, then we have to look elsewhere, though I doubt.
    Dec 2007
    Finland
    Post
    I fully agree with Henrik. And a small RC-loop would be even better.
    If return from INT_Handler is not critical, then just add
    PAUSE 100 'or some shorter time
    as a last comment in interrupt routine.
    BR,
    -Gusse-
    Dec 2008
    Los Angeles, CA
    Smile
    I am suffering from the worst contact bounce I've ever seen.
    I'm using the INT line on a PCF8574 and thought it latched until the chip was read... false... it latches until it is read OR is returned to it's original state (which offers no help whatsoever in the case of contact bounce!)... and the INTCON2.6 settings to work on rising or falling edges doesn't help either, so simply added a .1uF cap on the INT line right at the CPU to ground, and it 100% debounced the interrupt.
    Sometimes a 10-cent hardware solution is still the best.
    Brussels, Belgium
    Couple of closing comments from me:
    1) didn't seem to make any difference whether I used INTCON.4 = 1 or the @ INT ENABLE
    2) This particular routine when in use needs to have a 1sec exit pause anyway so I just debounced with a pause statement
    All's well that ends well - thanks for pointing me at key bouncing
    Andrew
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
