DT_INTS-18 - problem with INT0
Results 1 to 17 of 17
    What do you trig INT0 with? If it's a pushbutton you may have contact bounce that makes the interrupt fire multiple times. The 10mS pause in the ISR provides some debounce but perhaps it's not enough.
    Also, I don't see
    @   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts
    anywhere. I see that you "manually" enable the INT0 interrupt but try using the provided macro, to begin with at least.
    Sep 2005
    Campbell, CA
    To solve debounce problems, you can test for PORTB = 0 (or 1 if you are triggering on a rising edge). Don't leave the ISR unless the button is in the un-pressed state.
    Charles Linquist
    Brussels, Belgium
    I am triggering off a pushbutton but it is not debounce - it triggers once when I press the button, and again when I release.
    I thought of adding an "exit delay" to miss the release, but that fixes the symptoms and I'd like to understand the cause
    Macro for enabling the interrupt: hmmm - I'll try that tomorrow but is there a macro anywhere that defines which edge to interrupt off or should I stick with INTCON2.6 line ? I'm also going to try moving that statement after the interrupt create ASM section.
    Thanks, Andrew
    Dec 2007
    Finland
    Post
    Remove this one. And reason can be found from here .
    INTCON.4 = 1 'enable INT0
    BR,
    -Gusse-
    Brussels, Belgium
    Okeydokey - so I'll take out the INTCON lines but then where do I tell the D_INTS whether to trigger on a rising or falling edge ?
    Andrew
    ps: I'll add this question to the main D_INTS thread as it might be of interest to others.
    Talking RTFDs ....
    Hi, Andrew
    you sure ?
    INTCON2.6 = 0 ' Int 0 on falling edge of C3
    a look to INTCON2 register could help ...
    Darrel's goodie only enables/Disables the interrupts ... it's you to set interrupt conditions.
    Bouncing looks here a more than a valid reason for "false triggering" ...
    Dec 2007
    Finland
    Post
    Hi Andrew,
    This is OK, interrupt on falling edge.
    INTCON2.6 = 0
    Also add that INT_ENABLE part as Henrik suggested. Then it should work.
    Q: Isn't it so that INT_Handler execution cannot be interrupted (e.g interrupt in interrupt sequence)?
    If yes, then debounce filtering is not needed, because first falling edge trigger INT_Handler. Ringing is ignored during interrupt execution time.
    BR,
    -Gusse-
    Brussels, Belgium
    Hi, Andrew
    you sure ?
    At first I thought it couldn't be a bounce, but then I was just thinking of a "bounce" as I pressed the button. Obviously, a push button can bounce as you release it as well. Simplest thing is probably to just build a delay into the interrupt routine - timing isn't critical in this application and there is no problem holding in the interrupt routine for a few hundred msecs.
    Andrew
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
