DT_INTS-18 - problem with INT0
Results 1 to 17 of 17
    Brussels, Belgium
    Okeydokey - so I'll take out the INTCON lines but then where do I tell the D_INTS whether to trigger on a rising or falling edge ?
    Andrew
    ps: I'll add this question to the main D_INTS thread as it might be of interest to others.
    Talking RTFDs ....
    Hi, Andrew
    you sure ?
    INTCON2.6 = 0 ' Int 0 on falling edge of C3
    a look to INTCON2 register could help ...
    Darrel's goodie only enables/Disables the interrupts ... it's you to set interrupt conditions.
    Bouncing looks here a more than a valid reason for "false triggering" ...
    Dec 2007
    Finland
    Post
    Hi Andrew,
    This is OK, interrupt on falling edge.
    INTCON2.6 = 0
    Also add that INT_ENABLE part as Henrik suggested. Then it should work.
    Q: Isn't it so that INT_Handler execution cannot be interrupted (e.g interrupt in interrupt sequence)?
    If yes, then debounce filtering is not needed, because first falling edge trigger INT_Handler. Ringing is ignored during interrupt execution time.
    BR,
    -Gusse-
    Brussels, Belgium
    Hi, Andrew
    you sure ?
    At first I thought it couldn't be a bounce, but then I was just thinking of a "bounce" as I pressed the button. Obviously, a push button can bounce as you release it as well. Simplest thing is probably to just build a delay into the interrupt routine - timing isn't critical in this application and there is no problem holding in the interrupt routine for a few hundred msecs.
    Andrew
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
