Hi, Andrew
you sure ?
a look to INTCON2 register could help ...
Darrel's goodie only enables/Disables the interrupts ... it's you to set interrupt conditions.
Bouncing looks here a more than a valid reason for "false triggering" ...
At first I thought it couldn't be a bounce, but then I was just thinking of a "bounce" as I pressed the button. Obviously, a push button can bounce as you release it as well. Simplest thing is probably to just build a delay into the interrupt routine - timing isn't critical in this application and there is no problem holding in the interrupt routine for a few hundred msecs.
Andrew
