This is it !
Now works how I intend ! Thank You verry, verry much ! The on/off button works fine, and the check procedure too .I hope I write correct this "check procedure" for checking 5 times if is - indeed - overload (?!)
One last problem : if press but1 and rel1 is high, how can made rel1 low, with but1 - press again, of course - OR BUT2 - press once... ?!? (and some things with but2/rel2).
I try to write something, but rel1 go low AND rel2 go high...and this is unacceptable...Thanks again for attention and especially to Mr.Darrel for kindness and patience...
