<h1> THANK YOU ! </h1>
That is what I needed confirmation on.
Yes, it's work now !
@ DEVICE PIC12F675, intrc_osc_noclkout, wdt_ON, pwrt_on, mclr_off, bod_off
@ Sleep
GPIF=0
Thanks again to all for help ! @ Cheers!
Works...but don't sleep ! I measure the current and it is all the time about 3.5 mA. Based on "PICadilly 12F675", writen by Ian Burn, I try to re-re-redefine the code. But...even I made like in book, the current consumption it's 3.5 mA !
" @ DEVICE PIC12F675, intrc_osc_noclkout, wdt_OFF, pwrt_on, mclr_off, bod_off
IOCB= %00001100
INTCON.3=1
OPTIONS_REG.6=1
INTCON.0=0
Pause 100
@SLEEP
Pause100
I don't understand why do not work ! I remove the PIC from schematic, and the current consumption is about 2.5 mA; so, the 12F675 consume about 1 mA, all the time and never go to sleep with "less than 1 microamp" !
Hi fratello,
Well you have taken this thread every which away, instead of making new threads for different projects, so we do not really know which schematic and code you are asking about, so only "General" statements can be applied here. First, you are chasing 1 ma out of 3.5 ma, is there any way to kill the 2.5 since it is the bigger portion? Secondly, I do not think you will ever see 1µA, maybe wrong just my opinion. Just before @ SLEEP, I would try tristating the GPIO by TRISIO = 255, disable WPU and in your configs, shut off WDT, and disable MCLRE, you might switch to LP_OSC, to further reduce power. Read this thread, different chip but useful maybe:
http://www.picbasic.co.uk/forum/showthread.php?t=11325
Thanks for reply ! I use the schematic from post #1 and the code continuous improved in this thread. I made this changes on the last code posted by Mr.Darell. I say that I use this schematic on automobile ; I think every way to reduce the consumption it's necessary...or maybe the battery of my car give enough current, even I don't start the engine for a long period...It is not a verry big problem, but I want to understand the "mechanism" of the sleep procedure, and I am dissatisfied because, even I try all the variants, the obvious results are not present ! Just I try to make this project almost perfect and I really appreciate the support of all. Sorry if I disturb somebody...or if I became boring...
fratello,
Have you changed anything?
I see you put the WDT back to OFF ... good.
Here's a picture of my breadoard of your circuit, in case you see something different.
Obviously, I'm using LED's instead of relays, but the rest should be the same.
When in SLEEP mode, I measure about 8 µA on my cheap DVM.
The only time it's not in sleep mode, an LED(relay) is ON, so that current is about 7 mA.
Here's the program I'm currently using.
This is schematic I use. With my FUKE DT-830B I measure 3.5 mA -all the time- with no button push (so both relay OFF) and about 37 mA with one relay ON (without motor, of course). I remove the PIC and the current consumption is 2.5 mA (the two transistors ?) .
I use the same code ; I compile him after copy/paste of Yours ! Maybe it's because of my multimeter ? Anyway, thank You all so much for support !
