Problems with 12F675
Results 1 to 40 of 67
    Dec 2008
    Ploiesti, ROMANIA
    Default Yes !!!
    This is it !
    Now works how I intend ! Thank You verry, verry much ! The on/off button works fine, and the check procedure too .I hope I write correct this "check procedure" for checking 5 times if is - indeed - overload (?!)
    One last problem : if press but1 and rel1 is high, how can made rel1 low, with but1 - press again, of course - OR BUT2 - press once... ?!? (and some things with but2/rel2).
    I try to write something, but rel1 go low AND rel2 go high...and this is unacceptable...Thanks again for attention and especially to Mr.Darrel for kindness and patience...
    Last edited by fratello; - 23rd July 2009 at 22:56. Reason: problems with language :(
    Quote Originally Posted by fratello View Post
    I don't understand that.
    Relay1 and Relay2 can never be high at the same time.
    That's because of these statements...
    if but1=1 and rel2=0  then
    If Relay2 is on, it won't accept a press of Button1.
    Or maybe I missed the point of the question.
    Dec 2008
    Ploiesti, ROMANIA
    But1 make rel1 high at first push and low at second push.
    But2 make rel2 high at first push and low at second push.
    It is possible this :
    -but1 make rel1 high at first push and low when push second time but1 OR push but2 ?
    -but2 make rel2 high at first push and low when push second time but2 OR push but1 ?
    So, rel1 ON with but1 , and OFF with but1 OR but2 ; rel2 ON with but2, and OFF with but2 OR but1. Hope now You understand me;I am really verry sorry for my poor english...
    Thank You !
    ....me again. This is my working variant !
    In check: procedure I write this :
    if rel1 = 1 and but2 = 1 then
    low rel1
    goto Btn1PressDone:
    if rel2 = 1 and but1 = 1 then
    low rel2
    goto Btn2PressDone:
    In ISIS don't work, but in fact yes ! I don't understand why, but...Maybe You have another variant, much better; it's a good way to learn more. Still don't know if rel (1 or 2) stop if overload detected, only AFTER checking this overload for 5 times...
    Last edited by fratello; - 24th July 2009 at 08:14. Reason: ...not so young but restless ... ;)
    OK, I see what you mean now.
    Try this ...
    btn1:                   'actionare buton up
             high rel1
             pause 20
             while but1=1
             call check
             wend
             pause 20
             while but1 = 0 AND but2=0
             call check
                      if rel1=0  then
                      GOTO Btn1PressDone
             wend
             LOW rel1
             while but1=1 OR but2=1
             wend
             pause 20
    Btn1PressDone:
    And yes, the check: routine seems to work "only after 5 times".
    Dec 2008
    Ploiesti, ROMANIA
    I am speechless...THANK YOU VERRY MUCH ! Works like a charm ! Great job, You are verry, verry good in this...
    Great forum, I am proud for visiting him. All the best for everyone, wherever you are !
    Dec 2008
    Ploiesti, ROMANIA
    I have tested this module on my car ; works verry fine, like I expect.Since this will be use on car, I think this is one good ideea to minimize the consumption.So I try to write something...Please take one advice...Thanks !
    I think it might be better to ...
        rel1=0
        rel2=0
    @   sleep
    It looks like you have correctly set-up the pic to wake from sleep on PORT change (either switch).
    So then it wakes up ... drives the motor relays as necessary ... and only after the motor is finished, and no buttons are pressed, go back to sleep.
    The two NOP's are only required if it will be jumping to an Interrupt vector on wake up.
    Yours is just continuing where it left off.
    Hmmm, sounds like a powered antenna driver. ??
  1. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 05:58
  2. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
  3. 12F675 cant serout to PC
    By ruijc in forum General
    Last Post: - 3rd December 2007, 01:11
  4. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 22:45
  5. Serial LCD on 12F675
    By anj in forum mel PIC BASIC Pro
    Last Post: - 1st April 2004, 00:11
