Jellis
Can you try it this way ? What I'm suggesting is to clear the mismatch, enable the mismatch interrupt and then sleep
Code:IOCA = %00001000 ' Enable RA3 as on-change-INT ***this could be made permanent before main*** ' clear the mismatch condition dummy = flush INTCON = %10001000 ' Enable interrupts: global & RABIE, but TMR0 disabled ** and RABIF is cleared ** @ sleep ' Microcontroller is in Sleep State waiting for external FLUSH Interrupt ' Valve should be closed at this point and no water flowing GOTO Main ' Loop to Main to wait for next Flush interrupt on RA3 change
