Using Sleep
Results 1 to 3 of 3
Thread: Using Sleep
    Apr 2005
    Virginia
    Exclamation Using Sleep
    Ladies & Gents,
    I'm attempting to put a 18F2525 to sleep and wake up whenever a keypad button is pressed. When pressed, I tell an LED IC to light up one of 12 LEDs to indicate the button pressed, then go back to sleep. I've used sleep successfully in the past in assembly, but due dominantly to laziness, I'm trying to avoid relearning assembly for this task. I've read several posts on this form, but most of what I've seen either says use an interrupt, which I'm trying to do, without an interrupt routine or shows something with @sleep, @nop and then code immediately following as if sleep is a pause statement.
    I'm sure, as usual, I'm doing something silly, but I can't figure it out. I've got the WDT turned off at the beginning and if I turn it on and lessen the WDT postscaler value, the code seems to continuously blink the the LED (for ... next statement in Main routine). If I keep the WDT turned on and increase the postscaler value, as in the code below, the same thing happens every minute or so. I've included a for ... next routine with a slower blink rate when the interrupt routine gets called, but the interrupt routine never appears to get called. If anyone has some advice or a code example on just putting a PIC to sleep and waking up with an interrupt (from a button press) or a link to a post here I've missed, I'd be grateful. Any advice would be appreciated. Thanks in advance!
    The code:
    INCLUDE "modedefs.bas"
    'INCLUDE "pic18f2525.h"
    PORTA = $00
    PORTB = $00
    PORTC = $00
    asm
    __CONFIG _CONFIG1H, _OSC_INTIO7_1H & _FCMEN_OFF_1H & _IESO_OFF_1H ; Use internal oscillator,
    ; output clock on RA6, turn off failsafe monitor, disable switch over mode
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOREN_OFF_2L ; Enable Power-up timer, disable brown out
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_32768_2H ; Turn off Watchdog timer, set WDT postscale
    ; to 1:32,678
    __CONFIG _CONFIG4L, _STVREN_OFF_4L & _XINST_OFF_4L ; Turn off stack under/overflow, turn off
    ; extended instruction set
    bcf WDTCON, SWDTEN ; Disable the watchdog timer
    bsf OSCCON, IRCF2 ; Set the internal oscillator to 8MHz
    bsf OSCCON, IRCF1 ; Set the internal oscillator to 8MHz
    bsf OSCCON, IRCF0 ; Set the internal oscillator to 8MHz
    MOVLW 0x0F ; Set w = 00001111
    MOVWF ADCON1 ; Make all analog pins digital I/Os
    MOVLW 0x07 ; Set w = 00000111
    MOVWF CMCON ; Make all comparator pins digital I/Os
    endasm ' End assembly code
    define OSC 8
    TRISA = %11110000
    TRISB = %11101111
    TRISC = %11000000
    PORTA = $00
    PORTB = $00
    PORTC = $00
    SPI_CLK VAR PORTC.4 ' Clock for SPI communication
    SPI_SDO VAR PORTC.5 ' Serial Data Out for SPI communication
    LED_ENABLE VAR PORTB.4 ' OE-DM2, LED enable for STP16DP05's
    keypress var byte
    i VAR WORD ' Used for for...next loops
    first_byte var byte
    second_byte var byte
    third_byte var byte
    temp_byte var byte
    first_digit var byte
    column var byte
    column_value var word
    row var byte
    row_value var word
    temp var byte
    number var word
    remainder var byte
    value var word
    keypad_number var byte
    check_port var bit
    first_byte = $00
    second_byte = $00
    third_byte = $80 ' Bright Display
    'third_byte = $00 ' Dim Display
    ' Interrupt Setup
    Intcon.1 = 0 ' Clear the INT0IF Interrupt Flag bit
    ' (Last Column Button Press)
    Intcon3.0 = 0 ' Clear the INT1IF Interrupt Flag bit
    ' (Middle Column Button Press)
    Intcon3.1 = 0 ' Clear the INT2IF Interrupt Flag bit
    ' (First Column Button Press)
    Intcon2.6 = 1 ' Enable last column button press interrupt on rising edge
    Intcon2.5 = 1 ' Enable middle column button press interrupt on rising edge
    Intcon2.4 = 1 ' Enable first column button press interrupt on rising edge
    On Interrupt goto Halt ' Once an active interrupt port is enabled, go to the Halt routine
    Intcon = %10000000 ' Activate global interrupt
    Intcon.4 = 1 ' Activate First Column Button Press interrupt
    Intcon3.3 = 1 ' Activate Middle Column Button Press interrupt
    Intcon3.4 = 1 ' Activate First Column Button Press interrupt
    SHIFTOUT SPI_SDO, SPI_CLK, 1, [$0000\16] ' Turn off all LED columns
    HIGH PORTA.1 ' ENABLE the 1st STP16DP05 to except data
    LOW PORTA.1 ' DISABLE the 1st STP16DP05 to except further data
    high porta.2
    SHIFTOUT SPI_SDO, SPI_CLK, 1, [$FFFF\16] ' Turn on proper LED column
    FOR i = 1 to 2
    LOW LED_ENABLE
    PAUSE 250
    HIGH LED_ENABLE
    PAUSE 250
    NEXT
    low porta.2
    HIGH PORTA.1
    LOW PORTA.1
    MAIN:
    LOW PORTB.3 ' Enable the transistor
    for i = 1 to 3
    high porta.2
    low porta.2
    next
    @ SLEEP
    GOTO MAIN
    Button_Action:
    LOW PORTC.0
    LOW PORTC.1
    LOW PORTC.2
    LOW PORTC.3
    SELECT CASE column_value
    CASE 1
    check_port = PORTB.2
    CASE 2
    check_port = PORTB.1
    CASE 3
    CASE ELSE
    GOTO Error
    END SELECT
    HIGH PORTC.0
    IF check_port = 1 THEN
    keypad_number = column_value
    GOTO Got_Value
    LOW PORTC.0
    HIGH PORTC.1
    IF check_port = 1 then
    keypad_number = column_value + 3
    GOTO Got_Value
    LOW PORTC.1
    HIGH PORTC.2
    keypad_number = column_value + 6
    GOTO Got_Value
    LOW PORTC.2
    HIGH PORTC.3
    keypad_number = column_value + 9
    LOW PORTC.3
    column_value = 0
    GOTO Error
    Got_Value:
    LOW PORTC.0
    LOW PORTC.1
    LOW PORTC.2
    LOW PORTC.3
    SELECT CASE keypad_number
    CASE 1
    Value = $0001
    CASE 2
    Value = $0002
    CASE 3
    Value = $0004
    CASE 4
    Value = $0008
    CASE 5
    Value = $0010
    CASE 6
    Value = $0020
    CASE 7
    Value = $0040
    CASE 8
    Value = $0080
    CASE 9
    Value = $1000
    CASE 10
    Value = $2000
    CASE 11
    Value = $4000
    CASE 12
    Value = $8000
    CASE ELSE
    GOTO Error
    END SELECT
    LOW LED_ENABLE
    SHIFTOUT SPI_SDO, SPI_CLK, 1, [$Value\16]
    HIGH PORTA.1
    LOW PORTA.1
    PAUSE 1000
    HIGH LED_ENABLE
    low porta.2
    HIGH PORTA.1
    LOW PORTA.1
    GOTO MAIN
    Error:
    FOR i = 1 to 3
    HIGH PORTA.2
    PAUSE 500
    LOW PORTA.2
    PAUSE 500
    NEXT
    GOTO Main
    Disable ' Disable all interrupts
    Halt: ' Halt Routine
    HIGH PORTB.3 ' Disable the transistor
    HIGH PORTA.2
    PAUSE 1000
    LOW PORTA.2
    column_value = 0 ' Set column value to zero
    if Intcon.1 = 1 then ' If a button in the last column was pressed,
    column_value = 3 ' Set column value to 3
    endif ' End if statement
    if Intcon3.0 = 1 then ' If a button in the middle column was pressed,
    column_value = 2 ' Set column value to 2
    if Intcon3.1 = 1 then ' If a button in the first column was pressed,
    column_value = 1 ' Set column value to 1
    if column_value <> 0 then Resume Button_Action ' If column value is not equal to zero, go to Button Action routine
    LOW PORTB.3
    HIGH PORTA.2
    PAUSE 500
    LOW PORTA.2
    PAUSE 500
    Resume ' Return to sleep
    Enable
    Apr 2005
    Virginia
    Default Additional Note
    I apologize, I posted prematurely. I tried running this without the sleep statement, as I should have done sooner, and my interrupt routine isn't working. I still need help with the proper use of sleep, but I'm attempting to locate the interrupt problem first. I'll post the working interrupt version as soon as I figure this out. If you happen to see anything obvious, I'm all ears, well, eyes anyway. I think the problem is in my configurations, but we'll see. Thanks all.
    Bombay, India
    I haven't specifically used the 18F2525, so I cannot offer you specific advice. However, on the 16F628 and 16F917 that I have used, this is how I do it(from memory)
    Enable PORTB interrupt on change. Global interrupts <B>need not</B> be enabled. Then when you want the processor to sleep, just do this
    @ sleep
    @ nop
    @ nop
    Any change on Portb pins RB4 to RB7(depends on specific bits being set) would trigger an interrupt flag being set. This event causes the PIC to wake up from sleep even though the global interrupt is disabled. Just in case you need you interrupts to be enabled at that time, you have to ensure that the ISR will read PORTB and reset the Change Flag.
    That's all there is to it
    Jerson
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Battery powered applications
    By NavMicroSystems in forum Off Topic
    Last Post: - 22nd June 2009, 08:12
  3. 16F628A current high during sleep
    By Rubicon in forum mel PIC BASIC Pro
    Last Post: - 9th October 2006, 11:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. SLEEP Command and Interupts 16F648A
    By ghoot in forum mel PIC BASIC Pro
    Last Post: - 28th May 2004, 19:35
