Won't go back to SLEEP after 1st Interrupt
Results 1 to 33 of 33
    Mar 2009
    Colorado
    Default Tried your suggestions
    Thanks again Jerson for your help on this.
    I implemented your suggestions by keeping TMR0 disabled during the MAIN and Interrupt Service Routine until just before the IF-THEN block starts checking for pulse inputs from the FlowMeter. However, I see no changes in the current flow on PowerUp or on return to SLEEP after the ISR......350 microamps in both modes. I have included my latest code that includes these changes so you can see how I did it. If I didn't do it right, please advise.
    Still very frustrated on solving this problem.
    ' -----[ Device Declaration ]----------------------------------------------
    ' For MSASM assembler use following:
    @ __config _INTRC_OSC_NOCLKOUT & _BOR_SBODEN  & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    ' The above config  is inteded to set CONFIG = %0000110111010100 for hex 0DD4 or
    ' FCMEN on (1), IESO on(1), BOREN (01), CPD off (1), CP off (1), /MCLR is
    ' digital input (0), /PWRTE off (1), WDTE off (0), INTOSCIO (100).
    ' -----[ Revision History ]------------------------------------------------
    ' Version 1.0.7 on 6/21/09: Eliminated @ NOP in MAIN; Reformated Port
    '                           Assignments list; Changed IntCloc from 4 to 1 MHz;
    '                           WDT_OFF and comparators off to save power.
    ' Version 1.0.8 on 6/22/09: Changes to MAIN to minimize power during Sleep:
    '                           Set BOR_SBODEN; set PCON.4 =0; ANSEL =%11110011,
    '                           TRISA = %00001101..Set RA0, RA2 & RA3 as inputs in
    '                           MAIN before SLEEP permits return to SLEEP after ISR.
    ' Version 1.0.9 on 6/25/09: Moved INTCON statement to just before SLEEP in MAIN.
    ' Version 1.0.10 on 6/27/09: Delayed turning on TMR0 until after Flush interrupt
    ' -----[ Declare Variables & Aliases ]-----------------------------
    diff    VAR Byte      ' Difference between bat_mon and Vthr
    dummy   VAR Byte      ' For read of on-interrupt port & clear mismatch condition
    flush   VAR PORTA.3   ' Set RA3 as input for sensing flush switch closure Int
    i       VAR Byte      ' Index used in Gallon counter loop
    led1    VAR PORTC.0   ' Set RC0 as LED indicator of valve open..water flowing
    led2    VAR PORTC.1   ' Set RC1 as LED indicator of low battery
    bat_mon VAR PortA.0   ' Set RA0 as battery low power monitor
    meter   VAR PORTA.2   ' Set RA2 as input for Hall Sensor meter pulse Interrupt
    open_valve    VAR PORTC.2   ' Set RC2 as valve solenoid open command
    close_valve   VAR PORTC.3   ' Set RC3 as valve solenoid close command
    ' -----[ Declare Constants ]----------------------------------------
     k             CON 10   ' Calibration factor for flow meter...# pulses per gal
     Vthr          CON 3    ' Assumes Low Battery Monitor threshold = 3 volts
    ' -----[ Initialization ]-------------------------------------------
    Init:
    ' Setup Timer0 as an 8-bit counter with the clock input on RA2.
    ' 1:1 TMR0 prescaler
    ' TMR0 counts on high-to-low transitions
      OPTION_REG = %00111000   ' PORTA/B pullups enabled, Interrupt on falling
                               ' edge of RA2/INT, TMR0 clock source is RA2,
                               ' increment on high-to-low transitions, prescaler to
                               ' TMR0, TMR0 Rate 1:2
      TMR0 = 256 - k           ' preload TMR0 to overflow after k counts
    ' Initialization of inputs/outputs
      open_Valve = 0    ' Initialize RC2 (open_valve) at Low value
      close_valve = 0   ' Intialize RC3 (close_valve) at Low value
      TRISA.2 = 1       ' Set RA2 as input port for clock to TMR0
      TRISA.3 = 1       ' Set RA3 as input port for sensing Flush switch closure
      meter = 1         ' Initialize RA2 (meter) at High for METER pulse inputs
                        ' RA2 = TMR0 clock input for simulated meter pulse inputs
      flush = 1         ' Initialize RA3 (flush) at High value for flush interrupt
    ' Interrupts Setting Alias'
    TMR0_Enable VAR INTCON.5     ' Alias for On_Off switch of TMR0 counter
    FLUSH_INT_FLAG VAR INTCON.0  ' Alias RA3(FLUSH) On-change-interrupt flag bit
    TMR0_INT_FLAG VAR INTCON.2   ' Alias Timer0 overflow flag bit
    ' Set INT Handler
    ON INTERRUPT GOTO Int_handler
    '-----[ Main Code Starts Here ]------------------------------------------------
    MAIN:
      ' Perform following steps to save power during Sleep mode
        OPTION_REG.7 = 1    ' Disable PortA/PortB pull-ups
        OSCCON = %0100011   ' Switch to 1 MHz internal oscillator
        VRCON = %00100000   ' Set Voltage Reference for minimum power consumption
                            ' Disable CVref
        ANSEL= %11110011    ' Set PortA to Analog I/O to save power during Sleep but
                            ' leave Bits 2 & 3 as digital for RA2 pulse count
                            ' TMR0 overflow interrupt & RA3 On-Change intterupt.
        ANSELH= %11111111   ' Analog module enabled to save power during Sleep
        CM1CON0.7 = 0       ' Turn off comparators during Sleep
        CM2CON0.7 = 0
        PCON.4 = 0          ' Turn off BOR during Sleep
        WDTCON = %00010110  ' Turn WDT off to SLEEP indefinitely
        TRISA = %00001101   ' Set RA0, RA2 & RA3 as inputs
        TRISB = %11111111   ' Set all PORTB pins to inputs during Sleep
        TRISC = %11111111   ' Set all PORTC pins to input during Sleep
        PortA = %11111111   ' Write Port A all High to clear mismatch and save
                            ' power during SLEEP
        PortB = %11111111   ' Set all Port B and C pins High to save power
        PortC = %11111111   ' in Sleep mode
        ' Interrupt Settings
        INTCON = %10001000  ' Enable interrupts: global & RABIE, but TMR0 disabled
        IOCA = %00001000    ' before SLEEP.  Enable RA3 as on-change-INT
        @ sleep
        ' Microcontroller is in Sleep State waiting for external FLUSH Interrupt
            ' Valve should be closed at this point and no water flowing
       GOTO Main    ' Loop to Main to wait for next Flush interrupt on RA3 change
    '------{ Begin Interrupt Handler }---------------------------------------------
      DISABLE       ' Disable interrupts during interrupt handler
    Int_handler:
        OPTION_REG.7 = 0    ' Enable PortA/PortB Pullups
        WDTCON = %0001000   ' Turn WDT on for ops
        'Initialize registers for interrupt ops
      ' A/D & Comparators disabled
        ANSEL=0             ' Set PortA to digital I/O for use with RA2 and RA3
        ANSELH=0            ' Analog module disabled
        CM1CON0=0           ' Disable comparators
        CM2CON0=0
      ' Port Settings
        TRISA = %11111111   ' Set all PORTA pins to inputs...RA0, RA2 & RA3 are used
        TRISB = %00000000   ' Set all PORTB pins to outputs
        TRISC = %11110000   ' Set lower 4 pins of PartB as outputs for LEDs
        PORTA = %00000000   ' PortA pins all set to Low
        PORTC = %00000000   ' LEDs off, PULSOUT RC3 provides a high-going pulse
        TMR0_Enable = 1     ' Enable the TMR0 pulse counter for overflow interrupt
      IF FLUSH_INT_FLAG = 1 Then  ' Interrupt was from RA3 on change
        REPEAT
            ' Wait until the external Flush interrupt is at high level...limits
            ' interrupt to switch closure only and not also for switch opening
        Until flush = 1
        PULSOUT open_valve,2000*2   ' Generate 20 msec pulse to RC3 to open valve
        'HIGH led1              ' Light indicator that valve is open & water flowing
        Write  7, flush        ' Write FLUSH value..remove comment for test only
        ' Put code here to start a timer to run for 50 secs as a fail safe
        ' to prevent overflow of toilet tank in case of sensor failure.
            'PULSOUT close_valve,2000 ' Generate 20 msec
                                      ' pulse to RC4 to close valve
      Endif
      ' Valve is open and water is flowing
      REPEAT
            ' Wait for flow to reach 1.6 gallons
            ' Flash flow light while water flowinguntil pulse counter overflows
            High led1
            Pause 125/10
            Low led1
            Pause 500/10
            If diff > 2 Then   ' Battery is low..flash the low battery monitor light
                HIGH led2      ' while water is flowing
                PAUSE 125/10
                Low led2
                Pause 500/10
            'Write 5, bat_mon  ' Remove comment for test only
      Until TMR0_INT_FLAG = 1  ' Until flow meter pulse counter overflows
      PULSOUT close_valve,2000*2 ' Generate 20 msec pulse to RC4 to close valve
      WRITE 11, TMR0_INT_FLAG ' Write TMR0 value..remove comment for test only
      dummy = flush            ' Clear mismatch condition
      FLUSH_INT_FLAG = 0       ' Clear interrupt flag & enable RA3 on interrupt
      TMR0_INT_FLAG = 0        ' Clear overflow flag
      TMR0 = 256 - k           ' Reload TMR0 to overflow after k counts
      RESUME                   ' Resume Main Program
      ENABLE
      '-------{ End of Interrupt Handler }-----------------------------------------
        ' If the user program ends by getting to the last statement of the program
        ' at an END instruction, the MCU will SLEEP and await a wakeup.
    Default @ nop
    take a look..(DS41262C-page 210)
    "If the GIE bit
    is set (enabled), the device executes the instruction
    after the SLEEP instruction
    , then branches to the interrupt
    address (0004h). In cases where the execution of
    the instruction following SLEEP is not desirable, the
    user should have a NOP after the SLEEP instruction"
    ...did you try
    @ sleep
    @ nop
    I'm not expert neither....
    Bombay, India
    Jellis
    Can you try it this way ? What I'm suggesting is to clear the mismatch, enable the mismatch interrupt and then sleep
        IOCA = %00001000    ' Enable RA3 as on-change-INT ***this could be made permanent before main***
        ' clear the mismatch condition
        dummy = flush
        INTCON = %10001000  ' Enable interrupts: global & RABIE, but TMR0 disabled ** and RABIF is cleared **
        @ sleep
    Mar 2009
    Colorado
    Default Tried your last 2 posted suggestions
    I tried placing @ NOP statement after SLEEP and it made no difference....MCU ran as desired in either case and power on Powerup and after 1st ISR still at 350 microamps.
    Jellis
        dummy = flush
        @ sleep
    I also tried changing my code just before SLEEP to this suggestion and it also made no difference in operation or power consumption.
    I am at a total loss as to what to do next. I have experimented with the code in many ways to see if I can get the Powerup/SLEEP power consumption lower but without success.
    Two suggestions.
    • Take a 100K resitor from +5V to your ammeter, and the other lead to ground.
      If your meter is working correctly, you should get a reading of 50uA.
    • Remove the inputs from any of the pins that you can.
      Compile and load this program ...
      ASM  ; 16F690
        ifdef PM_USED                  ; For PM assembler
          device  INTRC_OSC_NOCLKOUT   ;   Oscillator Selection
          device  FCMEN_OFF            ;   Fail-Safe Clock Monitor
          device  IESO_OFF             ;   Internal External Switchover
          device  BOD_OFF              ;   Brown-out Detect
          device  CPD_OFF              ;   Data Code Protection
          device  PROTECT_OFF          ;   Code Protection
          device  MCLR_OFF             ;   Master Clear Reset
          device  PWRT_OFF             ;   Power-up Timer
          device  WDT_OFF              ;   Watchdog Timer
        else                            ; For MPASM assembler
      cfg=      _INTRC_OSC_NOCLKOUT     ;   Oscillator Selection
      cfg=cfg&  _FCMEN_OFF              ;   Fail-Safe Clock Monitor
      cfg=cfg&  _IESO_OFF               ;   Internal External Switchover
      cfg=cfg&  _BOR_OFF                ;   Brown-out Reset
      cfg=cfg&  _CPD_OFF                ;   Data Code Protection
      cfg=cfg&  _CP_OFF                 ;   Code Protection
      cfg=cfg&  _MCLRE_OFF              ;   Master Clear Reset
      cfg=cfg&  _PWRTE_OFF              ;   Power-up Timer
      cfg=cfg&  _WDT_OFF                ;   Watchdog Timer
        __CONFIG  cfg
      END   ; Enter Comma (sleep forever with no hope of waking)
    Mar 2009
    Colorado
    Question Assembler errors??
    T
    <br>[*]Remove the inputs from any of the pins that you can.
    ASM  ; 16F690
      __CONFIG  cfg
    [/list]
    I copied this code into my MicroCode Studio editor, assembled it with PICBasic Pro compiler, programmed it into my 16F690 that is installed in a PICkit2 Low Pin Development Board, and then tried to run the program. I get the following Assembler errors:
    "Overwriting previous address contents (2007)
    Symbol not previously defined (_FCMEN_OFF)
    Symbol not previously defined (_IESO_OFF)
    Symbol not previously defined (_BOR_OFF)
    SYmbol not previously defined (_CPD_OFF)"
    I presumed this was because I had the _config file commented out in the 16F690.INC file, so decommented it and tried again. Same errors ocurred. Any suggestions.
    Question: If I get this program to run, what will that tell me? Are you saying that with the 16F690 programmed this way I can then measure the power consumed when running and it will tell me the lowest possible power for the 16F690 before adding any other code??
    First off, do the resistor test. Make sure the meter's working.
    Never assume the reading you get is what you are actually testing.
    For the "Overwriting previous address contents (2007)" error, see this post ...
    http://www.picbasic.co.uk/forum/show...75&postcount=5
    I'm not sure what you mean by "decommented it", you should have Commented it.
    The idea is to eliminate your code and config's as the problem.
    If you still get high current readings with the chip locked in sleep mode, then you need to look at the hardware.
    By itself, the chip disables pull-ups, puts all pins in input mode, with all analog channels enabled. Current due to noise will be minimal.
    John,
    add this to your config: _FCMEN_OFF , this disables the fail safe clock monitor, made about 200 micro amp difference here.
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  2. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  3. Can't ID interrupt source with this IntHandler??
  4. Using Sleep
    Last Post: - 17th August 2008, 05:05
