Temperature with the LM34C
Results 1 to 26 of 26
    Darrel most likely hit the nail on the head. Sounds like some odd hardware problem, or a
    bad connection.
    Troubleshoot things one-at-a-time, and just setup a simple loop shooting serial data to
    your PC serial port until you get the serial com thing working.
    If it goes-like-splat, then you know there's a bad connection - or maybe even a problem
    with your PC serial port.
    Note: It might even be a problem with the PIC itself if the A/D is foo-bar. The ADCIN library
    function is a blocking type with;
    adcinloop
    btfsc ADCON0, GO_DONE ; Wait for conversion to complete
    goto adcinloop
    If ADCON0, GO_DONE never gets cleared, it's a sit & spin function call...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    bad connection.
    I have no idea how to begin setting up a loop like this.
    adcinloop
    goto adcinloop
    I have no idea what the above means either.
    ~ Dave
    Quote Originally Posted by StoneColdFuzzy View Post
    I have no idea how to begin setting up a loop like this.Dave
    Just make a short loop sending out some text strings over and over, while you wiggle wires and such.
    ~ Dave
    Cause he misspeller foo bar, wich is an ackronym which I misspelled, FUBAR is the proper spelling you guess what the first 2 letters spell, the BAR means Beyond All Repair. It's like it's cousin SNAFU, Situation Normal All . . . .
    X VAR BYTE
     FOR X = "A" TO "Z"
      DEBUG X,10,13
      PAUSE 500
     NEXT X
     GOTO Main
    -Bruce
    tech at rentron.com
    Joe, Bruce,
    Thanks!
    Still nothing. I'm going to make up some new cables with fresh contacts and I might even try a different computer.
    For the loop program; should I use config bits?
    ~ Dave
    Use the same config settings you used before.
    -Bruce
    tech at rentron.com
    Default Dave
    Solved! Bad number 2 contact on my 9 position D-sub connector. Thanks for all of the help!
  1. Replies: 10
    Last Post: - 17th February 2012, 08:19
  2. DS18S20 reading negative temperature
    By srob in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 22:21
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
