Temperature with the LM34C
Results 1 to 26 of 26
    Look in your PIC datasheet in the analog to digital converter section. There you will find the maximum impedance you may use with your Specific PIC model.
    Usually a simple small trim-pot (single or multi-turn) work pretty well... You could also use a already made voltage reference, this doesnt require any calibration and tend to be more stable on the long run.
    OK, I'm using a PIC16F877a instead of the PIC16F877. I have a 4 MHz ceramic osc and I'm using the direct connection as on the Rentron page. I don't know if I need to do this or not, but I have the VSS and VDD pins tied together, respectively. I checked the connections and tested the LM34 with 5 volts. The LM34 changes output voltage fine I don't know if I goofed the code up or not, but I'm getting nothing. Here's the code:
    @ device  pic16F877A, xt_osc, wdt_off, lvp_off, protect_off
    DEFINE loader_used 1    ' Boot loader is being used
    DEFINE debug_mode  1    ' Debug sending Inverted serial data
    DEFINE debug_reg portc  ' Debug Port = PortC
    DEFINE debug_bit 6      ' Debug.bit = PortC.6
    DEFINE debug_baud 9600  ' Default baud rate = 9600
    DEFINE osc 4            ' We're using a 4 MHz oscillator
    DEFINE ADC_BITS 8       ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1      ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50  ' Set A/D sampling time @ 50 uS
    samples VAR WORD        ' Multiple A/D sample accumulator
    sample  VAR BYTE        ' Holds number of samples to take
    temp    VAR BYTE        ' Temperature storage
    samples = 0             ' Clear samples accumulator on power-up
        TRISA = %11111111   ' Set PORTA to all input
        ADCON1 = %00000011  ' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
        PAUSE 500           ' Wait .5 second
    loop:
        FOR sample = 1 TO 20    ' Take 20 samples
            ADCIN 0, temp       ' Read channel 0 into temp variable
            samples = samples + temp ' Accumulate 20 samples
            PAUSE 250           ' Wait approximately 1/4 seconds per loop
        NEXT sample
        temp = samples/20
        DEBUG "Temperature is: ",DEC temp," Deg F",10,13
        samples = 0             ' Clear old sample accumulator
        GOTO loop               ' Do it forever
    What do you have connected to AN3? If nothing then try
    ADCON1 = %00000100
    ADCON1 = %00000100
    I have the wiper of a pot connected and set at 2.55 volts.
    ~ Dave
    May 2008
    Italy
    Dave, Vss is the ground or (zero volts) and Vdd is power or (+5Volts), from what you say it seems you have a short.
    Remove it and re-establish the corrected connections.
    Al.
    There is no short. There are two VVS pins and two VDD pins. They are tied together respectively. In other words, the VVS pins are tied to each other; the VDD pins are also tied to each other.
    ~ Dave
    I had to set this up myself to find the problem.
    When you use "DEFINE" everything has to be upper case. It would not work until I made that change. Problem was so simple but hard to see.
    <html>
    <body><!--StartFragment--><pre><code><font color="#000000">    <font color="#FF0000">DEFINE </font><font color="#0000FF">OSC </font>20
        @ <font color="#0000FF"><b>__config _HS_OSC </b></font>&amp; <font color="#0000FF"><b>_WDT_ON </b></font>&amp; <font color="#0000FF"><b>_LVP_OFF </b></font>&amp; <font color="#0000FF"><b>_CP_OFF
        </b></font><font color="#000080"><i>'DEFINE loader_used 1    ' Boot loader is being used
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>DEBUG_MODE  </b></font>1    <font color="#000080"><i>' Debug sending INVERTED serial data
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>DEBUG_REG PORTC  </b></font><font color="#000080"><i>' Debug Port = PortC
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>DEBUG_BIT </b></font>6      <font color="#000080"><i>' Debug.bit = PortC.6
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>DEBUG_BAUD </b></font>9600  <font color="#000080"><i>' Default baud rate = 9600
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>ADC_BITS </b></font>8       <font color="#000080"><i>' Set A/D for 8-bit operation
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>ADC_CLOCK </b></font>1      <font color="#000080"><i>' Set A/D clock Fosc/8
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>ADC_SAMPLEUS </b></font>50  <font color="#000080"><i>' Set A/D sampling time @ 50 uS
        </i></font><font color="#0000FF"><b>samples </b></font><font color="#FF0000"><b>VAR WORD        </b></font><font color="#000080"><i>' Multiple A/D sample accumulator
        </i></font><font color="#0000FF"><b>sample  </b></font><font color="#FF0000"><b>VAR BYTE        </b></font><font color="#000080"><i>' Holds number of samples to take
        </i></font><font color="#0000FF"><b>temp    </b></font><font color="#FF0000"><b>VAR BYTE        </b></font><font color="#000080"><i>' Temperature storage
        </i></font><font color="#0000FF"><b>samples </b></font>= 0             <font color="#000080"><i>' Clear samples accumulator on power-up
        </i></font><font color="#0000FF"><b>TRISA </b></font>= %11111111   <font color="#000080"><i>' Set PORTA to all input
        </i></font><font color="#0000FF"><b>ADCON1 </b></font>= %00000011  <font color="#000080"><i>' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
        </i></font><font color="#FF0000"><b>PAUSE </b></font>500           <font color="#000080"><i>' Wait .5 second
        </i></font><font color="#0000FF"><b>loop</b></font>:
        <font color="#FF0000"><b>FOR </b></font><font color="#0000FF"><b>sample </b></font>= 1 <font color="#FF0000"><b>TO </b></font>20    <font color="#000080"><i>' Take 20 samples
            </i></font><font color="#FF0000"><b>ADCIN </b></font>0, <font color="#0000FF"><b>temp       </b></font><font color="#000080"><i>' Read channel 0 into temp variable
            </i></font><font color="#0000FF"><b>samples </b></font>= <font color="#0000FF"><b>samples </b></font>+ <font color="#0000FF"><b>temp </b></font><font color="#000080"><i>' Accumulate 20 samples
            </i></font><font color="#FF0000"><b>PAUSE </b></font>250           <font color="#000080"><i>' Wait approximately 1/4 seconds per loop
        </i></font><font color="#FF0000"><b>NEXT </b></font><font color="#0000FF"><b>sample
        temp </b></font>= <font color="#0000FF"><b>samples</b></font>/20
        <font color="#FF0000"><b>DEBUG </b></font><font color="#00FF00"><b><i>&quot;Temperature is: &quot;</i></b></font>,<font color="#FF0000"><b>DEC </b></font><font color="#0000FF"><b>temp</b></font>,<font color="#00FF00"><b><i>&quot; Deg F&quot;</i></b></font>,10,13
        <font color="#0000FF"><b>samples </b></font>= 0             <font color="#000080"><i>' Clear old sample accumulator
        </i></font><font color="#FF0000"><b>GOTO </b></font><font color="#0000FF"><b>loop               </b></font><font color="#000080"><i>' Do it forever
        </i></font><font color="#FF0000"><b>END
    </b></font></code></pre><!--EndFragment--></body>
    </html>
  1. Replies: 10
    Last Post: - 17th February 2012, 08:19
  2. DS18S20 reading negative temperature
    By srob in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 22:21
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
