need help in lookup
Results 1 to 28 of 28
    Apr 2009
    hi joe im using the eeprom to save data and count them,just want to know how to vary the digits when enable digit 1 it shift out the data or number to digit 1 then digit 2 so on and remember im using shiftout to 74hc164 to drive 7 sigment digits,i want to drive 4 digit with shiftout, i will check this thread you gaved me thank you so much joe
    Quote Originally Posted by malwww View Post
    hi joe I'm using the eeprom to save data and count them,just want to know how to vary the digits when enable digit 1 it shift out the data or number to digit 1 then digit 2 so on and remember im using shiftout to 74hc164 to drive 7 sigment digits,i want to drive 4 digit with shiftout, i will check this thread you gaved me thank you so much joe
    I buy 4 digit displays from http://www.sureelectronics.net/ , usually through their eBay store. For about 15 US you get an spi display that works exactly with the code in your lookup table and it is about 32mm tall, 1 1/2 inches tall. These displays can be hooked together using cables supplied with them to make several digit displays. BTW, God helps us every day, that's why we do not starve.
    Apr 2009
    hello joe i wrote this code now it works the 7segment and shiftout .but when i vary things it doesnt works and it doesnt show me things, i want to know where i put a variables and how, is pic cant run 2 things in the same times ? (variables and shiftout with digit out) and i keep the shiftout how it is now , please help now it show me 3210 on leds 7segments ,sorry i cant find lcds in my country and i cant send money to buy from europ or usa bcz they dont alow us to send money out, i need to call my friends in spain to buy me them but it will take long 'now im new in pbp i want to learn a bit good and sorry about my english , thank you joe
    ' I2CREAD and I2WRITE Commands
    Include "modedefs.bas"
    'DEFINE SHIFT_PAUSEUS 1
    SDO VAR PortB.0
    SCLK var PortB.1
    DPIN var PORTA.0
    CPIN var PORTA.1
    B0 var byte
    B1 var byte
    B2 var byte
    B3 var byte
    B4 var byte
    symbol Digit_1 = portb.4
    symbol Digit_2 = portb.5
    symbol Digit_3 = portb.6
    symbol Digit_4 = portb.7
    SCLK = 8
    TRISB = 0
    ' i did a variable here lookup or read but it dont work or shiftout,
    Digit_2 = 1
    Digit_3 = 1
    digit_4 = 1
    SHiftOUT SDO,SCLK,0,[252]
    Digit_1 = 0
    pause 1
    Digit_1 = 1
    Digit_3 = 1
    digit_4 = 1
    SHiftOUT SDO,SCLK,0,[96]
    Digit_2 = 0
    pause 1
    Digit_1 = 1
    Digit_2 = 1
    digit_4 = 1
    SHiftOUT SDO,SCLK,0,[218]
    Digit_3 = 0
    pause 1
    Digit_1 = 1
    Digit_2 = 1
    digit_3= 1
    SHiftOUT SDO,SCLK,0,[242]
    Digit_4 = 0
    pause 1
    Here is what your code is doing
    SDO VAR PortB.0
    SCLK var PortB.1
    DPIN var PORTA.0
    CPIN var PORTA.1
    B0 var byte
    B1 var byte
    B2 var byte
    B3 var byte
    B4 var byte
    symbol Digit_1 = portb.4 <font color=red> renaming portb.4 to Digit_1, These can only hold the value 1 or 0</font color>
    SCLK = 8 <font color=red> attempt to give portb.1 the value of 8 ???</font color>
    TRISB = 0 <font color=seagreen> set all port b as outputs</font color>
    Digit_2 = 1 <font color = blue> Make renamed ports HIgh. </font color>
    Digit_3 = 1
    digit_4 = 1
    Digit_1 = 0
    pause 1
    Digit_1 = 1
    Digit_3 = 1
    digit_4 = 1
    Digit_2 = 0
    pause 1
    Digit_1 = 1
    Digit_2 = 1
    digit_4 = 1
    Digit_3 = 0
    pause 1
    Digit_1 = 1
    Digit_2 = 1
    digit_3= 1
    Digit_4 = 0
    pause 1
    You need to put in the REQUIRED code to disable analog stuff for your chosen PIC too or it will not do the digital dance. You need to define the TRISA values to make the proper ports inputs or outputs.
    OK I am not clear on what you want to do. Are you still wanting to retrieve your lookup from external eeprom? Because that is way more code than pulling it out of your main chip. Look at my tachometer code. I stored those values in the on chip eeprom, but I could have just as easily used a lookup table in code space, the primary immediate advantage to storing it in eeprom, is if you change to a different display you can easily change the eeprom data, to match.
    Apr 2009
    thank you joe, the problem i have is not lookup or eeprom or lcd,the problem is when i put variables the code doesnt works, like when i put the variables with the code above. i have problem when the pic start it losts betweenm the main shiftout and the variable so it doesnt work bcz im pausing the variable 1000 and shiftout is too fast so can i see the numbers on lcd ,the lcd and numbers shown good but just i add any variables it doesnt work or shift out things , i use pic 16f84 i think it hasnt analog stuff , thank you joe for your best
    for b = 0 to 9
    lookup n, [...,...,...,],bo
    or read ..,..
    next b
    example
    SDO VAR PortB.0
    SCLK var PortB.1
    DPIN var PORTA.0
    CPIN var PORTA.1
    B0 var byte
    B1 var byte
    B2 var byte
    B3 var byte
    B4 var byte
    symbol Digit_1 = portb.4 renaming portb.4 to Digit_1, These can only hold the value 1 or 0
    SCLK = 8 attempt to give portb.1 the value of 8 ???
    TRISB = 0 set all port b as outputs
    for b3 = 0 to 9
    I2CREAD DPIN,CPIN,$A0,b3,[B1]
    next b
    Digit_2 = 1 Make renamed ports HIgh.
    Digit_3 = 1
    digit_4 = 1
    SHiftOUT SDO,SCLK,0,[b1]
    Digit_1 = 0
    pause 1
    Digit_1 = 1
    Digit_3 = 1
    digit_4 = 1
    SHiftOUT SDO,SCLK,0,[b2]
    Digit_2 = 0
    pause 1
    Digit_1 = 1
    Digit_2 = 1
    digit_4 = 1
    SHiftOUT SDO,SCLK,0,[..]
    Digit_3 = 0
    pause 1
    Digit_1 = 1
    Digit_2 = 1
    digit_3= 1
    Digit_4 = 0
    pause 1
    and shiftout the variables it keeps just blinkin very slow no numbers nothings .
    Apr 2009
    hi again joe i found this link it has a few projects maybe you'll like it http://www.compsys1.com/workbench/
    I wrote you a counter, here is the code, would you like fries and a coke?
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF &_CP_OFF & _BODEN_OFF & _LVP_OFF
    SDO  Var PortB.4
    SCLK Var PortB.5
    DLE  Var PortB.7
    EECON1 = 7
    B0      Var WORD
    B1      Var byte
    D1      Var byte
    D10     Var byte
    D100    Var Byte
    D1000   Var Byte
    ONES    Var Byte
    TENS    Var Byte
    HUNS    Var Byte
    THOUS   Var Byte
    'WPUA = %00110001
    'ANSEL   = 0  ' FOR USE IN 16F690
    'ANSELH  = 0
    CCP1CON = 0
    'CM1CON0 = 0
    'CM2CON0 = 0
    CMCON = 7   ' Disable comparators 16F648A
    OPTION_REG = 0     '16f628a
            'OPTION_REG = %00111000     ' set for 16f690
    data @0,252,96,218,242,102,182,190,224,254,246
    Pause 10
     PORTB = 0
     PORTA = 0
     TRISB = %00000000 ' lower 4 pins outputs
     TRISA = %00000001 ' RA2 = TMR0 clock input
    count portA.0,100,b1
     B0 = B0+B1   'STORE THE RESULTS BETWEEN COUNTER LOOPS
     If B0 >= 9999 then B0 = 0
    D1    = b0 DIG 0        ' Load Thousands Digit
        Read D1, ONES           ' Convert and Load Thousands Variable
    d10   = B0 DIG 1        ' Load Hundreds Digit
        READ D10,TENS           ' Convert and Load Hundreds Variable
    D100  = B0 DIG 2        ' Load Tens Digit
        READ D100,HUNS          ' Convert and Load Tens Variable
    D1000 = B0 DIG 3        ' Load Ones Digit
        READ D1000,THOUS        ' Convert and Load Ones Variable
    Shiftout SDO,SCLK,4,[ONES\8,TENS\8,HUNS\8,THOUS\8]   ' Send digits to display module 0
    PAUSE 10
    HIGH PORTB.7
    pulsout DLE, 125
    pause 12
    Goto MAIN
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. ADCIN and LOOKUP ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 22:02
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. Confused On Dig & Lookup
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 22:49
