more info required
Hi malwww,
are you using the eeprom in this counter or just a display? Are you wanting to load count into eeprom and then display the results or just count to 9999? Am I correct in assuming SDO & SCLK are for the display ?
It is pretty easy once you get the hang of it, overflow your counter variable into another variable and sort @ display time using the DIG statement. Look at this thread to see how, post #9 is where I posted the code to which I refer. http://www.picbasic.co.uk/forum/showthread.php?t=9037
