need help in lookup
Results 1 to 28 of 28
    Hello malwww,
    If you have been following other threads, you have seen a similar one to yours. If you are using byte variables only then use lookup instead of lookup2 as the code is 1/3 as big and you can use a table of up to 255 choices. Lookup2 gives only 85 choices, which can be byte or word variables.
    Apr 2009
    Smile
    hi joe thank you again for explaining to me ,i have another question please if you dont mind...i i want to write atring (lookup) to the external eeprom then i read it and send it out just to get more ideas bcz im new in pbp ,but its easy to lern than asm. have a great weekend joe
    '' I2CREAD and I2WRITE Commands
    Include "modedefs.bas"
    DEFINE I2C_SLOW 1
    DEFINE SHIFT_PAUSEUS 1000
    SDO VAR PortB.0
    SCLK var PortB.1
    SCLK = 8
    SO con 0
    DPIN var PORTA.0
    CPIN var PORTA.1
    B0 var byte
    B1 var byte
    B2 var byte
    B3 var byte
    n var byte
    portB = 0
    TRISB = 0
    'for n = 0 to 15
    lookup n,[252,96,218,242,102,182,190,224,254,246],b0 ' numbers from 0 to 9
    For B2 = 0 To 15
    I2CWRITE DPIN,CPIN,$A0,b2,[str B0\8]
    Pause 20
    Next B2
    'next n
    loop: For B3 = 0 To 15
    I2CREAD DPIN,CPIN,$A0,B3,[B1]
    SHiftOUT SDO,SCLK,0,[b1]
    Next B3
    Goto loop
    i wrote this code but it doesnt shiftout the numbers from 0 to 9 like i have in the string .but it works good with last programe you fixed for me .see u joe
    Quote Originally Posted by malwww View Post
    hi Joe thank you again for explaining to me ,I have another question please if you dont mind...I want to write a string (lookup) to the external eeprom then I'll read it and send it out just to get more ideas because I'm new in pbp ,but its easier to learn than asm. have a great weekend Joe
      DEFINE I2C_SLOW 1
    SDO VAR PortB.0
    SCLK var PortB.1
    SCLK = 8
    SO      con     0
    DPIN    var     PORTA.0
    CPIN    var     PORTA.1
    B0      var     byte
    B1      var     byte
    B2      var     byte
    B3      var     byte
    n       var     byte
    portB = 0
    TRISB = 0
     'for n = 0 to 15 <font color = red>' commented out </font color>
    <font color=green>you have setup your variables, and stored nothing in them yet, and are proceeding to lookup the value of "n" which is unknown to you,</font color>
     <font color=green>'the following loop will output the value stored in "n" filtered through the lookup table 15 times,
    always the same number,in each eeprom location.
    why the str modifier?
    Seems to me the numbers in the lookup table are
    not string values, as they would be arranged between
    quotation marks like so "252","96" . . .</font color>
            For B2 = 0 To 15
                    Pause 20
            Next B2
            'next n
            Next B3
            Goto loop
    are you seeing what you need to change ?
    Apr 2009
    I DIDNT UNDERSTAND GOOD JOE, DO I HAVE TO PUT QUOTATIONS?
    BCZ I HAVE A PROBLEM TO WRITE IN THE EEPROM ,WHEN I READ THEM IT SHOW MW DEFFIRENT DATA,I STORED THOSE NUMBERS IN THE EEPROM USING THE PROGRAMER WHEN I READ THEM IT WORKS GOOD ,THE PROBLEM I HAVE IS TO WRITE TO THE EEPROM AND WHEN I WRITE JUST 1 NUMBER IT WORKS GOOD ,
    For B2 = 0 To 9
    Pause 20
    Next B2
    THANK YOU FOR HELPING ME JOE,
    Apr 2009
    [thank you joe got it now it works have a great day ...
    SDO VAR PortB.0
    SCLK var PortB.1
    SCLK = 8
    DPIN var PORTA.0
    CPIN var PORTA.1
    B0 var byte
    B1 var byte
    B2 var byte
    N var byte
    portB = 0
    TRISB = 0
    For B2 = 0 To 9
    lookup b2,[252,96,218,242,102,182,190,224,254,246],b0
    I2CWRITE DPIN,CPIN,$A0,b2,[ b0]
    Pause 20
    Next B2
    loop: For B3 = 0 To 9
    I2CREAD DPIN,CPIN,$A0,b3,[B1]
    Next B3
    Goto loop
    GOOD ! Glad you have it working the way You want it.
    Now I am curious, what are you making? I am guessing
    you intend to do more than store 0 - 9 in the eeprom.
    There are dozens of examples here to do something similar
    to what you have in mind, whatever it is. Google can search
    just this forum if you use this link.
    http://www.google.com/custom?hl=en&c...ch&sitesearch=
    just check the check box that says, Search picbasic.co.uk. and you are set.
    Apr 2009
    thank you joe for explaining to me things ,im always here,i really want to lern pbp good bcz im interesting,i posted another thread about VGA box if you have any ideas i want to share with everyone so we can build it , hope you are doing good .!
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. ADCIN and LOOKUP ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 22:02
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. Confused On Dig & Lookup
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 22:49
