Very Simple ICSP Programmer
Results 1 to 40 of 130
    Nov 2008
    Talking
    Quote Originally Posted by Squibcakes View Post
    Hi guys,
    I have been using this simple programmer.. why pay big bucks for a PIC programmer when this one costs just cents! In fact I have stopped using my 'other programmer' all together now.
    All you need is:
    three 4.7k Resistors,
    a few wires (1m)
    9 pin d-connector (female),
    and a 5 volt dc supply.
    I have used it on 16F84, 16F62X, 16F87X chips without problems.
    To make it:
    TXD (3) ------[4.7k]-------VPP
    GND (5) --------------------VSS
    DTR (4) -------[4.7k]------DATA
    CTS (8) ------------------DATA
    RTS (7) -------[4.7k]------CLK
    Numbers in Bracket are the connections on the 9-Pin D-Connector.
    I have made up a small PCB to mount the resistors on but... you could just solder them in line to go cheap.. Just be carefull they dont short out. If anyone wants the PCB footprint I can post it.
    Then just put your PIC into a breadboard, connect your 5 volt supply to VDD/VSS, and away you go.
    hi!!!!!!!!!
    can u please send the pcb layout &some more details to programm
    the pic
    its argent!!!!11111
    also which type pic r compatable with the such programmer?
    im new here
    expecting u r kindaa response
    i l be more happy u send softwares so that i m able to make pcb layouts
    Quote Originally Posted by sandeep View Post
    hi!!!!!!!!!
    the pic
    its argent!!!!11111
    im new here
    OR...and I just might be a little bit crazy here...
    If it's so argent, just go out and buy a PICKIT2.
    Microchip supported, already complete, done, done and done...
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 02:11
  2. Soic Icsp
    Last Post: - 13th September 2008, 19:51
  3. Replies: 1
    Last Post: - 10th December 2007, 23:57
  4. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 20:14
  5. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
