Very Simple ICSP Programmer
Results 1 to 40 of 130
    The blink code is a copy and paste from the PBP samples folder. Just added a few extra configuration lines... (oscon etc).
    When the pic is flashed there is no problems with the program running correctly. The problem is more getting it to program the pic in the first place. Sometimes it works... more often it doesnt. Especialy if start getting complicated programs.
    PS: My little programmer I bought on ebay is still a no show... how long does it take to get from Hong Kong to us via "air mail"?
    Quote Originally Posted by bearpawz View Post
    I had a couple of problems with my Warp13 programmer (serial port based) that caused me some headaches until I figured out that it was junk running in the background, mainly those programs that monitor cpu temps, fan speeds, etc. were causing it to mess up. Try killing all your background processes (well, not all, but at least everything in the tray) and then trying to program. heck, boot up in safe mode and see what happens.
    Well, this is a "development" machine I use so not much of anything running anywhere... using windows 98SE..
    You know, I really wish I could find the old "Kit96" progrrammer. I had that once and it got lost when I moved... but never had any problems with it and it was only about $15.00. If anyone has one laying around they dont use, or for that matter has the schematic and PCB files (I beleive the kit that you put together came with a PCB layout in the literature).
    I sure miss that programmer.
    How about the cable between the PC and the programmer? If it's a serial cable, it isn't a crossover cable is it? How about the ground pin (9 or 5, can't remember which), is it connected? With mine, I've got continuity between the ground on the Warp13 and the case of the PC. I've heard where some laptop users have problems because the ground in the cable isn't connected (myself included!). I had to blob-solder a jumper to the hood of the cable back in the day to get it to work.
    Quote Originally Posted by Bearpawz
    Google have to be your friend dude...
    http://kitsrus.com/pdf/k96.pdf
    http://www.picallw.com/
    http://picallw.feniks-pro.com/pictures/p16.jpg
    http://picallw.feniks-pro.com/pictures/p16pro.gif
    http://picallw.feniks-pro.com/pictures/pcb16pro.gif
    http://picallw.feniks-pro.com/pdf/p16pro.pdf
    Not Enough? Just search for P16PRO40
    Enjoy!
    Oct 2003
    Australia
    Have you tried another uPic.. Say a 16F628 or 16F88?
    This programmer works just not on chips ending in 'A' or when connected to laptop serial ports.
    squib
    Hey Squibcakes-
    I'm using your program for development using ICSP with '873A, '876A, '877A - and ICPROG, no problem, works every time
    Are you saying that you have come across some problems with -A suffix PIC's and your programmer?
    regards
    Angus
    Oct 2011
    Default Re: Very Simple ICSP Programmer
    Hello everybody, I am new in this forum. The last week i programmed one 16f88, with my GTP USB LITE . I was my first time with this pic. I programed it with internal oscilator 8 MHz , and PB7 and PB6 , put high and low intermittently.
    The problem was when i try to programmer other time. This fail, because the 16f88 enter in oscilation mode before programming mode.
    How i can to resolve this ????
    Thanks !
    Sep 2009
    Enable Vpp first, then Vdd on your programmer.
    Dec 2009
    Default Need help for schematic diagram for this one for 16f877a
    Guyz I need help for the schematic diagram of this simple ICSP does it really work for 16f877a can you post the schematic diagram for this one.
    Im a newbie in PIC and I'm using microcode studio but there are many problems like I build the required circuit but the software says reset the target microcontroller .. and some part of the threads here that I need a bootloader like tinybootloader
    http://www.etc.ugal.ro/cchiculita/so...bootloader.htm
    but what is the circuit requirements for this one in order to program a 16f877a
    Pls reply guyz ASAP
    Thanks alot
    Dec 2007
    Finland
    Post
    Quote Originally Posted by t_mask17 View Post
    Pls reply guyz ASAP
    Thanks alot
    Olimex PIC-PG2 (in pdf)
    I have used similar, but homemade with DL4YHF's WinPic Programmer
    Working well!
    BR,
    -Gusse-
    Last edited by Gusse; - 27th December 2009 at 16:13. Reason: Some small editing...
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 03:11
  2. Soic Icsp
    Last Post: - 13th September 2008, 20:51
  3. Replies: 1
    Last Post: - 11th December 2007, 00:57
  4. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  5. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
