HSERIN / SERIN Problem with 16f690
Results 1 to 25 of 25
    DEFINE HSER_ODD 1
    How is it working at all?
    Get rid of that line...
    From mr_e's PIC MULTICALC . . .
    DEFINE HSER_SPBRG 92  ' 2400 Baud @ 3.579MHz, 0.21%
    Oct 2008
    Okay. Below is my new code (I've added an LED to port b.6). Here's what happens. A capital 'A' shows on the terminal window, the LED goes on, the LED then goes out, another 'A' shows on the terminal, the LED goes on and there is where it stays. I never touched the keyboard during this time. After this process, it doesn't matter what I type in the terminal window, the light stays on and nothing else happens. Any thoughts?
    Include "modedefs.bas"
    DEFINE OSC 3
    define HSER_RCSTA 90h
    define HSER_TXSTA 24h
    DEFINE HSER_CLROERR 1
    OSCCON= $08
    'this is the layout for portb.5 - RB5/AN11/RX/DT
    'turn off analog input for port b.5
    ANSELH=0
    'and any other analog stuff
    ANSEL=0
    'there's several analog comparators - lets shut them off
    'I dont know which one - shut them all off
    CM1CON0 =0
    CM2CON0 =0
    CM2CON1 =0
    adcon1=0
    'now set it for input
    trisb.5 = 1
    trisc.0 =1
    rxPin VAR portB.5
    txPin VAR portB.7
    rxVal Var Byte
    txVal Var Byte
    loop:
    'serout txPin,T2400,["A"]
    hserout ["A"]
    Pause 1000
    High Portb.6
    Pause 1000
    'Low portb.6
    hserin [rxVal]
    'serin rxPin,T2400,rxVal
    'pause 500
    'serout txPin,T2400,[rxVal]
    hserout [rxVal]
    Low portb.6
    goto loop
    How about just a simple 'echo-ing' program to make sure everything is working first
    DEFINE OSC 3
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    Char VAR BYTE : led var portb.6 : output led : input portb.5 : output portb.7
    Main: HSERIN [Char] : led = 1 : HSEROUT [Char] : pause 10 : led = 0 : GOTO Main
    Type on the PC, characters should show up on the PC. Led should blink once for each character received/sent-back. Don't type any faster than 54 characters per second.
    Oct 2008
    Skimask,
    Okay, I put in your program. The light blinks once (when I release from reset - I don't touch anything), no character is displayed and that's it. I tried putting a HSEROUT before your main loop and it does send out a character. Any thoughts about turning off the built in analog stuff?
    Rob
    Quote Originally Posted by rborsuk View Post
    Skimask,
    My bad...yes, turn off all of the analog ports...everything over to digital.
    DEFINE OSC 3
    cm1con0 = 0 : cm2con0 = 0 : ansel = 0 : anselh = 0
    led=1 : pause 500 : led=0 : pause 500 : led=1 : pause 500 : led=0 : pause 500
    Are you sure the PIC is running? Try a quick "blinky" without any serial stuff.
    Oct 2008
    Mackrackit,
    Yep, it's running. Follow the rest of my reply.
    Skimask,
    Sorry for the delay. I wanted to try some additional things. I'll explain in a bit. I tried the new code. It produces two long flashes on the LED and one very quick one. It then does nothing. No characters are displayed on the terminal and I can't enter anything. Thinking that it might be something else, I traded out the Max232 with a Max233 (eliminated the caps and such). Same results. I then tried a new 16F690 (thinking that the other one might have been damaged), same results. Anything we're missing here?
    Rob
    Oct 2008
    Okay done. I was trying all kinds of things and forgot to remove that line. Please see my new post below.
    Rob
  1. HSERIN problem
    By eggman in forum mel PIC BASIC Pro
    Last Post: - 6th October 2007, 22:31
  2. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 23:50
  3. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 04:59
  4. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  5. HSERIN problem
    By s_syafiq81 in forum Serial
    Last Post: - 1st January 2006, 12:05
