HSERIN / SERIN Problem with 16f690
Results 1 to 25 of 25
    Oct 2008
    Here's the exact include I was using with mplabs
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F6xx.INC'	; PM header
            device  pic16F690, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F690, r = dec, w = -302
            INCLUDE "P16F690.INC"	; MPASM  Header
            ;* __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    		__config _XT_OSC & _WDT_ON & _MCLRE_ON & _CP_OFF
            NOLIST
            LIST
    When I switched to melabs, I modified the top one. I'm guessing that the pickit / icd2 wasn't the problem but maybe a difference in the compiler. What do you think?
    Rob
    I think you always should comment all default config line (both for MPASM and PM, DEVICE and CONFIG lines) and then set your config fuses in your code.
    Way more handy, because you don't need to remember each time which fuses you have hidden for a XYZ project using the same PIC.
    Have a look at the following, post #1 and #5 are all you need for now.
    Easier, I think to just comment them out and set them in your code every time. If you do not want to type, then make a file with all the setup code you use most often and open it everytime you start a new project, and save as, before your first compile.
    EDIT: Mister_e, fast on the draw!
    Jan 2010
    Detroit, Michigan, USA
    Default 16f690 Hserin problem
    Hello:
    I am having this same issue; what was the solution?
    TomC
    Jan 2010
    Default 16f690 HSERIN Problem
    I neglected to set the ANSEL and ANSELH to 0!!!
    TomC
  1. HSERIN problem
    By eggman in forum mel PIC BASIC Pro
    Last Post: - 6th October 2007, 21:31
  2. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 22:50
  3. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 03:59
  4. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  5. HSERIN problem
    By s_syafiq81 in forum Serial
    Last Post: - 1st January 2006, 11:05
