HSERIN problem
Results 1 to 3 of 3
Thread: HSERIN problem
    Oct 2007
    The Netherlands
    Default HSERIN problem
    Hello everyone,
    I'm having trouble getting HSERIN to work properly, I think there is something I don't understand.
    I am controlling a DC motor through a Gamoto PID controller and want to read back the position. This is converted to a MIDI signal for use in a Max/Msp program. When I use the Serin2 command it works ok, but when I use the Hserin command my results are unpredictable, that is, I think I first get data that was left in the buffer and then the new data. The bytes are not in the correct order. If I leave out the CLROERR thing it does not work at all, so I think I get overflow errors. Any idea of how I can solve this? I would like to understand the Hserin command better so I can use that instead of the Serin2 command.
    Here's (part of) my code:
    @ device pic16F688, pwrt_on, mclr_off, protect_off, wdt_on, hs_osc
    INCLUDE "modedefs.bas"
    define OSC 20
    DEFINE HSER_ 1
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    RCSTA = $90 ' Enable USART RX
    TXSTA = $24 ' Enable USART TX
    SPBRG = 129 ' 9600 Baud
    OSCCON.3 = 1
    ANSEL = %10000000 'AN7 analog input
    ADCON0.7 = 1 '10-bit result right justified
    CMCON0 = %00000111 'comparators off
    PORTA = %00000000
    TRISA = %00000000
    PORTC = %00000000
    TRISC = %00111010
    ack var byte
    rx_data1 VAR BYTE 'received serial data
    rx_data2 VAR BYTE 'received serial data
    rx_data3 VAR BYTE 'received serial data
    checksum VAR BYTE
    position var word
    pos1 var byte
    pos2 var byte
    readpos:
    hSerOut [$AA,$82,$33,$03,$B8] 'send request for position
    hSerIn [ack,rx_data1,rx_data2,rx_data3,checksum]
    ' SerIn2 PORTC.5,84,10,readpos,[wait ($41),rx_data1,rx_data2,rx_data3,checksum]
    position = ((rx_data1>>4) + (rx_data2<<4)) + (rx_data3<<12)
    pos1 = position & 127 'split into two 7 bit position bytes
    pos2 = (position >> 7) & 127
    SerOut2 PORTC.2,12,[$90,pos1,pos2] 'send out midi
    pause 50
    goto readpos
    Any help is appreciated
    When you're using HSERIN/HSEROUT, you also need to use the according define with, unless the baudrate will be 2400 Bauds.
    In your case @ 20 MHz you will need to use..
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    Oct 2007
    The Netherlands
    Thank you Mr E for your reply
    I am using version 2.45 which has a bug so I cannot use the HSER defines with a pic16F688.
    I do use the DEFINE HSER_CLROERR 1 which works ok.
    Is there a way to clear the buffer before using the HSERIN command?
    thanks again
  1. PIC16F88 HSERIN to LCD Problem
    By robbrownuk in forum mel PIC BASIC Pro
    Last Post: - 6th June 2009, 23:32
  2. 16F877 HSERIN problem with 3th party software
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 11th March 2009, 18:11
  3. PIC HSERIN problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 20th July 2008, 12:08
  4. Replies: 3
    Last Post: - 12th February 2007, 19:32
  5. HSERIN problem
    By s_syafiq81 in forum Serial
    Last Post: - 1st January 2006, 12:05
