Eugeniu, below are some ideas on how to modify your code with the help of an LCD. This should provide all the info for the conversion, decoding, and displaying of the temp based on the DS18S20 (which matches your previous posted table). All based on your code, SKIMASK's suggestions, and readily available code on the forum.
modifications to variables
reading temperature (this is not better than what you had, just short and simple)Code:Cold_Bit VAR temperature.Bit11 ' Sign-Bit for +/- Temp. 1 = Below 0 deg C Half_Deg_Bit VAR temperature.Bit0 ' 0.5deg Bit Sign VAR temperature.HIGHBYTE ' +/- sign for temp display temperature_int VAR temperature.LOWBYTE ' integer part of temperature temperature_dec VAR BYTE ' fractional part of temperature digit var byte[5]
storing raw temperature on EEPROMCode:'read temperature OWOut DQ, 1, [$CC, $44] ' Start temperature conversion pause 1000 ' Wait max conversion time OWOut DQ, 1, [$CC, $BE] ' Read the temperature OWIn DQ, 0, [temperature_int, sign] ' Store temperature on variable
reading raw temperature from EEPROMCode:'store raw value of temperature in EEPROM (like SKIMASK suggested) adr = 24 i2cwrite i2cdat, i2cclk, $a0, adr,[sign] adr = 25 i2cwrite i2cdat, i2cclk, $a0, adr,[temperature_int]
decoding temperature (including negative temperatures)Code:'read raw temperature from EEPROM adr = 24 i2cread i2cdat, i2cclk, $a0, adr, sign adr = 25 i2cread i2cdat, i2cclk, $a0, adr, temperature_int
displaying decoded temperature on LCDCode:'decode temperature as needed (this will decode both positive and negative temperatures) IF Cold_bit = 1 THEN ' If Cold_Bit = 1, negative temperature Sign = "-" temperature_int = (255 - temperature_int) + 1 ' 2s Complement ELSE ' If Cold_Bit = 0, positive temperature Sign = "+" ENDIF temperature_int = temperature_int / 2 ' Strip LSB from temperature reading IF Half_Deg_Bit = 1 ' If Half_Deg_Bit = 1, add half degree to result temperature_dec = 5 ELSE temperature_dec = 0 ENDIF
storing decoded temperature digitsCode:'to display temperature on LCD lcdout sign , DEC2 (temperature_int) , "," , DEC2 (temperature_dec)
P.S. When posting use the "code" tags to wrap the code and display it nice and tidy. Also use the "quote" tags when quoting somebody; again it displays nice and tidy.Code:'to extract digits digit[5] = temperature_int dig 2 digit[4] = temperature dig 1 digit[3] = temperature dig 0 digit[2] = "," digit[1] = temperature_dec dig 0 digit[0] = 0
. Thanks !
