Write Onewire data toa I2C memory / read ASCI
Results 1 to 40 of 68
    Nov 2007
    skimask;64450]Right. I understand what you are trying to do, with the EEPROM and the LED matrix's and such. It's a relatively common project.
    What you aren't understanding is that you are only writing ONE BYTE at a time with those statements, not 3 at a time as your changing addresses would indicate.
    And one other thing is 'precedence'. I'm not sure if it's applicable in this case, but...
    In your statement above...
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[temperature.LOWBYTE dig 4+48 ]
    How does that get interpreted?
    Assume temperature.lowbyte = 123
    You are trying to retrieve the 4th (actually 5th) digit of a byte value to which there can only be 3 digits.
    I understand what you say , but I try something , to see what display
    Another thing, still assuming temperature.lowbyte = 123, and assume that 'dig 4' is actually 'dig 0'...
    Will that statement return "3" + 48 or does it try to return the 52nd digit of temperature.lowbyte?
    A better way to put that statement might be:
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[ ( temperature.LOWBYTE dig 4 ) + 48 ]
    Is not imprtant , + or - paranthesis I see on display the same result .
    For the result of " temperature.LOWBYTE " I do not understand what is this number .
    If I put
    adr = 24
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[(temperature dig 2) + 48]
    pause 15
    adr = 27
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[(temperature dig 1) + 48]
    pause 15
    adr = 30
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[(temperature dig 0) + 48]
    pause 15
    Obtein a number which is a hexa from a teperature ...968 ,975 - 2408,2421
    For a LCD display write DEC2 (temperature/100) "," DEC2 (temperature//100). But for me in this moment I do not know what to do !
    Ok, so the parenthesis don't make a difference, no problem...Guess we're going to have to build this up from scratch...
    Do you have that LCD connected to your project? Is it working as you expect it to work (i.e. displays HELLO if you command it)
    EDIT: Never mind, obviously you do have the LCD connected...
    In reference to your I2CWRITE statements a few posts ago...
    adr = 24
    pause 15.......and so on.....
    You do NOT need to store temperature in the manner you are storing it. What you are doing in effect is storing the ASCII equivalent of your temperature value in 3 bytes, then retrieving that same result and trying to display the ASCII result of each of those bytes...in effect, display the ASCII values of the ASCII values of the bytes originally stored....sort of like looking at a camera which is looking at you looking at a camera which is looking at you...infinite regression...
    It looks to me like you're doing twice as much work as you need to do!
    Try to store the temperature like this:
    adr = 24
    i2cwrite i2cdat, i2cclk, $a0, adr,[temperature.highbyte]
    adr = 25
    i2cwrite i2cdat, i2cclk, $a0, adr,[temperature.lowbyte]
    This will store the WORD variable temperature in two bytes as required.
    Then for retrieving that same value:
    adr = 24
    i2cread i2cdat, i2cclk, $a0, adr, temperature.highbyte
    adr = 25
    i2cread i2cdat, i2cclk, $a0, adr, tempearture.lowbyte
    lcdout DEC2 (temperature/100) , "," , DEC2 (temperature//100)
    This should display on the LCD is in fact the temperature sensor and it's code are working properly.
    To get the individual digits from this value for display on the LED matrix instead of the LCD:
    adr = 24
    adr = 25
    digit var byte[5]
    digit[5] = temperature dig 4
    digit[4] = temperature dig 3
    digit[3] = temperature dig 2
    digit[2] = ","
    digit[1] = temperature dig 1
    digit[0] = temperature dig 0
    Nov 2007
    Smile
    [QUOTE=skimask;64461]Ok, so the parenthesis don't make a difference, no problem...Guess we're going to have to build this up from scratch...
    No , I have not a LCD display on the same leds display , but in my mind is to do this . I have a LCD display on a test plate for differnet programs .
    I know very well to work with a LCD display ( is a good "HELP " in MicroBasic Studio Plus
    "Obtein a number which is a hexa from a teperature ...968 ,975 - 2408,2421 "
    This is wrong . Was a dream ! When I have put my fingers on it , what I can see on leds display was more differnt by my body temperature
    Is not necesary to use " HIGH BYTE " I use only "LOW BYTE "
    [code]
    adr = 24
    adr = 25
    digit var byte[5]
    digit[2] = ","
    I'll try this !
    Quote Originally Posted by Eugeniu View Post
    Should use it more often...
    The 'temperature' function will return a WORD result.
    digit var byte[5]
    digit[2] = ","
    I'll try this !
    That's what we suggested back in post #2!!!
    USA - Arizona
    Eugeniu, below are some ideas on how to modify your code with the help of an LCD. This should provide all the info for the conversion, decoding, and displaying of the temp based on the DS18S20 (which matches your previous posted table). All based on your code, SKIMASK's suggestions, and readily available code on the forum.
    modifications to variables
    Cold_Bit VAR temperature.Bit11	' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    Half_Deg_Bit VAR temperature.Bit0	' 0.5deg Bit
    Sign VAR temperature.HIGHBYTE	' +/- sign for temp display
    temperature_int VAR temperature.LOWBYTE	' integer part of temperature
    temperature_dec VAR BYTE	' fractional part of temperature
    digit var byte[5]
    reading temperature (this is not better than what you had, just short and simple)
    'read temperature
    OWOut DQ, 1, [$CC, $44]	' Start temperature conversion
    pause 1000	' Wait max conversion time
    OWOut DQ, 1, [$CC, $BE]	' Read the temperature
    OWIn DQ, 0, [temperature_int, sign]	' Store temperature on variable
    storing raw temperature on EEPROM
    'store raw value of temperature in EEPROM (like SKIMASK suggested)
    adr = 24
    i2cwrite i2cdat, i2cclk, $a0, adr,[sign]
    adr = 25
    i2cwrite i2cdat, i2cclk, $a0, adr,[temperature_int]
    reading raw temperature from EEPROM
    'read raw temperature from EEPROM
    adr = 24
    i2cread i2cdat, i2cclk, $a0, adr, sign
    adr = 25
    i2cread i2cdat, i2cclk, $a0, adr, temperature_int
    decoding temperature (including negative temperatures)
    'decode temperature as needed (this will decode both positive and negative temperatures)
    IF Cold_bit = 1 THEN	' If Cold_Bit = 1, negative temperature
    	Sign  = "-"
    	temperature_int = (255 - temperature_int) + 1	' 2s Complement
    ELSE	' If Cold_Bit = 0, positive temperature
    	Sign  = "+"
    temperature_int = temperature_int / 2	' Strip LSB from temperature reading
    IF Half_Deg_Bit = 1	' If Half_Deg_Bit = 1, add half degree to result
    	temperature_dec = 5
    	temperature_dec = 0
    displaying decoded temperature on LCD
    'to display temperature on LCD
    lcdout sign , DEC2 (temperature_int) , "," , DEC2 (temperature_dec)
    storing decoded temperature digits
    'to extract digits
    digit[5] = temperature_int dig 2
    digit[4] = temperature dig 1
    digit[3] = temperature dig 0
    digit[2] = ","
    digit[1] = temperature_dec dig 0
    digit[0] = 0
    P.S. When posting use the "code" tags to wrap the code and display it nice and tidy. Also use the "quote" tags when quoting somebody; again it displays nice and tidy.
    One of the key phrases to be taken from this statement:
    Quote Originally Posted by languer View Post
    All based on your code, SKIMASK's suggestions, and readily available code on the forum...........................
    And this might help your post formatting a bit...
    http://www.picbasic.co.uk/forum/misc...bbcode#imgcode
    Nov 2007
    Was very usefully !
    Thank you .
    PS. I 'll be very bussy for a few day , and after this I'll work again to my project . I 'll tell you what I can doing .
    Nov 2007
    [QUOTE=languer;64516]Eugeniu, below are some ideas on how to modify your code with the help of an LCD.
    Thank you for your try to halp me , But remember I do not use a LCD display !
    I do not use it , becose I do not know it . Thanks !
    But you did say earlier that you do HAVE an LCD, and if you know how to use it, and can make it work, then why not use it to help you find your problem.
    And with those code snippets above, you should be able to pull out of them the chunks of code you may and/or may not need to get your project working, whether it be displayed on an LCD (which would be very handy) or LED matrix or on punch cards.
    Which is why I put that link in post #57 above. That way you can learn how to use those 'tags'.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
