Write Onewire data toa I2C memory / read ASCI
Results 1 to 40 of 68
    Nov 2007
    [QUOTE=languer;64516]Eugeniu, below are some ideas on how to modify your code with the help of an LCD.
    Thank you for your try to halp me , But remember I do not use a LCD display !
    P.S. When posting use the "code" tags to wrap the code and display it nice and tidy. Also use the "quote" tags when quoting somebody; again it displays nice and tidy
    I do not use it , becose I do not know it . Thanks !
    Quote Originally Posted by Eugeniu View Post
    But you did say earlier that you do HAVE an LCD, and if you know how to use it, and can make it work, then why not use it to help you find your problem.
    And with those code snippets above, you should be able to pull out of them the chunks of code you may and/or may not need to get your project working, whether it be displayed on an LCD (which would be very handy) or LED matrix or on punch cards.
    Which is why I put that link in post #57 above. That way you can learn how to use those 'tags'.
    Nov 2007
    I have try , be sure . I use a test program on LCD , bat there it work , on LEDS display not . For LCD are very usefully DEC ; HEX;...commands . I'try to change the kind of writing text ,(in my programme) ,to use " SELECT CASE " for binary or hexa byte .
    So are you saying that everything works as you want it to work if you are using the LCD?
    There is no need to rewrite the entire program!!! Your answers have been practically handed to you in previous posts, with example provided. The only thing left to do is to write the code for you.
    Nov 2007
    Yes ! But not on this plate . On this plate (Leds display )I use a PIC 16F876 and I have 3 free pins only on it . I can not install a LCD. Will be very usefully . I am not sure ( in my mind )every time that sensor work . In future I try to change PIC with 16F877 ,to can have together Leds and LCD display for ilk sensor .
    I am not sure that I understand what you say !
    Ok, as long as the code works in one place... I understand you don't have enough pins to run the LCD on this particular board and need to use the matrix'd LEDs...
    Meaning that the posts referring to the use of the DIG function with bytes/words/whatever are most likely what you need to pull the individual digits out of the bytes/words/whatever to send to the LEDs...
    Nov 2007
    I have made a few changes :
    In the first time write a few blanks (16)
    I2cwrite I2CDAT , I2CCLK , $A0,ADR,[ ]
    I have insert this lines
    SELECT CASE CARACTER
    CASE %0000000 : SIR_NO=137 ;0
    CASE %0000001 : SIR_NO=140 ;1
    CASE %0000010 : SIR_NO=145 ;2
    CASE %0000011 : SIR_NO=150 ;3
    CASE %0000100 : SIR_NO=155 ;4
    CASE %0000101 : SIR_NO=160 ;5
    CASE %0000110 : SIR_NO=165 ;6
    CASE %0000111 : SIR_NO=170 ;7
    CASE %0001000 : SIR_NO=175 ;8
    CASE %0001001 : SIR_NO=180 ;9
    TEMP1 VAR BYTE
    TEMP2 VAR BYTE
    temp1 = temperature.LOWBYTE /2
    temp2 = (100- (100/16)*(count_remain))
    (This FORMULAS work very well with LCD display )
    and writing
    adr = 4
    i2cwrite I2CDAT, I2CCLK, $A0, adr,[(temp1)dig 1,(temp1)dig 0,",",temp2 dig 1,temp2 dig 0 ]
    pause 15
    Now I read on LEDS display
    for begining 2000404,0502 ( this ciphers from the right side are more variables)
    when I put my fingers on sensor all nubers are modify . More right side
    and last ciphra from left side :
    200050x,0x0x
    200060x,0x0x
    200090x,0x0x
    200010x,0x0x
    " 2 " not change in "3" . And not 25,xx or 26,xx ......and so on
    GIVE ME AN OTHERS IDEAS !
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
