Generating 3-phase sine wave..
Results 1 to 39 of 39
    Jan 2007
    Brazil
    I've been using this one:
    '*  Name    : DT_INTS-14.bas                                    *
    '*  Author  : Darrel Taylor                                     *
    '*  Version : 0.93 BETA                                         *
    '*  Date    : JAN 29, 2006                                      *
    '* Rev 0.93  Fixed CMIF and EEIF problem with older PIC's       *
    '*           that have the Flags in PIR1 instead of PIR2        *
    '* Rev 0.92  solves a "Missed Interrupt" and                    *
    '*           banking switching problem                          *
    Is there an update?
    Sylvio,
    Quote Originally Posted by sirvo View Post
    Is there an update?
    I thought it was farther along than .93b...but after a quick bit of looking, maybe not. Then again, maybe there are a few fixes here and there that just never had the 'official' update done.
    .93 is the current version for the 14-bit pics.
    Do you have a CLEAR statement at the TOP of your program?
    Jan 2007
    Brazil
    Last project I used the CLEAR statement, but not in this one.. Would it be necessary since I've set all the variables at the top of the program?
    Sylvio,
    Maybe ... I'm not really sure.
    The last problem with DT_INTS-18 was because of that.
    DT_INTS-14 is at .93 now because I've never really been confident enough to call it "DONE". And I don't give it as much attention as the 18F version. My Avatar could be a clue.
    Give it a try, couldn't hurt.
    Jan 2007
    Brazil
    One week later, I'm back.. but no luck yet..
    I've tried to add the CLEAR statement but nothing happened... it still remains like it was...
    Is there another tip??????
    Thanks!
    Sylvio,
    You could post the rest of the program.
    Like I said <a href=#post59895>before</a>, I've run what you posted here (on a diff chip) and everything was fine.
    There may be something in the portion of the program that wasn't included.
    Jan 2007
    Brazil
    Ok...
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    '@ DEVICE pic16F777, HS_OSC ; System Clock Options
    '@ DEVICE pic16F777, WDT_OFF ; Watchdog Timer
    '@ DEVICE pic16F777, PWRT_ON ; Power-On Timer
    '@ DEVICE pic16F777, MCLR_OFF ; Brown-Out Detect
    '@ DEVICE pic16F777, PROTECT_OFF
    @  __CONFIG    _CONFIG1, _MCLR_OFF & _PWRTE_ON & _WDT_OFF & _HS_OSC
    define  OSC 20
    DEFINE HSER_SPBRG 10  ' 115200 Baud @ 20MHz, -1,36%
    clear
    MODO    VAR BYTE[3]
    DIST    VAR BYTE
    SAG     VAR BYTE[3]
    SAG[0] = 0
    SAG[1] = 0
    SAG[2] = 0
    SWELL   VAR BYTE
    SWELL = 0
    CTRL    VAR BYTE
    LOAD    VAR WORD
    RA      VAR BYTE
    RB      VAR BYTE
    RC      VAR BYTE
    RD      VAR BYTE
    RA = 0
    RB = 1
    RC = 0
    RD = 0
    V       VAR BYTE
    VA      VAR BYTE
    VB      VAR BYTE
    VC      VAR BYTE
    CONTA    VAR BYTE
    CONTB    VAR BYTE
    CONTC    VAR BYTE
    CONT    VAR BYTE
    INDEX   VAR BYTE
    FLAG    VAR BYTE
    X       VAR BYTE
    FLAG = 0
    CONTA = 0
    CONTB = 23
    CONTC = 47
    modo[0] = 1
    modo[1] = 1
    modo[2] = 1
    ' Set CCPx pins to outputs
    TRISC.2 = 0 ' CCP1 output
    TRISC.1 = 0 ' CCP2 output (could also be assigned to RB3)
    TRISB.5 = 0 ' CCP3 output
    TRISC.7 = 1
    TRISC.6 = 0
    TRISD.0 = 0
    ' Set CCP modules to PWM mode
    CCP1CON = %00001100 ' Mode select = PWM
    CCP2CON = %00001100 ' Mode select = PWM
    CCP3CON = %00001100 ' Mode select = PWM
    INTCON = %11000000
    LOAD = 65250' 4320Hz
    'LOAD = 0
    TMR1H = LOAD.HIGHBYTE
    TMR1L = LOAD.LOWBYTE
    T1CON = %00000001
    PIE1.0 = 1
    PR2 = 200
    'PR2 = 62
    PORTD.0 = 0
    ' Set TMR2 up for 1:1 prescale & turn it on
    T2CON = %00000100 ' TMR2 ON 1:1 prescale
    'T2CON = %00011100 ' TMR2 ON 1:1 prescale
    INT_LIST macro ;IntSource, Label,    Type, ResetFlag?
        INT_Handler TMR1_INT, _Timer1,   PBP, yes
        INT_Handler RX_INT,   _GetChar,  PBP, yes
        INT_Handler TX_INT,   _SendChar, PBP, yes
    @    INT_ENABLE  TMR1_INT   ; Habilita interrupção do TMR1
    @    INT_ENABLE  RX_INT     ;- enable the interrupt
    @    INT_ENABLE  TX_INT     ;- enable the interrupt
    MAIN:
        IF FLAG = 1 THEN
            PORTD.0 = 1
            flag = 0
            CONTA = CONTA + 1
            CONTB = CONTB + 1
            CONTC = CONTC + 1
            if contA = 71 then contA = 0
            if contB = 71 then contB = 0
            if contC = 71 then contC = 0
            index  = conta
            if RA.0 = 1 then
                DIST = RB
                SAG[0] = RC
                MODO[0] = DIST
                DIST = MODO[0]
            GOSUB tabela
            va = (v*(100-sag[0]))/100
            index  = contB
            if RA.1 = 1 then
                DIST = RB
                SAG[1] = RC
                MODO[1] = DIST
                DIST = MODO[1]
            GOSUB tabela
            vb = (v*(100-SAG[1]))/100
            index  = contC
            if RA.2 = 1 then
                DIST = RB
                SAG[2] = RC
                MODO[2] = DIST
                DIST = MODO[2]
            GOSUB tabela
            vc = (v*(100-SAG[2]))/100
            RA = 0
            GOSUB SAIDA
            PORTD.0 = 0
        GOTO MAIN
    TABELA:
        SELECT CASE DIST
        CASE 1: ' Fundamental
               LOOKUP INDEX, [100,109,118,126,135,143,151,158,165,171,177,183,187,191,195,197,199,200,200,199,198,196,193,189,185,180,175,168,162,154,147,139,130,122,113,104,96,87,78,70,61,53,46,38,32,25,20,15,11,7,4,2,1,0,0,1,3,5,9,13,17,23,29,35,42,49,57,65,74,82,91], V
        CASE 2: ' 3 com 20%
               LOOKUP INDEX, [100,114,127,140,152,162,170,177,182,185,187,187,187,185,184,182,181,180,180,180,181,182,184,185,187,187,187,185,182,177,170,162,152,140,127,114,100,86,73,60,48,38,30,23,18,15,13,13,13,15,16,18,19,20,20,20,19,18,16,15,13,13,13,15,18,23,30,38,48,60,73,86], v
        CASE 3: ' 3 com 20% + 5 com 10%
               LOOKUP INDEX, [100,118,135,150,161,170,175,178,178,178,177,177,178,180,182,185,188,189,190,189,188,185,182,180,178,177,177,178,178,178,175,170,161,150,135,118,100,82,65,50,39,30,25,22,22,22,23,23,22,20,18,15,12,11,10,11,12,15,18,20,22,23,23,22,22,22,25,30,39,50,65,82], V
        CASE 4: ' 3 com 20% + 5 com 10% + 7 com 10%
               LOOKUP INDEX, [100,124,144,159,168,171,170,168,168,171,175,181,187,190,190,188,184,181,180,181,184,188,190,190,187,181,175,171,168,168,170,171,168,159,144,124,100,76,56,41,32,29,30,32,32,29,25,19,13,10,10,12,16,19,20,19,16,12,10,10,13,19,25,29,32,32,30,29,32,41,56,76], V
        CASE 5: ' 5 com 10% + 7 com 20%
               lookup index, [100,122,139,149,151,147,141,136,137,145,157,172,186,194,197,194,188,183,181,183,188,194,197,194,186,172,157,145,137,136,141,147,151,149,139,122,100,78,61,51,49,53,60,64,63,55,43,28,14,6,3,6,12,17,19,17,12,6,3,6,14,28,43,55,63,64,59,53,49,51,61,78], v
        CASE 6:
        CASE 7:
        end select
    SAIDA:
            CCP1CON.4 = VA.0
            CCP1CON.5 = VA.1
            CCPR1L = VA >> 2
            CCP2CON.4 = VB.0
            CCP2CON.5 = VB.1
            CCPR2L = VB >> 2
            CCP3CON.4 = VC.0
            CCP3CON.5 = VC.1
            CCPR3L = VC >> 2
    Timer1:
        TMR1H = load.highbyte
        TMR1L = load.lowbyte
        FLAG = 1
    @ INT_RETURN
    GetChar:
          HSERIN [dec RA]
          HSERIN [dec RB]
          HSERIN [dec RC]
          HSERIN [dec RD]
    @   INT_RETURN
    SendChar:
          'hserout [dec cod[0], "-", dec cod[1], "-", dec cod[2], "-", dec cod[3]]
    @   INT_DISABLE  TX_INT    ;- disable the interrupt
    @   INT_RETURN
    Sylvio,
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 14:39
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  3. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  4. 3 phase PWM with dsPIC30F2020
    By nemmard in forum mel PIC BASIC
    Last Post: - 21st January 2009, 15:19
  5. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 08:35
